-static crashes
pedro_gonnet
Hello all,
First off, I don't know if this is a problem in ifort... I have a program that compiles and runs just fine until I link it with the "-static" option. Then, instead of running, it does
(idb) run
Thread received signal SEGV
stopped at [ function cvtas_a_to_t(...) 0x811c4c4]
The cvtas_a_to_t function is called somewhere before the program actually starts executing. I was also not able to find any documentation on this function.
Has anyone seen this before or know what this is about?
Cheers and many thanks
Pedro
pedro_gonnet
Hello again.
The crashing function cvtas_a_to_t is linked-in from libifcoremt.a. I still have not been able to find any documentation on what this function does or where it was called.
Cheers
Pedro
The routine in question converts a text form of a floating point number to double precision floating point. It would typically be called as part of a formatted READ statement. As it is an internal part of the compiler library, you would not find documentation on it.
I would first recommend ensuring that you have the latest available ifort installed. If the problem persists, please report it to Intel Premier Support.
Message Edited by sblionel on 07-22-2004 08:14 AM
