the local variable is auto save ?
史_建鑫
I have a sub in a module. the sub have a local variable. the first time the main program call the sub, I initiate the local variable. then I call the sub the second time without initiation, but the local variable value remain the same.
[fortran]
module testmod
    implicit none
    type :: testtype
        integer :: i
    end type testtype
contains
    subroutine foo(switch)
        logical, intent(in) :: switch
        type(testtype) :: t
        integer :: m
        if(switch==.TRUE.) then
            t%i = 10
            m = 23
        end if
        write(*,*) t%i, m
    end subroutine foo
end module testmod
[/fortran]
[fortran]
program main
    use testmod
    implicit none
    integer :: i
    call foo(.TRUE.)
    call foo(.FALSE.)
end program main
[/fortran]
I didn't turn on the /Qsave. I want to know is this feature just a compiler hidden rule and I should not rely on it?
thank you !!
Here it is just coincidence that the same memory address was used and that nothing had written to that address in between calls. Don't depend on this. If you want to test this, put a PRINT statement between the calls. You'll find that m now has a different value. t%i may be the same because by default the compiler uses static storage for derived type variables, but this still doesn't make it SAVE.
TimP
Can we assume that RECURSIVE or compilation options implying /Qauto would change away from static storage?
As Steve said, it is possible that the data remain visible between calls if no intervening function call uses the space, but that's an inadequately predicable side effect.
Yes, RECURSIVE or /Qauto (or /Qopenmp) will change this default.
