Is the increase in the stack size requirement to call IMSL proportional to the array size?
If the stack size requirement varies with the array size then the problem may be due to one of to situations.
1) The IMSL is using stack temp variables that vary with the array size (bad coding on there part)
2) The array in your code is on the stack instead of in global context.
subroutine foo()
real :: fooArray(123456)
end subroutine foo
Depending on your option switches (and OpenMP) fooArray will either be on the stack or in a foo_private area off the stack.
Jim Dempsey
Hi Steve,
Thanks. The interesting thing is that f77 has no problem to call imsl with large arrays.
I remembered that there was a solution to overcome the problem. But I forgot it. Probably an interface is required...
Thanks a lot.
Minix
Please show the statement that makes the call. If you are using MSIE, use the SRC button to include it. If another browser, surround it in
andtags. Also show the declaration of the array.
Jugoslav
