29390 Discussions
troubleshooting user subroutine with abaqus 6.10
m_b_
Hi Dear,
Im trying to implement subroutine umat(user defined code is written in 2006- not sure which version of abaqus is used?! ) and run a job.However, i,m getting this error through  abaqus cae and cmd (attached file),i was wondering if you could help me out?i,m using abaqus 6.10 -VS2008-IVF 11 AND successfully run some examples from abaqus verification.i also can send my fortran file ( .for) and input abaqus file for more clarification if you require.
is it possible that mismatching abaqus version cause this kinda error?i mean running a subroutine(written code in 06) is it sensetive to abaqus versions(6.10)?
any help really apreciated.
ERROr on cae :
The executable J:\SIMULIA\Abaqus\6.10-1\exec\standard.exe aborted with system error code 144. Please check the .dat, .msg, and .sta files for error messages if the files exist.  If there are no error messages and you cannot resolve the problem, please run the command "abaqus job=support information=support" to report and save your system information.  Use the same command to run Abaqus that you used when the problem occurred.  Please contact your local Abaqus support office and send them the input file, the file support.log which you just created, the executable name, and the error code.
With regards,
Milad
Greg_T_
Valued Contributor I
Hi Milad,
Check the "Abaqus User Subroutines Reference Guide" in the Abaqus documentation to confirm the UMAT subroutine arguments for the version of Abaqus you are using.  The arguments in the subroutine statement can occasionally change for different versions of Abaqus, and then a previously written user subroutine can have run time errors.
I recommend writing a "main" program to test your UMAT separately from Abaqus to confirm that the subroutine runs correctly.  Write a main program that provides all the inputs to the user subroutine, and even vary the input values to test that the subroutine does not have run time errors.
Run the Abaqus job from the command line instead of from within Abaqus/CAE as that should show you information about the compiling and linking that Abaqus is doing.  Perhaps there will be error messages indicating if the compiling or linking was unsuccessful.  Try running the Abaqus analysis from the Intel Fortran initialized console (CMD) window, which you can open from the Start button.  I have had good success using that Fortran CMD window to run Abaqus with user subroutines.  Depending on your version of Fortran, the location in the Start menu would be something like:
Start -> Intel Parallel Studio XE 2015 -> Compiler and Performance Libraries -> Command Prompt with Intel Compiler -> Intel 64 Visual Studio 2013 mode
To determine if the Abaqus job is crashing immediately, or actually getting in to the user subroutine, you can write debugging information from the user subroutine to the Abaqus message file (*.msg) using file unit = 7 (for Abaqus/Standard) using write() statements.  You could write the passed input values and intermediate values from the subroutine to the message file to determine if data or a calculation is causing a run time error.  Then look in the *.msg file for your debugging information; assuming the .msg file is created by Abaqus.  Refer to the "Abaqus Analysis User's Guide" in section 3.7.1 "Fortran unit numbers used by Abaqus" and there is a list of the file unit numbers you can use for output.  You could take the input values from the Abaqus message file and use them in your main program to further test the user subroutine.
Greg Thorwald
mecej4
A Web search shows that the code-144 message is from the Abaqus EXE, and is probably an indication that your user routine experienced a floating-point error (e.g., floating division by zero, sqrt(neg. arg), etc.). Apparently, Abaqus hooks up its own FPU error handler to service FPU exceptions.
You may attempt to examine your code and narrow down the part of it that cause the FPU exception. Otherwise, try an Abaqus user forum.
Greg_T_
Hi Milad,
Greg Thorwald
m_b_
Hi guys,thanks for your helpful replies,
Mr.Greg Thorwald : i,m using abaqus 6.10 -VS2008-intel composer XE 11,i also attached the error running the job through  cmd line,it appears in compiling stage,so do u think thts coming probably from a compiling error?! besides when i complie the code in fortran without linking to abaqus im getting these errors:
 1.error LNK2019: unresolved external symbol _MAIN__ referenced in function _main    libifcoremt.lib(for_main.obj)
2. fatal error LNK1120: 1 unresolved externals    Debug\Console5.exe
 i've checked the .msg and .dat from abaqus output but unfortunately couldnt get anything.
im gonna try  CMD window to run Abaqus with user subroutines
mecej4
You probably overlooked the fact that you need to write a Fortran main program that calls the DLL routine, and compile it and link to the import library of the DLL.
It is far more useful to have console output and program output presented/attached as text rather than as an image.
The image file err1.png appears to be the same as the one in #1, and the text in it does not match the description in #4.
m_b_
thanks for ur guidance,im very new to fortran coding,(havent written the code,just try to run it  and apply it to more complex model),thts the code(.for) :(the attached file is the ouput of  abaqus after linking-job aborted).
c ******************************************************************************************* C
C        C
C                                 ABAQUS  UMAT--EYEVP.FOR           C
C        C
C        C
C        C
C        C
C        C                                               C
C        C
C        C
C        FINAL UPDATE: DECEMBER,2004                            C
C        C
C  NOTES:        C
C          THIS CODE CAN ONLY BE USED FOR PLANE STRAN AND AXISYMETRIC PROBLEM!                C
C        C
C  ACDEMIC NOTES:        C
C     1. NO YIELD CONDITION IS USED TO JUDGE INITIAL YIELD       (1-NON)                      C
C     2. No HARDENING RULES ARE USED TO COMPUTE PK0, WHICK IS COMPUTED FROM P AND Q (2-NON)   C
C ******************************************************************************************* C
C   NOTES:        C
C         1 STATE VARIBLES ARE DEFINED IN THIS UMAT                                           C                                                               C
C    1.VOLUMETRIC STRAIN;        C        C
C   IMPORTANT ABAQUS CONVENTION:                                                              C
C    1. HYDROSTATIC STRESS P=(-1/3)(SUM(STRESS));                                             C
C    2. TRY TO ENSURE FEW TRICKS AS POSSIBLE IN CODES                                         C
     SUBROUTINE UMAT(STRESS,STATEV,DDSDDE,SSE,SPD,SCD,
     1 RPL,DDSDDT,DRPLDE,DRPLDT,STRAN,DSTRAN,TIME,DTIME,
    2 TEMP,DTEMP,PREDEF,DPREF,DPRED,MATERL,NDI,NSHR,NTENS,
    3 NSTATV,PROPS,NPROPS,COORDS,DROT,PNEWDT,CELENT,DFGRD0,
    4 DFGRD1,NOEL,NPT,LAYER,KSPT,KSTEP,KINC)
C
       IMPLICIT REAL*8 (A-H,O-Z)
C
       CHARACTER*8 CMNAME
       DIMENSION STRESS(NTENS),STATEV(NSTATV),DDSDDE(NTENS,NTENS),
     1 DDSDDT(NTENS),DRPLDE(NTENS),STRAN(NTENS),DSTRAN(NTENS),
    2 TIME(2),PREDEF(1),DPRED(1),PROPS(NPROPS),COORDS(3),DROT(3,3),
    3 DFGRDO(3,3),DFGRD1(3,3)
C*******************************************************************************************************C
C    DEFINITE THE CONSTANT PARAMETER IN EVP MODEL;ELASTIC AND VISCO-PLASTIC COMPONENTS                  C        *
C    ELASTIC PARAMETERS KAPAV THE RATIO BETWEEN REBOUND MODULUS AND SPECIFIC VOLUMN;ENU POSSION'S RATIO C
C                             P0--INITIAL MEAN STRESS FOR INITIAL VOLUMETRIC STRAIN                     C
C                             (CALCULATED BASED ON THE INITIAL STRESS CONDITIONS,INPUT VALUE)           C
C    CREEP COMPRESSION  PESAV  THE RATIO BETWEEN CREEP PARAMETER(PESA) AND SPECIFIC VOLUMN              C
C                       T0     INITIAL TIME FOR CREEP STARTING                                          C
C    REFERENCE LINE DEFINITION NAMDV  THE RATIO BETWEEN COMPRESSION MODULUS AND SPECIFIC VOLUMN         C
C                              PK00    INTERCEPT HYPOSTATIC PRESSURE (MEAN STRESS) INPUT VALUE          C
C                              EEPVMO INITIAL ELASTOPLASTIC STRAIN                                      C
C    CRITICAL STATE LINE       M      THE SLOPE OF THE CRITIAL STATE LINE (COMPUTED FROM ANGLE(AFA))    C
C                              PHI    EFFECTIVE INTERNAL FRICTION ANGLE(DG)                             C
C                              PK0     A STATE VARIABLE,CAOMPUTED FROM FLOW SURFACE                     C
C              (INITIAL VALUE WHICH CAN BE COMPUTED FROM FROM INITIAL STRESS STATES)                    C
C                              KK0     LATERAL PRESSURE COEFFICIENT                                     C
C                              EVKL   LIMIT VISCOPLASTIC STRAIN (INPUT)                                 C
C                              BETA   PARAMETER DETERMING TYPE OF ALORITHM                              C
C    DIFFERENT BETA CORRESPONDS TO DIFFERENT INTEGRATION ALGORITHM:                                     C
C                              (BETA=1 BACKWARD EULER INTEGRATION) (BETA=0 FORWARD EULER INTEGRATION)   C
C            TEST-TESTING CONDITION WHICH MEANS THE CHOICE OF M (INCLINATION OF CRITIAL STATE LINE)     C
C ******************************************************************************************************C
C                         +++++++++ MAIN PROGRAM +++++++++++++                                          C
C  THE WHOLE PROCESS IS DEVIDED INTO TWO STAGES: DIRECT ALGORITHM (NO ITERATION)                        C
C  THE PREESS-DEPENDENT ELASTIC BEHAVIOR IS USED IN THE ALGORITHM FOR SIMPLICITY                        C
C                          MAIN PROGRAM
C
C        DEFINITED VARIABLES USED IN MAIN PROGRAM
C
      DIMENSION STRANT(4),DET(4),DSTRESS(4),DD1(4,4),DSTRESSN(4)
    DIMENSION SIGMT(4),DD(4,4),DSIGM(NTENS),SIGM(NTENS),ETOTAL(4)
    DIMENSION DEDSN(4,4),DFDSN(4),DD2N(4,4),EELAS(4),EVPR(4)
C
      DOUBLE PRECISION KAPAV,NAMDV,T0,ENU,PESAV,EEPVM0,SIGM,EVK0
    DOUBLE PRECISION EVKL,PHI,PM0,BETA,AFA,M,SIGMT,KE,KG,DP
    DOUBLE PRECISION DSIGM,DD,F,P,Q,PN,AG,KKK,PNON,D1,D2,D4
    DOUBLE PRECISION PP,QQ,PPK,AA,BB,AA1,B,AA2,EVT,DEVT,EVTT
    DOUBLE PRECISION DEVPR(4),EVPN(4),SIGMN(4),DESN(4,4),DEVP(4)
    DOUBLE PRECISION DQDS(4),DPKDS(4),DQ,DPK,EVTN
    DOUBLE PRECISION DFP,ESP,ESQ,ESEV,DEVPS,EVPSR,ESHER,DESHER
C
      PARAMETER (PI=3.1415926)
C
C        PARAMETERS DEFINITION FOR SUBROUTINES
C
      DIMENSION DEE(4),STS(4),DFDS(4),STS1(4),EVPRN(4)
      DIMENSION STS2(4),EV2(4),DFSS1(4),DFSS2(4),DFSS3(4),DSTS(4)
    DIMENSION DC(4,4),GES(4,4),DEDS(4,4),DES(4,4)
    DIMENSION A(4,4),HN(4,4),DD2(4,4),DD0(4,4),DE(4,4),DD20(4,4)
C
    DOUBLE PRECISION P1,QI,PM1,PESAV2,P02,E0,EL,DTIME2
      DOUBLE PRECISION PM2,A2,B2,E1,E11,E12,KK2,BETA2
C
      INTEGER K,K1,K2,I,J,NMAX
C
C       TOTALLY 11 CONSTANTS NPROPS=12
C
     KAPAV=PROPS(1)
     ENU=PROPS(2)
       PK00=PROPS(3)
     PESAV=PROPS(4)
     NAMDV=PROPS(5)
       T0=PROPS(6)
     EEPVM0=PROPS(7)
     PHI=PROPS(8)
     KKK=PROPS(9)
     EVKL=PROPS(10)
     BETA=PROPS(11)
     TEST=PROPS(12)
C
C      DEFINITE THE TYPE OF PROBLEM
C
     IF(NDI.NE.3) THEN
     WRITE(6,1)
1      FORMAT(//,30X,'***ERROR-THIS UMAT MAY ONLY BE USED FOR ***',
     1          'ELEMENTS WITH THREE DIRECT STRESS COMPONENTS')
     ENDIF
C
C         CALCULATE PARAMETER--AFA AND M FROM K0 AND PHI
C
        AFA=3.0*(1.0-KKK)/(1.0+2.0*KKK)
C
      AG=PI/180.0*PHI
C
C      CHOSE THE CORRESPONDING M FOR CRITIAL STATE LINE(FAILURE LINE)
C
        IF(TEST.EQ.1) M=6.0*(SIN(AG))/(3.0-SIN(AG))
      IF(TEST.EQ.2) M=6.0*(SIN(AG))/(3.0+SIN(AG))
C
        IF(ENU.GT.0.4999.AND.ENU.LT.0.5001) ENU=0.499
C       DEFINITE THE VOLUMETRIC STRAIN AND TOTAL STRAIN:EVT AND STRANT
C       EV-VOLUMETRIC STRAIN; DEV-INCREMENT OF VOLUMETRIC STRAIN
C
         EVT=0.0
        DO K1=1,NDI
           EVT=EVT+STRAN(K1)
       ENDDO
C
         EVT=STATEV(1)
C
C        COMPUTE P AND Q IN THE CURRENT N STEP
C
         P=(-1.0)*(STRESS(1)+STRESS(2)+STRESS(3))/3.0
       Q=(STRESS(1)-STRESS(2))*(STRESS(1)-STRESS(2))+
    1     (STRESS(1)-STRESS(3))*(STRESS(1)-STRESS(3))+
     2     (STRESS(3)-STRESS(2))*(STRESS(3)-STRESS(2))
C
       DO K1=NDI+1,NTENS
          Q=Q+6.0*STRESS(K1)*STRESS(K1)
       ENDDO
            Q=SQRT(Q/2.0)+1.0E-25
C
C       REDUCE THE TIME INCREMENT FOR THE GEOSTATIC STEP TO ENSURE ZERO
C       INITIAL STRAIN CAN BE OBTAINED. ALSO, THIS TIME INCREMENT CAN NOT BE
C       CHANGED IN INPUT DATA FILE! THE RULE TO CHOSE IT IS STRAIN < 1.0E-6
C
     IF(KSTEP.EQ.1) DTIME=0.01
C
C       CALCULATE HARDENING PARAMETER PK AT LAST STEP
C
         PK=P+(Q-AFA*P)*(Q-AFA*P)/P/(M*M-AFA*AFA)
C
C       CALCULATE ELASTIC STIFFNESS MATRIX
C
        KE=1.0/KAPAV*ABS(P)
        KG=3.0*0.5*(1.0-2.0*ENU)/(1.0+ENU)*KE
C
C        FORM THE STIFFNESS MATRIX IN THIS STEP
C
       DO I=1,NTENS
        DO J=1,NTENS
           DD1(I,J)=0.0
        ENDDO
       ENDDO
C
C       DEFINE BASIC ELEMENT IN NONLINEAR ELASTIC STIFFNESS MATRIX
C       PRESSURE-DEPENDENT NONLINEAR ELASTIC
C
        D1=KE+4.0*KG/3.0
        D2=KE-2.0*KG/3.0
C
      D4=KG
C
      DO I=1,NDI
       DO J=1,NDI
         DD1(J,I)=D2
       ENDDO
         DD1(I,I)=D1
      ENDDO
C
      DO I=NDI+1,NTENS
         DD1(I,I)=D4
      ENDDO
C
C       UPDATE STRESS-STRESS=STRESS+DSTRESS USING DIRECT EXPLICIT ALGORITHM
C
         CALL FLOW1(STRESS,AFA,M,PK00,NAMDV,EEPVM0,T0,DFDSN,EVPRN,EVT,
    1                                                     EVKL,PESAV)
C
       CALL FLOW2(STRESS,AFA,M,PESAV,EVT,PK00,EEPVM0,EVKL,NAMDV,T0,
    1                                  DFDSN,DFSS1,DFSS2,DFSS3,DEDSN)
C
          DO 100 I=1,NTENS
        DO 100 J=1,NTENS
           DC(I,J)=0.0
        DO 100 K=1,NTENS
           DC(I,J)=DC(I,J)+DD1(I,K)*DTIME*BETA*DEDSN(K,J)
100     CONTINUE
C
         DO 105 I=1,NTENS
       DO 105 J=1,NTENS
        IF(I.EQ.J) DC(I,J)=1.0+DC(I,J)
105      CONTINUE
C
C      SYSMETRY AND INVERSION OF MATRIX DC
C
        CALL INVERT(DC,4)
C
        DO 110 I=1,4
      DO 110 J=1,4
         DES(I,J)=0.0
      DO 110 K=1,4
         DES(I,J)=DES(I,J)+DC(I,K)*DD1(K,J)
110     CONTINUE
C
        DO I=1,NTENS
       DO J=1,NTENS
          DD2(I,J)=DES(I,J)
       ENDDO
      ENDDO
C
C       FORM JACOBIAN MATRIX
C
         DO K1=1,NTENS
        DO K2=1,NTENS
           DDSDDE(K1,K2)=DD2(K1,K2)
        ENDDO
       ENDDO
C
C       CALCULATE NEW STRESS INCREMENT DSTRESS
C
        DO K=1,NTENS
         DSTRESS(K)=0.0
      ENDDO
C
      DO K1=1,NTENS
       DO K2=1,NTENS
          DSTRESS(K2)=DSTRESS(K2)
     1                  +DDSDDE(K2,K1)*(DSTRAN(K1)-DTIME*EVPRN(K1))
       ENDDO
      ENDDO
C
C       UPDATE THE NEW STRESS FOR N+1 STEP
C
        DO K1=1,NTENS
         STRESS(K1)=STRESS(K1)+DSTRESS(K1)
      ENDDO
C        ***** THE END OF STRESS UPDATE ALGORITHM ******
C
C        COMPUTE THE INCREMENT OF P-DP
C
       DP=(-1.0)*(DSTRESS(1)+DSTRESS(2)+DSTRESS(3))*1.0/3.0
C
C        COMPUTE AND UPDATE THE VOLUMETRIC STRAIN EVM USING PK FOR N INCREMENT
C        1 COMPUTE THE VISCOPLASTIC STRAIN RATE B
C
         PKK=ABS(PK/PK00)
         AA=EEPVM0+NAMDV*LOG(PKK)-EVT
         BB=(1.0+AA/EVKL)
         AA1=AA/BB
       IF(PESAV.GT.1.0E-7) THEN
         AA2=AA1/PESAV
!!         IF(AA2.GT.0.0) AA2=0.0
         B=(BB**2)*(EXP(AA2))
         B=PESAV/T0*B
       ELSE
         B=0.0
       ENDIF
C
C       2 COMPUTE THE DERIVATIVE OF VISCOOLASTIC STRAIN RATE WITH RESPECT
C         TO PK AND VOLUME STRAIN:JP AND JV
C
        JP=2.0*NAMDV/BB/EVKL/P+NAMDV/PESAV/P/BB/BB
      JV=(-1.0)*2.0/BB/EVKL+(-1.0)/PESAV/BB/BB
C
C       FORM INCREMENT OF VOLUME STRAIN
C
        DEVT=(KAPAV*DP/P+DTIME*B*(1.0+BETA*JP*DP))/(1.0-DTIME*B*BETA*JV)
C
C       UPDATE VOLUMETRIC STRAIN EVT; HARDENING PARAMETER PK; P AND Q;
C
       EVT=EVT+DEVT
!      IF(EVT.LT.0.0) EVT=0.0
!      IF(AA.GT.0.0)  EVT=NAMDV*LOG(PKK)
C
         STATEV(1)=EVT
C
C        1. TOTAL STRAIN ENERGY
C
         DEE1=0.0
       TDE=0.0
       DO K1=1,NTENS
          TDE=TDE+(STRESS(K1)*DSTRAN(K1))
       ENDDO
C
C        2. SPECIFIC ELASTIC STRAIN ENERGY
C
         DO K1=1,NTENS
        DO K2=1,NTENS
           DEE(K2)=DEE(K2)+DSTRAN(K1)*DD1(K1,K2)
        ENDDO
       ENDDO
C
         DO K=1,NTENS
          DEE1=DEE1+DEE(K)*DSTRAN(K)
       ENDDO
C
         SSE=SSE+DEE1
       SPD=SPD+TDE-DEE1
      RETURN
    END
C ********************************** THE END OF MAIN PROGRAM *****************************
C
C ********************************************************************************** C
C      NOTES:  THE FOLLOWING SECTION IS SUBROUTINES INVOKED IN THE MAIN PROGRAM      C        C
C                              SUBROUTINES (TOTALLY 4)                               C        C
C ================================================================================== C
C                    1. FLOW DIRECTION--FLOW(I)                                      C
C      THE ONE-ORDER DERIVATION OF YIELD FUNCTION WITH REPECT TO STRESS  TENSOR      C
c                    SUBROUTINE FLOW1(I)                                             C
C      NOTES: 1. STS1-STRESS TENSOR                                                  C
C           2. DFDS-DERIVATIVE OF YIELD FUNCTION VERSUS STRESS TTENSOR               C
C           3. AFA1-AFA; 4.M1-M;  5.P1,Q1--MEAN STRESS AND DEVIATOR STRESS           C
C           4. EVPRN-ELASTRO-VISCOPLASTIC STRAIN RATE FOR N STEP                     C
      SUBROUTINE FLOW1(STS1,AFA,M,PK00,NAMDV,EEPVM0,T0,DFDS,EVPR,
    1                                          EVT,EVKL,PESAV)
C
C
      DIMENSION DFDS(4),STS1(4),EVPR(4)
    DOUBLE PRECISION PK00,STS1,DFDS,AFA,M,PK,PKPK0,NAMDV
    DOUBLE PRECISION EEPVM0,T0,EVT,EVKL,PESAV,EVPR,BBB
    DOUBLE PRECISION A,B,C,P1,Q1,GE1,GE3,AAA,AAA1
    INTEGER K,I,J,KSTEP
C
C       MISES STRESS(Q)
C
           A=STS1(1)-STS1(2)
         B=STS1(2)-STS1(3)
         C=STS1(3)-STS1(1)
         P1=(-1.0)*(STS1(1)+STS1(2)+STS1(3))/3.0
         Q1=A*A+B*B+C*C
         Q1=Q1+6.0*STS1(4)*STS1(4)
         Q1=SQRT(Q1/2.0)+1.0E-25
C
         PK=P1+(Q1-AFA*P1)*(Q1-AFA*P1)/(M*M-AFA*AFA)/P1
C
       GE1=PESAV/T0
         GE3=2.0*P1-PK-2.0*AFA*(Q1-AFA*P1)/(M*M)
    1                        +(AFA*AFA)*(PK-2.0*P1)/M/M
C
!       IF(GE3.LT.0.01) GE3=0.01
C
C       CALCULATE FIRST DERIVATIVE OF YIELD FUNCTION TO STRESS TENSOR DFDS
C
      DO I=1,3
        DFDS(I)=(2.0*P1-PK-(Q1-AFA*P1)*(2.0*AFA+9.0*P1/Q1)/(M*M)
    1          +(AFA*AFA)*(PK-2.0*P1)/(M*M))*1.0/3.0*(-1.0)+3.0*STS1(I)
     2          *(Q1-AFA*P1)/Q1/(M*M)
        ENDDO
      DFDS(4)=6.0*STS1(4)*(Q1-AFA*P1)/Q1/(M*M)
C
      DO K1=1,4
           PKPK0=ABS(PK/PK00)
           AAA=EEPVM0+NAMDV*(LOG(PKPK0))-EVT
!!        IF(AAA.GT.0.0) AAA=0.0
           BBB=(1.0+AAA/EVKL)
           AAA1=AAA/BBB/PESAV
C
C       ENSURE EVT LARGER THAN REFERENCE STRAIN EVR
C
!!        IF(AAA1.GT.0.0) AAA1=0.0
           EVPR(K1)=GE1*(BBB**2)*(EXP(AAA1))/(ABS(GE3))*DFDS(K1)
        ELSE
           EVPR(K1)=0.0
        ENDIF
      ENDDO
C
      RETURN
      END
C   **************************** FFFFFFFFFFFFFFFFFF ********************************
C                       2. SUBROUTINE FLOW2 (STS2,....)                              C
C     DIREVATION OF VISCOPLASTIC RATE WITH RESPECT TO STRESS TENSOR                  C
C     NOTES: 1.DEDS-DIREVATION OF VISCOPLASTIC RATE WITH RESPECT TO STRESS TENSOR    C
C            2.DFDS-FIRST DERIVATIVE OF YIELD FUNCTION TO STRESS TENSOR              C
C            3.STS2-STRESS TENSOR;  4.EV-VOLUMN STRAIN                               C
C            5.EVKL-LIMIT VISCOPLASTIC STRAIN                                        C
      SUBROUTINE FLOW2(STS2,AFA,M,PESAV,EVT,PK00,EEPVM0,EVKL,NAMDV,T0,
    1                 DFDS,DFSS1,DFSS2,DFSS3,DEDS)
C
C
    DIMENSION DFDS(4),DFSS1(4),DFSS2(4),DFSS3(4),STS2(4)
    DIMENSION GES(4),DEDS(4,4),DC(4,4),DC1(4,4),DFDS2(4,4)
    DOUBLE PRECISION AFA,M,NAMDV,PK,EVT,PK00,EPVM0,T0,PESAV
    DOUBLE PRECISION PM22,B2,A2,P,Q,Q1,Q2,Q3,EVKR,E11
    DOUBLE PRECISION E12,EVKL,E1,EVKR0
    INTEGER K,I,J,KSTEP
C
C        FIRSTLY, CALCULATE P AND Q AND PM
c        CALCULATE P
C
         P=(-1.0)*(STS2(1)+STS2(2)+STS2(3))/3.0
C
C        CALCULATE Q
C
        Q1=STS2(1)-STS2(2)
        Q2=STS2(2)-STS2(3)
        Q3=STS2(1)-STS2(3)
        Q=Q1*Q1+Q2*Q2+Q3*Q3
        Q=Q+6.0*STS2(4)*STS2(4)
C
          PK=P+(Q1-AFA*P)*(Q1-AFA*P)/(M*M-AFA*AFA)/P
C
C        FORM UNIT MATRIX
C
       DO 405 I=1,4
        GES(I)=1.0
405    CONTINUE
         GES(4)=0.0
C
C        CALCULATE DEDS
C
     DO 430 I=1,3
       DFSS1(I)=-1.0/3.0
       DFSS2(I)=1.0*P+STS2(I)
       DFSS3(I)=-1.0/3.0
430    CONTINUE
C
          DFSS1(4)=0.0
        DFSS2(4)=2.0*STS2(4)
        DFSS3(4)=0.0
C
     DO 450 I=1,4
     DO 450 J=1,4
450        DFDS2=0.0
C
      DO  I=1,4
       DO  J=1,4
       DFDS2(I,J)=DFSS1(I)*(-2.0/3.0-AFA/(M*M)/3.0*(9.0*P/Q+2.0*AFA)
     1              +2.0/3.0*AFA*AFA/M/M)*GES(J)
     2              +AFA/(M*M)/Q*(2.0-GES(J))*STS2(J)
     3              +DFSS2(I)*1.5*AFA/Q/Q/Q/(M*M)*(3.0*P*P*GES(J)
     4              +(2.0*Q*Q*GES(J)+9.0*(2.0-GES(J))*P*STS2(J))/3.0)
     5              +DFSS3(I)*3.0/(M*M)*(1.0-AFA*P/Q)*GES(J)
C
         IF (I.EQ.J) THEN
           DFDS2(I,J)=DFDS2(I,J)+3.0*(2.0-GES(J))/(M*M)
    1                                     *(1.0-AFA*P/Q)
         ENDIF
        ENDDO
       ENDDO
C
       DO 410 I=1,4
     DO 410 J=1,4
        DC(I,J)=DFDS(I)*GES(J)
        DC1(I,J)=DFDS(I)*((2.0-GES(J))*STS2(J)+P*GES(J))
410    CONTINUE
C
C        FORM B2 AND A2 TO CALCULATE SCALAR VALUE IN YIELD RULE
C
         B2=2.0*P-PK-2.0*AFA*(Q-AFA*P)/(M*M)+(AFA*AFA)*(PK-2.0*P)/(M*M)
C
!     IF(B2.LT.0.01) B2=0.01
C
       PM22=ABS(PK/PK00)
       EVKR=EEPVM0+NAMDV*(LOG(PM22))-EVT
C
!!     IF(EVKR.GT.0.0) EVKR=0.0
C
         E1=1.0+EVKR/EVKL
       E11=EVKR/E1
C
C       EVKL--LIMIT OF THE VISCOPLASTIC STRAIN
C
      IF(PESAV.GT.1.E-7) THEN
             E12=E11/PESAV
          IF (E12.GT.0.0) E12=0.0
           A2=PESAV/T0*(E1**2)*(EXP(E12))
        ELSE
           A2=0.0
      ENDIF
C
C        FORM DEDS(I,J)-DIFFERENTIATION OF VISCOPLASTIC STRAIN RATE TO STRESS TENSOR
C
       DO  I=1,4
        DO J=1,4
         IF (PESAV.GT.1.0E-7) THEN
            DEDS(I,J)=DFDS2(I,J)*A2/(ABS(B2))
    1        +(DC(I,J)*2.0/3.0+3.0*AFA*DC1(I,J)/Q/(M*M))/(B2*B2)*A2
         ELSE
            DEDS(I,J)=0.0
         ENDIF
         ENDDO
      ENDDO
C
    RETURN
    END
C     ============================================================================ C
C                 3. INVERT  FORM INVERSION OF MATRIX                              C
C     SUBROUTINE FOR CALCULATING THE INVERT MARTRIX OF THE STIFFNESS MATRIX        C
       SUBROUTINE INVERT(A,NMAX)
C
C
       DIMENSION A(4,4)
     INTEGER N,J,NMAX,I
C
      DO 310 N=1,NMAX
       D=A(N,N)
      DO 320 J=1,NMAX
320         A(N,J)=-A(N,J)/D
      DO 450 I=1,NMAX
      IF(N-I) 410,450,410
410      DO 440 J=1,NMAX
         IF(N-J) 420,440,420
420          A(I,J)=A(I,J)+A(I,N)*A(N,J)
440     CONTINUE
450         A(I,N)=A(I,N)/D
            A(N,N)=1.0/D
310   CONTINUE
C
      RETURN
    END
C **************************** ////  THE END \\\\ ********************************
m_b_
please correct me if im wrong.(have no experience coding in fortran);
1-i need to write a Fortran main program(run the subroutine as a individual code), and compile it and link to the import library of the DLL.(dont have any idea now??)
the text in it does not match the description in #4.<<<<<<< what do u mean by that?sry i didnt understand that
THTS the abaqus input file:
**TRIAXIAL TEST SIMULATION:DRAINED TEST
** PARTS
*Part, name=Part-1
*End Part
** ASSEMBLY
*Assembly, name=Assembly
*Instance, name=Part-1-1, part=Part-1
*Node
      1,           0.,           0.
      2,          0.019,           0.
      3,           0.,           0.038
      4,          0.019,         0.038
*Element, type=CAX4
1, 1, 2, 4, 3
** Region: (CLAY:Picked)
*Elset, elset=_I1, internal
 1,
** Section: CLAY
*Solid Section, elset=_I1, material=CLAY
1.,
*End Instance
*Nset, nset=_PickedSet4, internal, instance=Part-1-1
 1, 3
*Elset, elset=_PickedSet4, internal, instance=Part-1-1
 1,
*Nset, nset=_PickedSet5, internal, instance=Part-1-1
 2, 4
*Elset, elset=_PickedSet5, internal, instance=Part-1-1
 1,
*Nset, nset=_PickedSet6, internal, instance=Part-1-1
 1, 2
*Elset, elset=_PickedSet6, internal, instance=Part-1-1
 1,
*ELSET,ELSET=ECLAY, instance=Part-1-1
1
*NSET,NSET=NCLAY,instance=Part-1-1
1,2,3,4
*NSET,NSET=TOP,instance=Part-1-1
3,4
*NSET,NSET=BOTTOM,instance=Part-1-1
1,2
*NSET,NSET=LHS,instance=Part-1-1
1,3
*End Assembly
** MATERIALS
*MATERIAL,NAME=CLAY
*User Material, TYPE=MECHANICAL, constants=12,unsymm
0.0125, 0.3, 9.48, 0.0023, 0.0837, 1.0, 0.0, 25.37,
0.999, 0.355, 1.0, 2
*DEPVAR
1,
*INITIAL CONDITIONS, TYPE=RATIO
NCLAY,1.08, 0., 1.08, 0.038
*INITIAL CONDITIONS,TYPE=STRESS,GEOSTATIC
ECLAY,-1.0E2, 0., -1.0E2, 0.038, 0.999
*INITIAL CONDITIONS,TYPE=SOLUTION
ECLAY, 0.1972
*AMPLITUDE,NAME=RATE,DEFINITION=TABULAR,TIME=STEP TIME,VALUE=RELATIVE
0.1, 0.0435, 0.2, 0.0870, 0.3, 0.1304, 0.4, 0.1739,
0.5, 0.2174, 0.6, 0.2609, 0.7, 0.3043, 0.8, 0.3478,
0.9, 0.3913, 1.0, 0.4348, 1.1, 0.4783, 1.2, 0.5217,
1.3, 0.5652, 1.4, 0.6087, 1.5, 0.6522, 1.6, 0.6957,
1.7, 0.7391, 1.8, 0.7826, 1.9, 0.8261, 2.0, 0.8696,
2.1, 0.9130, 2.2, 0.9565, 2.3, 1.0
*STEP
GEOSTATIC INITIAL STRESS STATE
*GEOSTATIC
*DLOAD
ECLAY,P2,1.0E2
** BOUNDARY CONDITIONS
*Boundary
BOTTOM, 2
TOP,2
LHS,1
*Output, field, FREQUENCY=1
*ELEMENT OUTPUT,ELSET=ECLAY
S,E
** HISTORY OUTPUT: H-Output-1
*EL PRINT
S,
E
*END STEP
** STEP: STEP100
*Step,EXTRAPOLATION=NO,INC=10000,UNSYMM=YES
STEP100
*STATIC
0.0005,2.3,1.0E-20,0.0005
**KEEP CONSTANT VERTICAL STRAIN RATE 1.0E-6 PER SECOND
*BOUNDARY,AMPLITUDE=RATE
TOP,2,2,0.0076
*EL PRINT
S,
E,
SDV,
*NODE PRINT
U,RF
*Output, field, FREQUENCY=5
S,
E,
SDV
*Output, history, frequency=5
S,
E,
SDV
*End Step
Greg_T_
From the command line messages it looks like Abaqus has compiled and linked to the user subroutine and started the analysis.  To investigate further, I still recommend that you write a main program that can call the user subroutine to confirm that it is working correctly before running from Abaqus.  Then add write statements to unit=7 (to the Abaqus *.msg message file) within the user subroutine to see if Abaqus has been able to call the user subroutine and pass input values.  Adding more write statements will give an indication of progress through the user subroutine and where the crash occurs.
mecej4
In that case, you cannot proceed with the task. Sorry.
