29417 Discussions
strange memory occupier of allocatable array in custom type in Fortran
Jovan_Z_
I wanna create an allocatable array in custom type as follows:
  1. type cell
  2.    integer(4) :: fn
  3.    integer(4), dimension(:), allocatable :: nd
  4. end type cell
  5. type(cell), dimension(:), allocatable :: elem
  6. allocate(elem(10000))
There is memory occupier ten times more than 10000*4 Bytes before allocating array nd, why?
I thought a custom type might not contains any uncertain array, and modified the code as follows:
  1. type cell
  2.    integer(4) :: fn
  3.    integer(4), pointer :: nd(:)
  4. end type cell
  7. do i=1,10000
  8.    elem(i)%nd=>cnode(j:j+7)
  9. end do
 where cnode is a target array. The same situation happens, i.g. the memory occupier is  ten times
more than (10000*4+10000*8*4), and why? What should I do to change this?
jimdempseyatthecove
You are allocating an array of cell, not an array of integer(4).
The => must have a pointer on the left side, yours has an allocatable array.
If you were to re-type nd as pointer, the cell would have
integer(4) for fn
+ and pointer with array descriptor (size varies depending on platform)
Jim Dempsey
Jovan_Z_
Yes, I found the pointer with array descriptor occupying memory tens of times more than 4 bytes, which was although announced as integer pointer.
integer(4) for fn
Jim Dempsey
jimdempseyatthecove
If your cell array is sparsely filled, and you have an interest in conserving memory then consider
type nd_t
end type nd_t
type cell
  integer(4) :: fn
  type(nd_t), pointer :: p_nd
end type cell
Caution, should your array be more than sparsely filled, then this will consume additional memory.
Jim Dempsey
Jovan_Z_
What if the cell array is fully filled? I use allocatable array to store all data I need without any blank array element.
For this situation, the large memory occupier of pointer is ievitable, right?
jimdempseyatthecove
You will note that I preface my suggestion with "If your cell array is sparsely filled". When not sparsely filled, you would not use the extra indirection. To determine the effectiveness of the indirection:
IA32:
    4 + 32 bytes per cell (1D array) + allocation bytes + heap header
vs
    4 + 4 bytes per cell +  32 bytes per cell having allocation  + heap header
Intel64
    4 + 64 bytes per cell (1D array) + allocation bytes + heap header
vs
    4 + 8 bytes per cell +  64 bytes per cell having allocation  + heap header
Potentially (rough approximation) when your percent of cells allocated falls below 85%, you'd save memory.
Alternative strategy:
You illustrated: elem(i)%nd=>cnode(j:j+7), if the target of the pointer is always a slice of cnode, then your user defined type could contain:
  a type field of number of bytes necessary for your list of types (1:4 bytes)
  a length field of  number of bytes necessary for your largest type (1:4 bytes)
  a starting index into cnode (2:4 bytes)
Each cell entry would then be between 4 and 12 bytes depending on your requirements.
Jim Dempsey
