29657 Discussions
strange behaviour from 64-bit integer
Alireza_Forghani
I'm seeing a strange behaviour from int64 integer. Following code:
    use iso_fortran_env
    implicit none
    integer (int64) :: i
    i=2**32-2
write (*,*) "i, btest (i,0)" , i, btest (i,0)
    write (*,*) "i, btest (i,31)" , i, btest (i,31)
    write (*,*) "i, btest (i,32)" , i, btest (i,32)
    write (*,*) "i, btest (i,33)" , i, btest (i,33)
    write (*,*) "huge (i)" , huge (i)
returns:
 i, btest (i,0)                    -2 F
 i, btest (i,31)                    -2 T
 i, btest (i,32)                    -2 T
 i, btest (i,33)                    -2 T
 huge (i)   9223372036854775807
which shows that it calculates 2^32-2 as -2. Whereas limit on int64 is  9223372036854775807 that is way bigger than 2^32!
Wonder if I'm doing something wrong!
IanH
The expression on the right hand side of the assignment to i is not using 64 bit integers.
Consider the difference between the print statements in the following:
  USE, INTRINSIC :: ISO_FORTRAN_ENV, ONLY: INT64
  IMPLICIT NONE
  PRINT *, 2**32-2
  PRINT *, 2_INT64**32-2
END
IanH
  IMPLICIT NONE
  PRINT *, 2**32-2
END
Alireza_Forghani
Thanks Ian. the problem is fixed!
