undefined reference under suse 9.0
tcorbard
A code that use to compile with ifc, now produce the following
at compilation time.
/tmp/ifcLXalxY.o(.text+0x1500c): rfrence indfinie vers des_
/tmp/ifcLXalxY.o(.text+0x150cc): rfrence indfinie vers des_
/tmp/ifcLXalxY.o(.text+0x150e5): rfrence indfinie vers des_
/tmp/ifcLXalxY.o(.text+0x17778): rfrence indfinie vers list_
/tmp/ifcLXalxY.o(.text+0x18a38): rfrence indfinie vers list_
/tmp/ifcLXalxY.o(.text+0x1a9f9): rfrence indfinie vers des_
/tmp/ifcLXalxY.o(.text+0x1aa12): rfrence indfinie vers des_
/tmp/ifcLXalxY.o(.text+0x1ca1c): rfrence indfinie vers add_ascii_
/tmp/ifcLXalxY.o(.text+0x1ca38): rfrence indfinie vers output_
I recently update my system from Suse 8.1 to 9.0.
Is there any library I should link with for these to be found?
Thierry
