strange syntax errors
j-simpson
I'm getting strange errors about the syntax of my code. The errors are copied below. As you can see, I tried using both ' and " and neither worked. Please help! I didn't get these errors with intel fortran for linux in other codes in which I had the exactsame lines written.
/lib/cpp -fpp -P -Dmpi=0 -Dsgi=0 -Dlinux=1 -Dibm=0 -Dmac_osx=0 ../source/kinds.F > kinds.F
/opt/intel/bin/ifort -CB -c -FR kinds.F
/lib/cpp -fpp -P -Dmpi=0 -Dsgi=0 -Dlinux=1 -Dibm=0 -Dmac_osx=0 ../source/grid_utilities.F > grid_utilities.F
/opt/intel/bin/ifort -CB -c -FR grid_utilities.F
/lib/cpp -fpp -P -Dmpi=0 -Dsgi=0 -Dlinux=1 -Dibm=0 -Dmac_osx=0 ../source/make_table.F > make_table.F
/opt/intel/bin/ifort -CB -c -FR make_table.F
fortcom: Error: make_table.F, line 35: Syntax error, found END-OF-STATEMENT when expecting one of: , )
FILE="../grid_centers/grid_centers_"
fortcom: Error: make_table.F, line 36: Unbalanced parentheses
FORM="FORMATTED",STATUS="OLD")
fortcom: Error: make_table.F, line 36: Syntax error, found ',' when expecting one of: ;
fortcom: Error: make_table.F, line 36: Syntax error, found ')' when expecting one of: ;
fortcom: Error: make_table.F, line 45: Syntax error, found END-OF-STATEMENT when expecting one of: , )
FILE='../grid_connections/connections_'
fortcom: Error: make_table.F, line 46: Unbalanced parentheses
FORM='FORMATTED',STATUS='OLD')
fortcom: Error: make_table.F, line 46: Syntax error, found ',' when expecting one of: ;
fortcom: Error: make_table.F, line 46: Syntax error, found ')' when expecting one of: ;
fortcom: Error: make_table.F, line 57: Syntax error, found END-OF-STATEMENT when expecting one of: , )
FILE='../grid_tables/tables_'
fortcom: Error: make_table.F, line 58: Unbalanced parentheses
FORM='FORMATTED',STATUS='UNKNOWN')
fortcom: Error: make_table.F, line 58: Syntax error, found ',' when expecting one of: ;
fortcom: Error: make_table.F, line 58: Syntax error, found ')' when expecting one of: ;
fortcom: Error: make_table.F, line 36: This name does not have a type, and must have an explicit type. [FORM]
fortcom: Error: make_table.F, line 36: This name does not have a type, and must have an explicit type. [STATUS]
compilation aborted for make_table.F (code 1)
make: *** [make_table.o] Error 1
Check line length. My guess is you've gone past column 72.
j-simpson
The line length is fine, especially since it is free form fortran.
Your files have the .F file type, which are interpreted as fixed-form after being run through fpp.
j-simpson
I get the same errors after I changed the .F to .F90 as shown below. It doesn't seem as though it could be an actual syntax issue, because the errors are occuring very early in the lines. (?)
/lib/cpp -fpp -P -Dmpi=0 -Dsgi=0 -Dlinux=1 -Dibm=0 -Dmac_osx=0 ../source/kinds.F90 > kinds.F90
/opt/intel/bin/ifort -CB -c -FR kinds.F90
/lib/cpp -fpp -P -Dmpi=0 -Dsgi=0 -Dlinux=1 -Dibm=0 -Dmac_osx=0 ../source/grid_utilities.F90 > grid_utilities.F90
/opt/intel/bin/ifort -CB -c -FR grid_utilities.F90
/lib/cpp -fpp -P -Dmpi=0 -Dsgi=0 -Dlinux=1 -Dibm=0 -Dmac_osx=0 ../source/make_table.F90 > make_table.F90
/opt/intel/bin/ifort -CB -c -FR make_table.F90
fortcom: Error: make_table.F90, line 34: Syntax error, found END-OF-STATEMENT when expecting one of: , )
OPEN (UNIT=17, FILE="../grid_centers/grid_centers_"
fortcom: Error: make_table.F90, line 35: Unbalanced parentheses
fortcom: Error: make_table.F90, line 35: Syntax error, found ',' when expecting one of: ;
fortcom: Error: make_table.F90, line 35: Syntax error, found ')' when expecting one of: ;
fortcom: Error: make_table.F90, line 44: Syntax error, found END-OF-STATEMENT when expecting one of: , )
fortcom: Error: make_table.F90, line 45: Unbalanced parentheses
fortcom: Error: make_table.F90, line 45: Syntax error, found ',' when expecting one of: ;
fortcom: Error: make_table.F90, line 45: Syntax error, found ')' when expecting one of: ;
fortcom: Error: make_table.F90, line 56: Syntax error, found END-OF-STATEMENT when expecting one of: , )
fortcom: Error: make_table.F90, line 57: Unbalanced parentheses
fortcom: Error: make_table.F90, line 57: Syntax error, found ',' when expecting one of: ;
fortcom: Error: make_table.F90, line 57: Syntax error, found ')' when expecting one of: ;
FOR M='FORMATTED',STATUS='UNKNOWN')
fortcom: Error: make_table.F90, line 35: This name does not have a type, and must have an explicit type. [FORM]
fortcom: Error: make_table.F90, line 35: This name does not have a type, and must have an explicit type. [STATUS]
compilation aborted for make_table.F90 (code 1)
The compiler itself doesn't recognize .F90, as far as I know. Make it .f90 and see what happens. fpp will process .F90 into a .f90 by default (I think - Linux is not my strong point), but it looks as if you are overriding that.
All the evidence I see points to a line length issue. If you can't solve the problem, file a support request with Intel Premier Support and attach a test case.
j-simpson
OK, thanks for your help!
