29359 Discussions
using lapack from mkl in intel visual fortran
flygaoonly
I want to use lapack from mkl in intel visual fortran. Formerly in compaq visual fortran, to use lapack from cxml, I can add a sentence "INCLUDE 'CXML_INCLUDE.F90' " in front of my program, then compile and build in visual studio under windows. Now is there a similar way to use lapack from mkl in intel visual fortran, since in the manual, the setup procedure is a little bit complex.
TimP
Please read the help files and use the link advisor posted at the top of the MKL forum, then follow up there with any additional questions.l
Michael_C_Intel4
you may include 'mkl_lapack.f90' in your program when using MKL.
If you want to link against MKLusing CVF calling convention, you'll need to link:
mkl_s.lib mkl_intel_thread.lib mkl_core.lib libiomp5.lib (or libguide.lib)
but it may be different if you want to link against dynamic MKL, for instance. Surely, querying MKL link advisor would be helpful.
Michael.
