spin-control behavior
Brooks_Van_Horn
I have an up/down spin control in a dialog and I have a working call-back routine and the control works fine with its integer edit buddy. However, the edit box does not display an initial value. If I press the up or down part of the spinner then it correctly displays the right value. I just don't seem to be able to get it to display its startup value. If I query the spin-control for its position it returns the correct value. I've even tried to do a dlgsetint to the edit control but no correct initial display.
Any ideas?
Brooks Van Horn
andrew_4619
You will need to initialise the buddy window data when you initialise the dialog
Brooks_Van_Horn
Hi Andrew,
Was already doing that and I just walked a debug session and all the return codes came out .TRUE. So some grimlin is at work here.
Brooks
cean
New Contributor II
After changing dialog, you need to update the resource.fd file.
