unlink !!!
ekeom
I try to use the unlink instruction. How can I use it in Linux
Intel Fortran? Which library should use for that. DFLIB and
DFPROT semeed not work!!
Didace
fortcom: Error: far_field_212_m.f90, line 27: Error in
opening the Library module file. [DFLIB] use
dflib
fortcom: Error: far_field_212_m.f90, line 28: Error in
opening the Library module file. [DFPORT]
use dfport
fortcom: Error: far_field_212_m.f90, line 86: This
name does not have a type, and must have an explicit
type. [UNLINK]
if(f_exist) i = unlink(file_mac)
TimP
In the documentation files which are installed with the compiler, it says "use ifport"
