29651 Discussions
three IMSL Fortran Library 6.0 installed
Intel_C_Intel
Hi
I've checked from Control Panel->Add&DeleteProgram(I guess from my Chinese Windows XP) and find I have three IMSL Fortran Library 6.0 installed (all in same size and used on 2008/8/1). Why there are three exactly the same, I guess, versions?
Thank you.
Chien-Hui
This can happen if you installed the IA-32, Intel 64 and IA-64 versions of IMSL. It shows up that way in Add/Remove Programs.
Intel_C_Intel
So do I need to install all of them? Windows XP of my pc is for IA-32.
Before I read your reply, I remove all three of them in Add/Remove Programs. I thought they are duplicated, since they didn't show versions. I download IMSL version forIA-32 from registrationcenter. However, I failed to install after I click Next. It shows a dialogbox showing usually in some problem about a software and the bottom of the box has Debug(B), ReportThisProblem(S) and NoReport(D) (to Microsoft).
What happens now?
Thank you for your reply.
Chien-Hui
No, you need only the IA-32 version.
The error message you are seeing is very general and comes from Windows - I have not seen this error when installing IMSL. Please reboot the PC and try again. If you need more help, contact Intel Premier Support.
Intel_C_Intel
I've already reboot twice and the same error message appears.
Chien-Hui
Try downloading another copy.
