Hello, I have updated to Intel Fortran Compiler Integration for Microsoft Visual Studio 2005, Version 9.1.3192.2005. I ambuilding aQuickWin application. I have got two trivial questions: (1) is there a very simple way to append a single html file to my program,which would be accessible from theapplication'shelp menu- it would include manual to the program users; (2) will the release version work on any windows computer or is it necessary to distribute some supporting files?
Thank you very much for your response.
2) The release version will work on any Windows computer if it's built with "Static" (non-dll) run-time libraries. I think it's the default -- the setting is located in Project/Properties/Fortran/Libraries/Run-time library. Otherwise, you have to redistribute IVF run-time dll, libifcorert.dll.
Thank you very much for your response. With regards to 1)
dummy = ShellExecute(NULL,NULL, "http://www.microsoft.com", NULL, NULL, SW_SHOWNORMAL)
works fine. I need to replace the webpage with theactualpath tothe htmlfile in the directory on user's computer. I use:
dir = file$curdrive
fname = TRIM(dir)//'/manual.html'
dummy = ShellExecute(NULL,NULL, fname, NULL, NULL, SW_SHOWNORMAL)
which does not work, the function returns a value 2.Thanks for any suggestion, Milan
fname = TRIM(dir)//'/manual.html'C
