unusual INCLUDE hierarchy
Robinson__Donald
I'm having trouble getting Dev Studio to use the INCLUDE files I want. Here is a simplified example to show the problem.
I have source code and include files in two directories /d1 and /d2. There are 2 slightly different copies of an INCLUDE file 'parms.f77' in both directories. In this project, the version of 'parms.f77' in /d1 is never supposed to be used; even by source routines in /d1: the copy in /d2 is always used.
I've tried to modify settings under Tools | Options as well as the 'USE and INCLUDEPaths' settingsunder Project | Settings | Fortran | Preprocessor without any success. Although these settings are able to correctly point to /d2/parms.f77 when referenced bymost source files in the project, source files in /d1 always use /d1/parrms.f77. I've also tried dragging into the project the External include files, and then deleting them. Still no success.
For a variety or reasons - principally a shared code base -I can't just delete /d1/parms.f77 from the system permanently,although it would be OK if I could somehow automatically erase it each time I did a build. (My source control would still have a copy). My preferred solution would be to have the correct information in the DSP file
Is it possible to do what I want? Any advice would be very welcome.
This is CVF, right? What version? My memory on this issue is a bit fuzzy, but I know there was a bug where the directory of the source was always used - the /assume:[no]source_include switch just determined where in the list it would go. I don't know if it ever got fixed in CVF.
Robinson__Donald
Hi Steve - This is CVF Standard 6.6c.
Thought so. I don't know of a good solution for you.
Robinson__Donald
Thanks very much. Two possibilities come to mind: (1) do you know if there are any plans to keep producing CVF patches; (2) does the Intel product (which appears to bemuch more current!) get this right?
There are no plans for future CVF updates.
This is fixed in the current Intel Visual Fortran (was fixed in late December.)
sgongola
Steve,
I think this is the problem I reported to CVF support in june, 2002:
#CVF18049: /assume:nosource_include does not seem to work correcly.
Unfortunately, it was not fixed with any of the CVF updates released since then and I have been working around it by ensuring that the needed include was always present in the same directory as the source file.
sol
Yes, I remember that. As you note, it wasn't fixed for CVF.
