29386 Discussions
troubles with io: nested dt descriptor
ericcp_dias_ie
I am writing a code in which I need to use a derived data type that include another derived data type.
I've been able to follow the examples tu use the DT descriptor for user defined io within the first one, but in the second one I get an error from the compiler, namely
model.f90: error #8638: The type/rank signature for arguments of this specific subroutine is identical to another specific subroutine that shares the same defined I/O.   [UDIO_WRITE_NODE]
model.f90: error #8638: The type/rank signature for arguments of this specific subroutine is identical to another specific subroutine that shares the same defined I/O.   [UDIO_WRITE_MODEL]
model.f90: error #8638: The type/rank signature for arguments of this specific subroutine is identical to another specific subroutine that shares the same defined I/O.   [UDIO_READ_NODE]
compilation aborted for model.f90 (code 1)
I have to admit that I simply nested the two io procedures.
The inner derived data type works finely
module myNode
  implicit none
  type node
     logical :: isIsotropic
     real    :: depth
     real    :: sigmaMean
     real    :: sigmaRatio
     real    :: betaS
  end type node
  interface write(formatted)
     module procedure udio_write_node
  end interface write(formatted)
  interface read(formatted)
     module procedure udio_read_node
  end interface read(formatted)
contains
  subroutine udio_read_node(dtv, unit, iotype, v_list, iostat, iomsg)
    !        ifort note: to enable reading int as logical the code must be compiled with the flag
    !        -assume old_logical_ldio
    class(node), intent(inout)  :: dtv
    integer, intent(in)         :: unit
    character(*), intent(in)    :: iotype
    integer, intent(in)         :: v_list(:)
    integer, intent(out)        :: iostat
    character(*), intent(inout) :: iomsg
    read(unit,fmt=*,iostat=iostat,iomsg=iomsg) dtv%isIsotropic, dtv%depth, dtv%sigmamean, dtv%sigmaratio, dtv%betas
  end subroutine udio_read_node
  subroutine udio_write_node(dtv, unit, iotype, v_list, iostat, iomsg)
    class(node), intent(in)     :: dtv
    if(dtv%isIsotropic)then
       write(unit, fmt=*, iostat=iostat, iomsg=iomsg) 1, dtv%depth, dtv%sigmamean, dtv%sigmaratio, dtv%betas
    else
       write(unit, fmt=*, iostat=iostat, iomsg=iomsg) 0, dtv%depth, dtv%sigmamean, dtv%sigmaratio, dtv%betas
    end if
  end subroutine udio_write_node
end module myNode
program test1
  use myNode
  implicit none
  integer :: i
  type(node),dimension(4) :: n
!!$  do i = 1,4
!!$     n(i)%isIsotropic = .true.
!!$     n(i)%depth = real(i)*1.1
!!$     n(i)%sigmamean = real(i) * 0.5
!!$     n(i)%sigmaratio = real(i) * 1.0
!!$     n(i)%betas = real(i) * 15.0
!!$  end do
  open(1,file='iotest.txt',form='formatted',recl=2048)
  read(1,"(4(dt))") n
  close(1)
  do i = 1,4
     write(*,"(dt)") n(i)
  end do
end program test1
but when I try to use the same with another type that contains an array of type(node) i get the compilation error.
module model
  use mynode
  implicit none
  integer, private, parameter :: kmax = 32
  type model
     integer :: k     = 1
     real    :: logL  = 0.
     real    :: logPr = 0.
     real    :: h_par = 1.
     type(node), dimension (kmax) :: par
  end type model
     module procedure udio_write_model
     module procedure udio_read_model
contains
  subroutine udio_read_model(dtvv, unit, iotype, v_list, iostat, iomsg)
    class(model), intent(inout)    :: dtvv
    read(unit,fmt=*,iostat=iostat,iomsg=iomsg) dtvv%k, dtvv%logL, dtvv%logPr, dtvv%h_par, dtvv%par(1:dtvv%k)
  end subroutine udio_read_model
subroutine udio_write_model(dtv, unit, iotype, v_list, iostat, iomsg)
    class(model), intent(in)    :: dtv
    write(unit, fmt=*, iostat=iostat, iomsg=iomsg) dtv%k, dtv%logL, dtv%logPr, dtv%h_par, dtv%par(1:dtv%k)
  end subroutine udio_write_model
end module model
program test1
  use mtmodel
  use mynode
  implicit none
  type(model) :: m
  integer :: i
  read(1,"(dt)") m
  close(1)
  write(*,"(dt)") m
  do i = 1,4
     write(*,"(dt)") m%par(i)
  end do
end program test1
What's the proper way to chain the user defined io procedure?
Thanks in advance for any help.
Eric
Lorri_M_Intel
I believe that your code is correct, but apparently, the compiler is getting confused by the interface declarations.
I changed the type declarations to have type-bound procedures instead, and removed the generic interfaces, and the program compiled.
More specifically, I changed the declaration of node to:
  type node
     real    :: depth
     real    :: sigmaMean
     real    :: sigmaRatio
     real    :: betaS
  contains
     procedure :: udio_read_node
     procedure :: udio_write_node
     generic   :: write(formatted) => udio_write_node
     generic   :: read(formatted) => udio_read_node
  end type node
Similar edit for type model.
            I hope this helps -
                            --Lorri
I have escalated this as issue DPD200411713. I also note that the error messages lack "locator" information to tell you where in the source file the error (allegedly) occurred.
ericcp_dias_ie
Even modifying the code I still get runtime errors.
As workaround, there is a simple way to overload read a write?
Please show a complete test case with the modified code.
ericcp_dias_ie
The node.f90 module stays the same
module myNode
  implicit none
  type node
     real    :: depth
     real    :: sigmaMean
     real    :: sigmaRatio
     real    :: betaS
   contains
  end type node
!!$  interface write(formatted)
!!$     module procedure udio_write_node
!!$  end interface write(formatted)
!!$  interface read(formatted)
!!$     module procedure udio_read_node
!!$  end interface read(formatted)
contains
    else
    end if
end module myNode
and works as before.
If I try to nest the node structure into another one I get
forrtl: severe (105): there is no data-edit-descriptor to match a data-item in the I/O list, unit 1, file /Users/eric/Src/greenTDMT/iotest_write.txt
Image              PC                Routine            Line        Source
test               0000000104292E5C  Unknown               Unknown  Unknown
test               00000001042BE122  Unknown               Unknown  Unknown
test               000000010427C00E  Unknown               Unknown  Unknown
test               000000010427BB7E  Unknown               Unknown  Unknown
explicitly I try to read/write na array of nodes and a bunch of other parameters
module mtmodel
  use mynode
  implicit none
  type model
     integer :: k     = 1
     real    :: logL  = 0.
     real    :: logPr = 0.
     real    :: h_par = 1.
   contains
     procedure :: udio_read_model
     procedure :: udio_write_model
     generic   :: read(formatted)  => udio_read_model
     generic   :: write(formatted) => udio_write_model
  end type model
!!$     module procedure udio_read_model
!!$     module procedure udio_write_model
contains
  subroutine udio_read_model(dtv, unit, iotype, v_list, iostat, iomsg)
    read(unit,fmt=*,iostat=iostat,iomsg=iomsg) dtv%k, dtv%logL, dtv%logPr, dtv%h_par, dtv%par(1:dtv%k)
!!$  function forward(m,period) result(z)
!!$    implicit none
!!$    type(model), intent(in) :: m
!!$    real, intent(in)        :: period
!!$    complex, dimension(2,2) :: z
!!$    call z1anis()
end module mtmodel
program test1
  use mtmodel
  use mynode, only : node
  implicit none
  type(model) :: m
  type(node), dimension(4)  :: n
  integer :: i
  do i = 1,4
  end do
  m%par(1:4) = n
  open(1,file='iotest_write.txt',form='formatted',recl=2048)
  write(1,113) m
  close(1)
!  write(*,113) m
!!$  do i = 1,4
!!$     write(*,"(dt)") m%par(i)
!!$  end do
113 format(dt)
end program test1
I think that the problem could be that I use the * descriptor in both the node and model i/o subroutine, but I am not sure about that.
