structure constructors: further problems
Ferdinand_T_
New Contributor II
inspired by the recent derived-type constructor issue (http://software.intel.com/en-us/forums/topic/375761), I decided to post some related example code which also behaves differently than I expected. I tested with ifort 13.0.1, and counterchecked with gfortran (gcc) 4.7.2.
EXAMPLE I: polymorphic components
  • set up structure constructor for a 'container', containing an other derived-type 'child' by reference
  • 'child' is polymorphic, and it's superclass may be empty
[fortran]
module m
    ! possibly empty superclass
    type :: super
       integer :: field    ! add a field (or not)
    end type
    type, extends(super) :: child
    end type
    ! reference container
    type :: container
       class(super), pointer :: ptr => null()
    end type
end module m
program p
    use m
    implicit none
    type(child), target :: myChild
    type(container) :: myContainer
    ! initialize the container with a reference to child
!-----ALTERNATIVE A--------
    ! direct pointer assignment
    myContainer%ptr => myChild
    ! ifort:    output "T"
    ! gfortran: output "T"
!-----ALTERNATIVE B--------
    ! structure constructor
    myContainer = container(myChild)
    ! ifort:    compiler-error #6795
    !           "The target must be of the same type and kind
    !            type parameters as the pointer    [MYCHILD]"
    ! gfortran: compiler-error
    !           "Can't convert TYPE(child) to CLASS(super)"
!-----ALTERNATIVE C--------
    ! structure constructor wich matches the declared type
    class(super), pointer :: super_ptr
    super_ptr => myChild                 ! cast to superclass
    myContainer = container(super_ptr)
    ! ifort:    if super has NO data fields:          output "F"
    !           if super has at least one data field: output "T"
    ! gfortran: (both cases) output "T"
    ! check initialization, output "T" expected
    print *, associated(myContainer%ptr)
end program
[/fortran]
Remarks:
  • ALTERNATIVE A: This is what I want to do with structure constructors.
  • ALTERNATIVE B: The structure constructor assignment fails, even if a direct pointer assignment is allowed.
    The intel reference pages told me that "If a component of the derived type is a pointer, the value in the expression list must evaluate to an object that would be a valid target in a pointer assignment statement. (A constant is not a valid target in a pointer assignment statement.)". It also sais, that "If necessary, values are converted (according to the rules of assignment), to agree with their corresponding components in type and kind parameters.", so I thought the structure construcor should workd here (but both ifort and gfortran complained)
    http://software.intel.com/sites/products/documentation/doclib/stdxe/2013/composerxe/compiler/fortran-mac/GUID-6521CC96-2A0E-4CE0-8036-3238F7476C34.htm
  • ALTERNATIVE C: Strangely, it seems to make a difference if the superclass "super" has fields or not. (it doesn't help here to add type-bound procedures). This problem with empty types is also adressed in EXAMPLE II
EXAMPLE II: empty derived type
  • now, the containedderived-type is non-polymorphic and may be empty
[fortran]
module m
    ! empty derived type
    type :: empty
    !   integer :: field    ! add a field (or not)
    end type
    type :: container
       type(empty), pointer :: ptr => null()
    end type
end module m
program p
    use m
    implicit none
    type(empty), target :: myEmpty
    ! initialize the container with a reference to empty
    myContainer = container(myEmpty)
    ! check initialization (output "T" expected)
    ! results:
    ! ifort:    if super_type has NO data fields:          output "F"
    !           if super_type has at least one data field: output "T"
end program
[/fortran]
Remarks:
  • Now, the structure constructor works fine (no polymorphism any more), unless the "empty" type is indeed empty (that was a known issue in ifort 11, but still in 13?)
Thanks for comments and in the hope this may be useful,
Ferdinand
Steven_L_Intel1
Both of these problems are fixed in a release later this year.
Ferdinand_T_
New Contributor II
Glad to hear that!
The second problem is not related to structure constructors, as association of pointers to empty types seems to be a more general issue.
Regards, Ferdinand
Ferdinand_T_
New Contributor II
Hello Steve,
a quick check with the latest ifort 2013 sp1 (version 14.0.0) solved almost all of my fortran 2003 problems!
However, with the exception of EXAMPLE I ALTERNATIVE B, where the upcasting in the structure constructor still fails with the same error message. Of course this is only a minor issue, but since I started to clear my code from all those 'pre-14.0 release workarounds', I just wondered about this one.
Thank you, with best regards
Ferdinand
Steven_L_Intel1
I agree that the structure constructor here should be allowed. I have escalated this as issue DPD200248768.
Ferdinand_T_
New Contributor II
Just noticed that version 14.0.1 doesn't support empty derived types completely yet, is that true?
(didn't find it in the release notes)
Example:
[fortran]
type :: empty_type
    !integer :: nonempty          ! uncomment to get expected behaviour
end type
type(empty_type) :: rhs
type(empty_type), allocatable :: dynamic_lhs
! works but should'nt:
dynamic_lhs = empty_type()
print *, allocated(dynamic_lhs)   ! output 'F'
! fails but shouldn't:
allocate(dynamic_lhs)
rhs = dynamic_lhs                 ! output: segm. fault
end
[/fortran]
Ferdinand
Steven_L_Intel1
We believe we support empty types completely. I do recall a known issue with ASSOCIATED for an allocated empty type - I'll check on its status tomorrow. It's probably connected with the second allocate succeeding when it shouldn't. FWIW, you need to compile this source with -standard-semantics to get dynamic_lhs allocated on the assignment.
