unformatted read/writes
Justin_v_
My application has recently stopped being able to read unformatted files that are greater than 2.1GB in size.  Specifically, the read command of the following subroutine fails (iostat=-1) if jj = 2900 (file size 2.15GB), but works (iostat=0) if jj=2800 (file size 2.08GB).
ii = 95000
jj = 4000
allocate ( store_huge(ii, jj), STAT = istat )
store_huge = 0.0
open( newunit = file_id, file = outputfilename, form = 'unformatted', action='write', iostat = istat )
write(file_id, IOSTAT=istat) store_huge
close(file_id)
store_huge = 1.0
open(newunit=file_id, FILE=outputfilename, form = 'unformatted', action='read', iostat = istat)
read(file_id, IOSTAT=istat) store_huge
close(file_id)
deallocate( store_huge )
This problem only appeared recently, and may be due to a recent Windows update (which we can no longer control, and which have been driving me crazy).  I have Windows 10 (including the most recent automated updates), am using VS2017 (which may be the problem, though I have been using this for a couple of months without issue), and Visual Fortran Compiler 17.0.4.210.
Justin_v_
I have recompiled the application with (microsoft) VS2015 (rather than VS2017), and the same problem appears.  This suggests that it is something to do with Visual Fortran Compiler 17.0.4.210 and/or Windows 10 (version 1703, OS Build 15063.413).
Justin_v_
Using the access='stream' option seems to resolve this issue, even if only sequential access (the default) is used.  Something looks like it has gone wrong with the compiler (probably due to a change in Windows), which I hope can be fixed soon...
andrew_4619
The -1 is end of file on read. But is the problem the read or is it the write that failed? Did you check the end of the file that was written to see if it is all there?
Also is there a timing issue with buffering data, ie windows has not fully finished the write when you do the read....
Justin_v_
The error code appears with the read command, not the write command.  File sizes of the write command also suggest something at least close to completion.  Yes, -1 is end of file on read; it is also possible to generate code 64 (I think), if breaking the read up into multiple variables.  I do not know how to check the end of file, as it is unformatted (binary).  I can confirm that is definitely not a timing issue.
Playing around with this code snippet reveals no problems at all, but all sorts of failures appear when the "access='stream'" option is omitted and different combinations of variable reads-writes are used that imply a total file size greater than 2.1GB:
ii = 95000
jj = 2000
allocate ( store_huge(ii, jj*2), store_huge2(ii,jj), store_huge3(ii,jj), STAT = istat )
store_huge = 1.0
store_huge2 = 2.0
store_huge3 = 3.0
open( newunit = file_id, file = outputfilename, form = 'unformatted', action='write', access='stream', iostat = istat )
write(file_id, IOSTAT=istat) store_huge2
write(file_id, IOSTAT=istat) store_huge3
close(file_id)
store_huge2 = 2.0
store_huge3 = 2.0
open(newunit=file_id, FILE=outputfilename, form = 'unformatted', action='read', access='stream', iostat = istat)
read(file_id, IOSTAT=istat) store_huge2
read(file_id, IOSTAT=istat) store_huge3
close(file_id)
deallocate( store_huge, store_huge2, store_huge3 )
It really looks like microsoft have made some change that exposes a problem with the default (sequential) read/write unformatted combination.
andrew_4619
These error still suggest you are reading and incomplete file. Read it back one byte at a type with non advancing IO until you get eof. Check the number of bytes read and the last few bytes read at eof. This might tell you something interesting or close this line of thought.
How do you know with certainly it is not a timing issue BTW?
Post a complete  program for #5 that gives the error and I will test it.
Justin_v_
It is not a timing issue, because the same problem originally appeared when I tried to read a file that had been written some days previously.  I have also tested whether reading a (2.2GB) file an hour after it had been written (following my lunch break) made a difference - it didn't.
Find attached two zip folders, with VS solutions that replicate the problem attached.  It appears that compiler options make a difference, as the code in the two solutions is identical, but the errors are different.  VERSION 1 is an extract from the application that I originally tested on, and reproduces the errors I found during my testing - these are slightly different in VERSION 2.
Please note that this problem only appeared after the most recent windows 10 update (as discussed above) - the errors I get on my system are included in the source code comments.
jimdempseyatthecove
Does adding:
    BUFFERED='yes'
have any effect?
Jim Dempsey
Justin_v_
I just ran the test routine, and adding buffered='yes' didn't alter results at all.
Roman1
Recently I have found a bug with unformatted I/O.  Can you look at my previous post, and see if it is related to what you are seeing.  Are you using /assume:buffered_io ?
https://software.intel.com/en-us/forums/intel-visual-fortran-compiler-for-windows/topic/721914
Roman
Justin_v_
This is possibly the same problem as yours Roman, as I use the buffered I/O option by default.  But, the problem I identify also arises when buffered I/O is suppressed - as indicated by the VERSION2.zip solution that is included in this post
andrew_4619
I tried your version 1 and I agree that it looks like a bug in the fortran runtime. I had a small play with test 1 (see below). There is nothing of interest in the windows (getlasterror) calls. it seems when the fortran sets  the error status on the read the windows error gets reset to 0. I just did that as is sometimes shows something of interest.
when I did the write array array slices test it throws error 67 ( input statement requires too much data) reading the third slice, subsequent reads don't return a error (but fail as the data read is uninitialised).
In conclusion this is something INTEL need to look at.
MODULE tester
!	Module defined here to test specific functions
IMPLICIT none
CONTAINS
SUBROUTINE test11()
!	TEST to check writing routine
use ifwin, only: getlasterror
implicit none
! local
integer(4) :: ii, jj, file_id, istat
integer :: l1,l2
real(8), allocatable :: store_huge(:,:), store_huge2(:,:), store_huge3(:,:)
character(2000) :: outputFileName
!	begin code
outputFileName = 'C:\temp\check.dat'
ii = 95000
jj = 2000
store_huge = 1.0
store_huge2 = 2.0
store_huge3 = 3.0
! test 1
do l1 = 1, size(store_huge, dim=2)
    write(file_id, IOSTAT=istat) store_huge(:,l1)
    if( istat /= 0 ) write(*,*) 'write1 l1, istat', l1, istat
enddo
!write(file_id, IOSTAT=istat) store_huge
close(file_id)
store_huge = 0.0
write(*,*) 'err code before open 1',getlasterror()
write(*,*) 'err code before read 1',getlasterror()
!read(file_id, IOSTAT=istat) store_huge	! fails with istat = -1
    read(file_id, IOSTAT=istat) store_huge(:,l1)	! fails with istat = -1
    if( istat /= 0 ) write(*,*) 'read1 l1, istat', l1, istat, getlasterror()
enddo
write(*,*) 'err code after read 1',getlasterror()
close(file_id)
read(file_id, IOSTAT=istat) store_huge3	! fails with istat = 67
close(file_id)
! test 2
close(file_id)
read(file_id, IOSTAT=istat) store_huge3	! fails with istat = -1
close(file_id)
close(file_id)
! test 3
close(file_id)
close(file_id)
! test 4 - no fail
close(file_id)
close(file_id)
! test 5 - no fail
close(file_id)
close(file_id)
! test 6 - no fail
close(file_id)
close(file_id)
continue
END SUBROUTINE test11
END MODULE tester
Justin_v_
Thanks for this Andrew - I am surprised that a error is appearing in the write statement on the grid slice test, as no error is reported when writing the full matrix.  In any case, at least the 'stream' work-around is keeping me going for the moment, and hopefully the Intel people will resolve the issue before things get more complicated.
andrew_4619
There was only error on read not write.
Justin_v_
Thanks for the clarification (I got confused by the "write array array slices test it throws error 67")
Devorah_H_Intel
Hi Justin, Andrew,
Thank you for the report. I am checking with development on this and will get back to you shortly.
Best regard,
Devorah_H_Intel
This was fixed as well in 18.0 compiler to be released soon.
The type of “store_huge” array was not specified. Using real*8”:
real*8, allocatable :: store_huge(:,:)
 removed IOSTAT= specifier from READ statement to catch possible Input error:
read(1) store_huge
18.0 works fine:
-bash-4.1$ ifort -V
Intel(R) Fortran Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 18.0 Build 20170705
Copyright (C) 1985-2017 Intel Corporation.  All rights reserved.
-bash-4.1$ ifort f2.f90 -assume buffered_io && ./a.out
-bash-4.1$
Justin_v_
Apologies - is "real(8), allocatable" not equivalent to "real*8, allocable"?  I do not follow how removing IOSTAT= specifier from READ statement will catch the error - I thought this would do the reverse (or maybe you have in mind a run-time error message)?
A bit confused, but happy to hear that it will be fixed in 18.0 - can you take a guess as to which month 18.0 will come out?
Many thanks,
Justin.
Steve_Lionel
REAL*8 is an extension - in Intel Fortran it is equivalent to REAL(8). Best practice is to not use explicit kind numbers such as 8, though. See Doctor Fortran in "It Takes All KINDs"
Removing the IOSTAT allows the error to be reported on the console rather than just have the variable set. The error report will have more information.
andrew_4619
And now I am confused as the examples in this thread use real(8) and not the defunct real*8. I don't get Surely removing IOSTAT=  that means I program crashes on error rather than you being able to handle the error.
IanH
The comments make sense for the code snippets in the first few posts of the thread.  The type of store_huge is not specified at all - support would have had to guess when they saw the original post.  An IOSTAT specifier is provided for the io statements (and others), but the value that results is ignored - which is hiding the problem, not handling it.
