using lapack and blas libraries
chimico
If I try to compile
ifort programma.f90 -llapack -lblas
I get this error message:
ld: cannot find -llapack
remembering that to run ifort I added this to my .bashrc:
PATH="/opt/intel/Compiler/11.1/069/bin/intel64:$PATH"
export PATH
LD_LIBRARY_PATH="/opt/intel/Compiler/11.1/069/lib/intel64"
export LD_LIBRARY_PATH
and that Lapack is instead in usr/lib I wrote in terminal:
ifort program.f90 -L/usr/lib llapack lblas
but get this error message
ifort: error #10236: File not found: 'llapack'
ifort: error #10236: File not found: 'lblas'
So now I don't know what to do ...
Help me please
[bash]
[/bash]
[bash]
[/bash]
mecej4
What OS, version?
You appear to be attempting to mix 32-bit and 64-bit objects and libraries. It is also unclear as to whether you do have 64-bit Blas and Lapack libraries installed; normally, such libraries go into /usr/lib64 rather than /usr/lib.
In your second attempt, you should have used the command
ifort program.f90 -llapack -lblas
rather than
ifort program.f90 llapack lblas
With some older versions of ld on Linux/Unix, ld was not knowledgeable enough to use soft links to libraries.
chimico
Thank you for the answer
Now it works:
I downloaded by synaptic (I use ubuntu 10.04 64 bit ) the package liblapack-dev (I don't know why liblapack3gf wasn't enough...)
TimP
Did you install the MKL library option with your ifort installation? That provides more highly optimized BLAS and lapack, including automatic threading. The link advisor helps you figure out your link command. It should work interchangeably with the libraries from your linux distro.
