29385 Discussions
uninstall Fortran Compiler Professional Edition for Linux* 11.0
Jacques_Hertzberg
I'm looking around at the same issue I met without success. Hope I'm in the right place to post this.
Removing unintentionally the directory containing Intel Fortran install with mkl install, I can't reinstall Intel Fortran getting a message :
Initializing, please wait...
The Intel Fortran Compiler Professional Edition for Linux* 11.0 is already
installed.
If you want to reinstall the Intel Fortran Compiler Professional Edition for
Linux* 11.0
please uninstall current version and run install script again.
Press "Enter" key to quit:
Can you help me ?
Steven_L_Intel1
Follow the uninstall instructions in the release notes. My guess is that the install is recorded in the rpm database and needs to be removed somehow.
Jacques_Hertzberg
I've read the guide before posting :
2. Type the command: /bin/ia32/uninstall_cprof.sh (substitute intel64 or ia64 for ia32 as desired)
But there isn't anymore and there's no uninstall script in archive.
TimP
Quoting - Jacques Hertzberg
Try e.g. 'rpm -qa | grep intel'
and (as root) run 'rpm -e --force ....' on the entries which you need to remove. I find this simpler than attempting to extract uninstall from the archive.Without --force, you would have to find the right order for removal (e.g. mkl before ifort...)
Jacques_Hertzberg
Quoting - tim18
# rpm -qa | grep intel
intel-isubhe101018-10.1.018-1.em64t
intel-iidbe101018-10.1.018-1.em64t
intel-icce101018-10.1.018-1.em64t
No ifort.
I think I'll ask for directory backup.
Thanks for your help.
