29487 Discussions
the array .... has value ... which is less than the lower bound of .....
hana_K_
Hi
I wrote my program in Fortran 90 and complied it successfully, but when I run it this error was appeared.
the array ENERGY has value -3689348814741910323 which is less than the lower bound of 1.
Does someone have an idea about this problem?
My code is something like this:
SUBROUTINE A (energy,....)
DOUBLE PRECISION, POINTER, DIMENSION(:,:), INTENT(IN) ::energy
END SUBROUTINE A
DOUBLE PRECISION FUNCTION B(x,addMember)
CALL A(energy,...)
DOUBLE PRECISION, POINTER, DIMENSION(:,:) :: energy
ALLOCATE (energy(....))
DEALLOCATE (energy)
END FUNCTION B
SUBROUTINE C(energy,....)
END SUNROUTINE C
DOUBLE PRECISION FUNCTION D(.....)
CALL A(energy,...)
DEALLOCATE(energy)
END FUNCTION D
many thanks in advanced
Hana
TimP
It looks as if you are calling the subroutine with the array argument before allocating it, so your result seems unsurprising.
Lorri_M_Intel
These routines all contained deferred shape arguments, which means that an interface must be available at the call site.
I appreciate that this is just truncated code, but none of the subroutines here have any knowledge that the routine they're calling is expecting a deferred shape argument.   Make sure your actual code is correct.
                   --Lorri
mecej4
There are a couple of sobering conclusions to be drawn from this thread:
  • If an explicit interface is not provided when one is needed, the runtime error messages may say very misleading things. If a user reports only these errors without showing the complete  sources (or at least the relevant parts thereof), any cure that may be suggested is likely to make the headache worse.
  • If you are going to use assumed shape arrays, optional arguments, etc., consider using a self-imposed rule to place subprograms using these features into modules and USE the modules in the callers. It would be a good idea to forswear using implicit typing when you have such subprograms in a project.
hana_K_
Thank you, but as you see I allocate my argumment, just the INTENT(IN) and INTENT(OUT) argument.
hana_K_
Thank you.
This is a part of my code. and this part comes in aMODULE which I call  this MODULE and others in my main program also I used IMPLICT NONE in my code.
Casey
hana K. wrote:
Presumably what Tim is referring to is you inconsitancy in allocating energy.  For example, subroutine A declares energy as intent in, but we do not know what it does, so we infer from the other procedures.  Subroutine B calls A, then allocates energy.  Subroutine D allocates energy, then calls A. At then end of both B and D, energy is deallocated.  From what code we can see, the only inferences that can be made are that when A is called, energy may either be allocated or not.  When B or D are called, energy is unallocated upon exit.  With only that information I have to agree with Tim's statement.   Posting a complete code example would allow for more helpful feedback to be provided.
