29425 Discussions
undefined symbol: for__pthread_mutex_lock_ptr when building shared library
gregfi04
I'm attempting to follow the procedure belowin order to build shared libraries with statically-linked Intel libraries:
All of the shared libraries are being built and most of them (seem to) function correctly. A few of them, however, produce this message when the code is executed and they're linked in:
symbol lookup error: ./code_name:undefined symbol: for__pthread_mutex_lock_ptr
Any thoughts on what may cause this?
Greg
TimP
The usual way to link in pthreads is by giving ifort an option which implies it (-openmp or -parallel), or by appending -lpthreads to the link options. So the thought would be that you chose some less usual method.
gregfi04
Here are my linker flags. Do any of these look out of whack?
/usr/lib64/gcc/x86_64-suse-linux/4.1.2/../../../../lib64/crti.o \
/usr/lib64/gcc/x86_64-suse-linux/4.1.2/crtbeginS.o \
--eh-frame-hdr \
-shared \
-L/tools/intel/fce/11.1.046/lib/intel64 \
-L/usr/lib64/gcc/x86_64-suse-linux/4.1.2 \
-L/usr/lib64/gcc/x86_64-suse-linux/4.1.2/../../../../lib64 \
-L/lib/../lib64 \
-L/usr/lib/../lib64 \
-L/usr/lib64/gcc/x86_64-suse-linux/4.1.2/../../../../x86_64-suse-linux/lib \
-L/usr/lib64/gcc/x86_64-suse-linux/4.1.2/../../.. \
-L/lib64 \
-L/lib \
-L/usr/lib64 \
-L/usr/lib \
-Bstatic \
-lifport \
-lifcore_pic \
-limf \
-lsvml \
-Bdynamic \
-lm \
-Bstatic \
-lipgo \
-lirc \
-u \
__pthread_once \
-Bdynamic \
-lpthread \
-lc \
-lgcc_s \
-Bstatic \
-lirc_s \
-Bdynamic \
-ldl \
-lc \
/usr/lib64/gcc/x86_64-suse-linux/4.1.2/crtendS.o \
/usr/lib64/gcc/x86_64-suse-linux/4.1.2/../../../../lib64/crtn.o
Ron_Green
hmmm, interesting. In newer compilers this symbol is indeed in libifcore_pic.a BUT it's not in your old 11.1 version library for libifcore_pic.a
I am assuming you have -openmp or -parallel in your build, yes?
There were some restrictions in the past regarding using the OpenMP runtime and static builds - to the effect that you could NOT build statically with OpenMP. I'll check with our OpenMP experts.
ron
Ron_Green
it would help to see your compiler options.
-i-static will NOT link in the static OpenMP runtime library. You need '-openmp-link static' to achieve that.
ron
