29657 Discussions
trouble converting compaq visual fortran code
robberman
I'm just getting started trying to upgrade from compaq vf v. 6.1 and having problems
At first I tried using the Visual Studio 2010, then saw that I might need to use 2008 version, so have tried (unsuccessfully) with Visual Studio 2008 C++ Express Edition.
Any suggestions? Is there a place I can download some information on what version of Visual studio I need, etc. to get started, and then how to most easily compile and run fortran code?
Thanks!!
Rob
Have you purchased Intel Visual Fortran or are you using an evaluation copy? If you purchased, it includes the necessary Visual Studio bits (from VS2008). You can also use a trial copy of Visual Studio 2010 if you have the evaluation, since the evaluation version does not include the VS bits. You cannot use "Express Edition" installs for this.
TimP
ReleaseNotes.pdf in ifort distribution documentation folder has most of this information. VS Express would work only for limited command line mode usage of only the ia32 (32-bit compiler), and would require you to set the -Qlocation,link option (e.g. in ifort.cfg).
robberman
Thanks. I have purchased Vis Fortran, so it sounds like I should remove the Vis Studio versions I installed as you're saying it will run on its own. It's a bit confusing because when I downloaded Vis Fortran all the options said something about requiring Vis Studio to run.
If you already have a supported version of Visual Studio installed (not an "Express Edition"), leave it. For people who do not have a supported Visual Studio, we provide a Fortran development environment based on VS2008 that is installed when you download and install the "full" package.
