29640 Discussions
split a program in two subroutine
roddur
Hello friends,
I have this code in hand and my job is to split this in two subroutine, from atompp. (Sorry for putting the long code, but hope this may be helpful)
[cpp]c#define LM
program lm
! subroutine lm()
implicit none
! Common blocks:
! --- dynamical memory allocation:
integer wksize
parameter(wksize=8000000)
integer w(wksize)
common/wkarr/w
! Controls for IO
integer ishow,ncnt1,ncnt2,mcount
parameter (ncnt1=1,ncnt2=2,mcount=20)
character*4 cquit,err,output
character*8 prgnam
! Parameters for options, structure, basis
integer nbas,nclass,nl,nlrho,nsp,mmixat
integer nit,nitat,ndel(3),ltmax(3),ifmt3d
double precision bound(3,6),origin(3),plat(9,6),alat(2)
logical switch(31)
! for iterations
integer niter,mmixpq
double precision beta,rmsdel,rms2,toleto,wc
! Class parameters
integer mxclas
parameter (mxclas=200)
integer lmx(mxclas),lmxrho(mxclas),nrclas(mxclas),
. konfig(0:3,mxclas)
double precision dq(mxclas),qc(mxclas),qtot(2*mxclas),
. ves(2*mxclas),vrmax(2*mxclas),wsr(mxclas),z(mxclas)
character*4 clabl(mxclas)
! Symmetry group
integer nsymop,ngen
double precision symopm(9,48),symopv(3,48)
character*72 symops(48),gens(48)
! BZ - integration / empty-sphere finder
integer nkxyz(3),norder,nopts,npts
double precision emin,eminc,emax,emaxc,range,tolef,width
! Empty-sphere finder
double precision rmaxes,rmines
integer nrxyz(3)
! Scaling wsr
double precision asavol,facvol,gamma,ommax1(3),ommax2(3)
! Structure constant parameters
integer ialpha,itrans,lmaxw,ndimin,jbasdn,ldn,mdn,nsmesh
double precision dele,deltr,kap2,kfit,rmaxs,rmaxs2,eps
! Parameters relating to Ewald sums
integer nkdmx
double precision as,awald,tolews,vol
! for rhofit
integer rfout
! for SYML
integer mxline
parameter (mxline=99)
integer nq(mxline),nline
double precision q1(3,mxline),q2(3,mxline)
character*1 lab1(mxline),lab2(mxline)
! Local variables, functions and offsets to dynamic arrays
integer fopn,i,ibas,ic,icalc,iprint,isym(10),j,lunit,len2,mxkp,
. nkd,nkg,nkp,npp,nrxc,obeta,oadot0,oalph0,obas,obk,
. odlat,oenu,oevrl,oglat,oibk,oiclas,oidmod,oidxdn,onrcls,
. opnu,opp,oqnu,osigma,osigm2,otrtab,owk,owtkp,og
parameter(npp=6)
double precision avw,avwsr,dovl1(3),dovl2(3),efermi,
. qb(9),vmtz
logical begmom,convrg,lsmall,t,f,lpot,lsymst,lsdm1,nowrit
character*30 csym(7)
character*72 name,tit
parameter(t=.true.,f=.false.)
! External calls
external avwsr,chkcls,chkdis,chksym,chkwsr,defdr,defi,dscal,fexit,
. finits,fopn,icopy,iprint,lunit,ioctrl,allocm,wkinit
integer isum,ldim,nderiv,neighm,nmesh,ntet,
. oadot,oadoto,oalpha,oalpho,ocg,ocy,odmad,odmat,
. oeband,oemom,oiax,oidn,oidtet,oindcg,oirr,oixirr,
. ojcg,onpr,opold,oqold,orwats,os,osdot,osdm1,osdm1s,
. otrad,otral
double precision detot,ebmax,ebmin,etot,etoto,sumdq,zval
character*4 cnit
data prgnam/'LM'/
data ialpha/0/,ifmt3d/1/,itrans/0/,jbasdn/1/,ldn/0/,lmaxw/8/,
. ltmax/2,2,2/, mdn/0/, mmixat/2/,
. mmixpq/1/, nbas/1/, nclass/1/, ndimin/350/,ngen/0/,nit/1/,
. nitat/30/,niter/30/,nkdmx/250/,nkxyz/4,4,4/,nl/3/,
. nopts /8001/, norder/0/,npts/1001/,nrxc/1/,nrxyz/0,0,0/,
. nsp/1/
data as/.2d1/, beta/.5d0/,dele/.05d0/,deltr/.1d0/, efermi/-.25d0/,
. kap2/.0d0/,kfit/0.d0/ ,emax/.2d1/ ,emaxc/.2d1/ ,emin/-.2d1/,
. eminc/-.2d1/,eps/.0d0/,facvol/.1d1/,gamma/.0d0/,
. ommax1/.16d0,.18d0,.20d0/,ommax2/.40d0,.45d0,.50d0/,
. range/.5d1/ ,rmaxes/.40d1/,
. rmaxs/.32d1/,rmaxs2/.35d1/,rmines/.9d0/,rms2/99.9999999d0/,
. rmsdel/.1d-4/,tolef/.1d-5/,toleto/.1d-4/,tolews/.1d-5/,
. vmtz/-.75d0/,wc/-.1d1/,width/.5d-2/
data clabl/mxclas*'E'/, cquit/'----'/, csym/7*'undef'/,
. err/'ERR '/, gens/'E',47*' '/, output/'LM '/
data convrg/f/, switch/t,t,f,t,f,f,f,f,f,t, t,t,t,f,t,f,f,t,f,f,
. f,f,f,f,t,t,f,f,f,t, f/
write(*,*) "LM called"
! --- time measure
call cpusrt('TOTL',t)
call cpusrt('PRWK',t)
! --- Set up dynamic memory allocation and other initialization ---
call wkinit(wksize)
! --- Set up the file logical units ---
call finits
! --- read CTRL file
do ishow = ncnt1,ncnt2
do i = 0, mcount
call ioctrl(i,prgnam,w(oadot0),alat,w(oalph0),as,avw,
. w(obas),beta,bound,clabl,cquit,csym,dele,deltr,
. efermi,emax,emaxc,emin,eminc,eps,err,facvol,
. gamma,gens,ialpha,icalc,w(oiclas),w(oidmod),
. w(oidxdn),ifmt3d,ishow,isym,itrans,jbasdn,kap2,
. kfit,konfig,lab1,lab2,ldn,lmaxw,lmx,lmxrho,
. lsmall,ltmax,mcount,mdn,mmixat,mmixpq,nbas,
. nclass,ndel,ndimin,ngen,nitat,niter,nkdmx,nkp,
. nkxyz,nl,nline,nlrho,norder,nopts,npts,nq,nrclas,
. nrxc,nrxyz,nsp,nsymop,ommax1,ommax2,origin,output,
. plat,w(opnu),w(opp),q1,q2,w(oqnu),range,rfout,rmaxes,
. rmaxs,rmaxs2,rmines,rmsdel,w(osigma),w(osigm2),
. switch,tit,tolef,toleto,tolews,ves,vmtz,vrmax,wc,
. width,wsr,z)
if (i.eq.6.and.ishow.eq.1) then
! --------- Allocate memory for pp's, moments, basis ....
call allocm(mxclas,nbas,nclass,nl,nlrho,npp,nsp,oadot0,
. oalph0,obas,oenu,oevrl,oiclas,oidmod,oidxdn,
. opnu,opp,oqnu,osigma,osigm2)
elseif (i.eq.8.and.ishow.eq.1) then
! --------- Check the symmetry and eventually complete the basis
call chksym(alat,clabl,csym,gens,isym,switch(30),switch(10),
. lsmall,nbas,nclass,ngen,nrclas,nsymop,obas,oiclas,
. otrtab,plat,prgnam,symopm,symops,symopv,switch(3))
! --------- Average Wigner Seitz radius ---
avw = avwsr(plat,alat,vol,nbas)
if (.not.switch(3).and..not.lsmall)
. call chkcls(w(obas),clabl,w(oiclas),w(oidmod),w(oidxdn),
. w(otrtab),konfig,lmx,nbas,nclass,nl,nrclas,nsp,
. nsymop,w(opnu),w(opp),prgnam,w(oqnu),wsr,z)
elseif (i.eq.9.and.ishow.eq.1) then
call sclwsr(alat,asavol,w(obas),clabl,dovl1,dovl2,facvol,
. gamma,w(oiclas),switch(25),nbas,nclass,nrclas,
. ommax1,ommax2,plat,wsr,z)
call chkwsr(alat,clabl,nclass,nrclas,plat,wsr,z)
if(dabs(asavol-facvol).gt.1.d-5)
. call errmsg
. (' Not space filling: increase number of ES or OMMAX $',4)
endif
enddo
if (ishow.eq.0) then
call fexit(0,' HELP=T encountered')
elseif (ishow.eq.1) then
call chkdis(alat,w(obas),clabl,w(oiclas),nbas,nclass,plat,z)
call gtname(len2,nclass,nrclas,z,name)
tit = name(1:len2)//', '//csym(2)
if (switch(17).or.switch(8).or.prgnam.eq.'LMHART') then
! -------- Get irreducible mesh points
nmesh=(ndel(1)+1)*(ndel(2)+1)*(ndel(3)+1)
call defi(oirr , nmesh)
call defi(oixirr,4*nmesh)
call makirr(bound,w(oirr),w(oixirr),ndel,nsymop,origin,
. plat,symopm,symopv)
call rlse(oixirr)
endif
! --- Set up BZ mesh ---
mxkp = nkxyz(1)*nkxyz(2)*nkxyz(3)
call defi (oibk ,mxkp)
call defdr(owtkp,mxkp)
call defdr(obk ,mxkp*3)
call bzmesh(w(obk),w(oibk),nkxyz(1),nkxyz(2),nkxyz(3),nkp,nsymop,
. plat,qb,symopm,w(owtkp))
call rlse(obk)
call defdr(obk,3*nkp)
if (switch(11).and.(switch(12).or.prgnam.eq.'LMDOS')) then
! ----- find inequivalent tetrahedra ---
call defi(oidtet,mxkp*30)
call tetirr(w(oibk),w(oidtet),nkxyz(1),nkxyz(2),nkxyz(3),
. ntet,qb)
call rlse(oidtet)
call defi(oidtet,ntet*5)
endif
call cpustp('PRWK',f,f)
! --- Calculate localized structure constants ---
call defdr(orwats,-nclass)
nderiv=1
nsmesh=1
lpot=.false.
lsymst=.true.
lsdm1 =.false.
nowrit=.false.
call strrs(w(oadot0),alat,w(oalph0),avw,w(obas),clabl,dele,deltr,
. switch(16),ialpha,icalc,w(oiclas),itrans,kap2,lmaxw,lmx,
. lpot,lsdm1,lsymst,nbas,nclass,nderiv,ndimin,neighm,nl,
. nowrit,nrclas,nsmesh,oadot,oadoto,oalpha,oalpho,ocg,
. ocy,oiax,oindcg,ojcg,onpr,os,osdot,osdm1,osdm1s,
. otrad,otral,plat,rmaxs,w(orwats),w(osigma),wsr)
! --- Generate Madelung matrix ---
call defdr(odmad,nbas*nbas)
call defdr(odlat,3*nkdmx)
call defdr(oglat,3*nkdmx)
call lattc(alat,as,awald,w(odlat),w(oglat),nkd,nkdmx,nkg,
. plat,tolews)
call madmat(alat,awald,w(obas),w(odlat),w(odmad),w(oglat),nbas,
. nkd,nkg,plat)
call rlse(odlat)
if (cquit.eq.'MAD ') call fexit(0,' LM: Q=MAD encountered')
call cpusrt('ITET',t)
do nit=0,niter
begmom = switch(4).or.(nit.gt.0)
write(cnit,'(a1,i3)')'I',nit
call cpusrt(cnit,t)
! ---- This is the beginning of zeroth iteration ---
! ----- Calculate the charges and ves for coming iteration. Necessary
! ----- that this precede ATOMSC since it requires electrostatic shifts
call getq(clabl,dq,konfig,lmx,nclass,nl,nrclas,nsp,w(opnu),qc,
. w(oqnu),qtot,sumdq,z,zval)
call madpot(clabl,w(odmad),w(oiclas),nbas,nclass,qtot,ves,wsr)
call atomsc(begmom,clabl,switch(14),detot,dq,w(oenu),
. etot,w(oevrl),kap2,konfig,switch(17).or.switch(8),
. switch(29),switch(21),switch(6),switch(18),lmx,
. switch(28),switch(1),mmixat,nclass,nitat,nl,
. switch(9),nrclas,nrxc,nsp,w(opnu),qc,w(oqnu),qtot,
. ves,vmtz,vrmax,wsr,z)
if (begmom) call enutpp(w(oenu),w(oidmod),nclass,nl,npp,nsp,
. w(opp))
call atompp(avw,clabl,kap2,switch(6),lmx,switch(1),nclass,
. nl,nsp,w(opp),w(osigma),ves,vmtz,wsr,z)
if (nit.ne.0) detot = etot - etoto
etoto = etot
if (begmom.and.iprint().ge.0)
. write(lunit(1),301)nit,niter,sumdq,etot,rms2,detot
if (cquit.eq.'ATOM') call fexit(0,' LM: Q=ATOM encountered')
if (switch(6)) call fexit(0,' LM: FREE=T encountered')
! ----- Check for convergence ---
convrg=(rms2.lt.rmsdel.and.dabs(detot).lt.toleto)
if (.not.convrg.and.nit.ne.niter) then
! ------- Make copy of old p's and q's and downfolding indices ---
call defdr(opold,nl*nsp*nclass)
call defdr(oqold,nl*nsp*nclass*3)
call defi (oidn ,nl*nclass)
call icopy(nl*nclass,w(oidxdn),1,w(oidn),1)
call dcopy(nl*nsp*nclass ,w(opnu),1,w(opold),1)
call dcopy(nl*nsp*nclass*3,w(oqnu),1,w(oqold),1)
if(switch(8)) call defdr(oemom,-3*nl**4*nsp*nbas)
c call writepp(w(opp),nl,nsp,nclass)
! ------- Band calculation ---
call bndasa(alat,avw,w(obas),w(obk),clabl,dele,
. ebmax,ebmin,efermi,emaxc,eminc,w(oemom),
. w(oevrl),w(oiclas),w(oidtet),w(oidn),kap2,
. ldim,lmx,nbas,nclass,neighm,nkp,nkxyz,nl,
. norder,npts,nrclas,nsp,nsymop,ntet,oadot,oalpha,
. odmat,oeband,oiax,onpr,os,osdot,plat,w(opp),
. w(oqnu),range,w(osigma),switch,symopm,symopv,
. tolef,vmtz,width,wsr,w(owtkp),zval)
if (switch(23)) then
call bzlabs(lab1,lab2,nline,q1,q2)
call wrlmfs(alat,w(obk),w(oeband),efermi,w(oibk),isym(1),
. ldim,nkxyz(1),nkxyz(2),nkxyz(3),nkp,nsp,plat)
endif
if (switch(17))
. call dens(alat,avw,bound,clabl,ifmt3d,w(oirr),kap2,
. switch(29),switch(21),lmx,switch(24),nbas,nclass,
. ndel,neighm,nl,nsp,obas,odmat,oiax,oiclas,oidn,
. onpr,opp,origin,os,plat,wsr,z)
if (switch(8))
. call rhofit(alat,avw,w(obas),bound,clabl,deltr,w(oemom),
. w(oiclas),w(oidn),ifmt3d,w(oirr),kfit,lmaxw,
. lmx,lmxrho,nbas,nclass,ndel,nl,nlrho,nrclas,
. nsp,origin,plat,rfout,rmaxs2,w(orwats),
. w(osigm2),wsr,z,zval)
! ------- Transform to the orthogonal representation
call ortrep(clabl,w(oidn),nclass,nl,nsp,w(opp),w(oqnu))
!-------- Shift enu to center of gravity and calculate new moments
!-------- and backup old qnu's and pnu's
call enutcg(avw,clabl,w(oevrl),w(oidmod),kap2,lmx,
. nclass,nl,nsp,w(opnu),w(opp),w(oqnu),wsr)
! ------- Mixing moments and pnu's
call mixpq(beta,switch(13),clabl,lmx,mmixpq,nclass,nl,nsp,
. w(opnu),w(opold),w(oqnu),w(oqold),rms2,wc)
call rlse(opold)
if (cquit.eq.'/home/rudra/Recursion/ASR/BAND_A') call fexit(0,' LM: Q=BAND encountered')
endif
call cpustp(cnit,f,f)
if (convrg.or.switch(17).or.switch(8)) goto 1
enddo
1 call cpustp('ITET',f,f)
! --- End of the self-consistency loop
if(convrg) call atompp1(avw,clabl,kap2,switch(6),lmx,
. switch(1),nclass,
if (convrg) write(lunit(1),302) rms2,dabs(detot)
emax=(idnint(ebmax*10)+1)*0.1d0
emin=(idnint(ebmin*10)-1)*0.1d0
301 format(/72('#')//'ITER',i3,' OUT OF',i3,': MAG MOM=',f12.8,
. 3x,'ETOT=',f17.8,/22x,'RMS DQ=',f12.8,
. 2x,'DETOT=',f17.8//72('#')/)
302 format(/' Jolly good show! You converged to rms DQ=',f10.8,
. /' Jolly good show! You converged to DETOT=',f10.8)
endif
enddo
call timres(clabl,nbas,nclass,nit)
! write(*,*) "IMHERE"
call fexit(0,prgnam)
End
[/cpp]
What I am tryong to do is make another variable name for each of the variable present here in the first half of the code, add them as a argument etc. like
[cpp]	d_ngen=ngen
d_nit=nit
d_nitat=nitat
d_niter=niter
d_ialpha=ialpha
[/cpp]
and so on and put these as argument on the subroutine!!
what I am confused is is there any other, better way of transfering this value, that are got updated at the end of the 1st subroutine to the second one as well as to the calling program?
jimdempseyatthecove
Roddur
1) You may be able to declare those arguments to the subroutine as pass by value instead of pass by reference.
subroutine foo(ngen, nit, nitat, niter, ...)
integer, value :: ngen, nit, nitat, niter, ...
2) Place all those arguments into a user defined type in your main subroutine. Then declare a second instance of that type and perform the copy of that type and then pass the reference to the subroutine
type yourContext
sequence
end type yourContext
type(yourContext) :: mine,nextLevel
! initialize mine for use in current subroutine
mine%ngen = ...
mine%nit = ...
!use mine in current subroutine
nextLevel = mine ! make copyfor next level
call yourNextLevel(nextLevel)
subroutine yourNextLevel(mine)
! ^^ use minehere
! declare the referenct to incomming context
! declare local copy for next level
type(yourContext) :: theirs
call yourNextLevel(nextLevel) ! could be recursive or other subroutine
Jim Dempsey
jimdempseyatthecove
You may need to declare an interface too
Jim
roddur
Dear Jim,
As your first option, I cannot do that because i have to pass many arrays as well!
I mean, how can I pass the arrays by argument?
TimP
Why not a module for the shared data?
roddur
Quoting - tim18
Ummm....I am not sure, but what in my mind for the module is that, if I use the module for declaring variables, it will reinitialize the variable every time. But my problem is I have to carry forth the value of the variables generated by the first part.
Is there any way to check via some compiler option which values are modified?
If there is only one code, I can do that using idb and print the value. But how here?
jimdempseyatthecove
Roddur,
Your original post indicated that you needed to make copies of the variables (as opposed to passing references to the variables).
Do you require copies of the arrays, or can the called subroutine simply use a reference to the array?
If reference for the array but copies for the scalars, then in
type yourType
sequence
integer : nat
real, pointer :: Array(:)
end type yourType
real :: someArray(5000)
type(yourType) :: mine, nextLevel
! do once
mine%Array => someArray
! your code can modifie either
someArray(I) = xxx
! or
mine%Array(I) = xxx
! update your level's copy of local data
mine%nat = n
! make copy of your level's data for next level
! note, this makes a copy of the pointer to Array and not the data of Array
nextLevel = mine
call yourSub(nextLevel)
subroutine yourSub(mine)
! and if this Level calls self or next level
type(yourType) :: nextLevel
Jim Dempsey
