stack overflow
Rob1
I have a segment of code, that has been running fine for a while.
I got a stack overflow error when run with large arrays.
Here is the code:
ALLOCATE(xa(na))
 xa = [x(1:n-1)-x(n), x, x(2:n)+x(n)]     <<<< Stack over flow on this line
In the stack overflow case, n=44836 and na=134506
If i cange the code to this it will run:
ALLOCATE(xa(na))
xa(:n-1) = x(:n-1)-x(n)
xa(n:2*n-1) = x
xa(2*n:3*n-2) = x(2:)+x(n)
Is the latter the preferable method?
Are the pieces in the brackets assembled on the stack, thus the stack overflow?
Should i increase the stack size?
thanks,
rob
TimP
Apparently, the array constructor creates a temporary copy of the array, as you mentioned. If you prefer the notation and don't mind the extra time spent, you should set a larger stack size, or set /heap-arrays.
Rob1
Thanks Tim. So if i increased the stack size, the code would run slower? I need the code to run as fast as possible, so i guess i'll stick with the new notation. Also, i'm getting the same error again in a call to another function and i can't figure this one out. //////////////////////////////////////////////// Here is the calling function: SUBROUTINE calcspline(y2, n,x,y,Dx1,Dxn,closeends) ! computes spline of a set of data !---------------------------------------------------------------------------------------------------------------------------------------------------- !-------------------------------------------------------------- begin common mod files -------------------------------------------------------------- USE OUTFILES !-------------------------------------------------------------- end common mod files -------------------------------------------------------------- !---------------------------------------------------------------------------------------------------------------------------------------------------- IMPLICIT NONE !---------------------------------------------------------------------------------------------------------------------------------------------------- !--------------------------------------------------------- begin define function parameters --------------------------------------------------------- INTEGER, INTENT(IN) :: n ! array length REAL*8, INTENT(IN), DIMENSION(n) :: x ! independent vector REAL*8, INTENT(IN), DIMENSION(n) :: y ! dependent vector REAL*8, INTENT(IN) :: Dx1 ! delta (dx) at first element (x(1)) REAL*8, INTENT(IN) :: Dxn ! delta (dx) at last element (x(n)) INTEGER, INTENT(IN) :: closeends ! 1 = closed - continuous loop; 2 = open ends REAL*8, INTENT(OUT), DIMENSION(n) :: y2 ! second derivative (d^2y/d^2x) y vector with respect to x vector !--------------------------------------------------------- end define function parameters --------------------------------------------------------- !---------------------------------------------------------------------------------------------------------------------------------------------------- !---------------------------------------------------------------------------------------------------------------------------------------------------- !---------------------------------------------------------- begin define local variables ---------------------------------------------------------- REAL*8 DyDx1 ! derivative (dy/dx) at first element (x(1)) REAL*8 DyDxn ! derivative (dy/dx) at last element (x(n)) INTEGER na ! appended array length REAL*8, ALLOCATABLE :: xa(:) ! independent vector with appendages on front and rear REAL*8, ALLOCATABLE :: ya(:) ! dependent vector with appendages on front and rear REAL*8, ALLOCATABLE :: y2a(:) ! second derivative (d^2y/d^2x) y vector with respect to x vector with appendages on front and rear !REAL*8 xa(3*n-2) ! independent vector with appendages on front and rear !REAL*8 ya(3*n-2) ! dependent vector with appendages on front and rear !REAL*8 y2a(3*n-2) ! second derivative (d^2y/d^2x) y vector with respect to x vector with appendages on front and rear !---------------------------------------------------------- end define local variables ---------------------------------------------------------- !---------------------------------------------------------------------------------------------------------------------------------------------------- DyDx1 = ( y(2)-y(n-1) )/Dx1 ! only for closed circuit! DyDxn = DyDx1 na = 3*n-2 ALLOCATE(xa(na)) ALLOCATE(ya(na)) ALLOCATE(y2a(na)) !xa = [x(1:n-1)-x(n), x, x(2:n)+x(n)] xa(:n-1) = x(:n-1)-x(n) xa(n:2*n-1) = x xa(2*n:3*n-2) = x(2:)+x(n) !ya = [y(:n-1), y, y(2:)] ya(:n-1) = y(:n-1) ya(n:2*n-1) = y ya(2*n:3*n-2) = y(2:) CALL spline(y2a, na,xa,ya,DyDx1,DyDxn) y2 = y2a(n:2*n) ! crop appendages DEALLOCATE(xa) DEALLOCATE(ya) DEALLOCATE(y2a) ENDSUBROUTINE calcspline //////////////////////////////////////////////////////////////////////////// Here is the called function: SUBROUTINE spline(y2, n,x,y,yp1,ypn) IMPLICIT NONE ! computes second derivative of interpolating function. ends have zero second derivative. !---------------------------------------------------------------------------------------------------------------------------------------------------- !--------------------------------------------------------- begin define function parameters --------------------------------------------------------- INTEGER, INTENT(IN) :: n ! array length REAL*8, INTENT(IN), DIMENSION(n) :: x ! independent vector REAL*8, INTENT(IN), DIMENSION(n) :: y ! dependent vector REAL*8, INTENT(IN) :: yp1 ! derivative (dy/dx) at first element (x(1)) REAL*8, INTENT(IN) :: ypn ! derivative (dy/dx) at last element (x(n)) REAL*8, INTENT(OUT), DIMENSION(n) :: y2 ! second derivative (d^2y/d^2x) y vector with respect to x vector !--------------------------------------------------------- end define function parameters --------------------------------------------------------- !---------------------------------------------------------------------------------------------------------------------------------------------------- !---------------------------------------------------------------------------------------------------------------------------------------------------- !---------------------------------------------------------- begin define local variables ---------------------------------------------------------- REAL*8 p REAL*8 qn REAL*8 sig REAL*8 un REAL*8 u(n) INTEGER i !---------------------------------------------------------- end define local variables ---------------------------------------------------------- !---------------------------------------------------------------------------------------------------------------------------------------------------- IF (n==0) THEN RETURN ENDIF IF (yp1 > 0.99D30) THEN y2(1) = 0.D0 u(1) = 0.D0 ELSE y2(1) = -0.5D0 u(1) = ( 3.D0/(x(2)-x(1)) ) * ( (y(2)-y(1))/(x(2)-x(1)) - yp1 ) !sig = (x(1)-x(n-1))/(x(2)-x(n-1)) !p = sig*y2(n-1) + 2.D0 !y2(1) = (sig-1.D0)/p !u(1) = ( 6.D0*( (y(2)-y(1))/(x(2)-x(1)) - (y(1)-y(n-1))/(x(1)-x(n-1)) )/(x(2)-x(n-1)) - sig*u(n-1) )/p ENDIF DO i=2,n-1 sig = (x(i)-x(i-1))/(x(i+1)-x(i-1)) p = sig*y2(i-1) + 2.D0 y2(i) = (sig-1.D0)/p u(i) = ( 6.D0*( (y(i+1)-y(i))/(x(i+1)-x(i)) - (y(i)-y(i-1))/(x(i)-x(i-1)) )/(x(i+1)-x(i-1)) - sig*u(i-1) )/p ENDDO IF (ypn > 0.99D30) THEN qn = 0.D0 un = 0.D0 ELSE qn = 0.5D0 un = ( 3.D0/(x(n)-x(n-1)) ) * ( ypn - (y(n)-y(n-1))/(x(n)-x(n-1)) ) ENDIF IF (n==1) THEN y2(n) = 0.D0 ELSE y2(n) = (un-qn*u(n-1))/(qn*y2(n-1)+1.D0) ENDIF DO i=n-1,1,-1 ! back substitution loop of tridiagnal algorithm y2(i) = y2(i)*y2(i+1)+u(i) ENDDO ENDSUBROUTINE spline ////////////////////////////////////////////////////////////////////////////// I get the same crash before the first execution line in subroutine spline (i break it at line 1, then it crashes when i "step over"). Am i not declaring the dummy arguments correctly in subroutine spline? thanks, rob
