29635 Discussions
variable scoping between subroutines
jvandeven
I have been developing a fortran program for around 6 years now, and haven'texperienced anyproblems in moving between different programme modules and subroutines. Recently, however, I have found that variables have fallen out of scope after returning from a pass to a subroutine. It is a basic question, but what do I need to do to ensure the integrety of variables during passes between subroutine calls?
Many thanks,
Justin.
When you say "fallen out of scope" do you mean that the values have been incorrectly changed? If so, that strongly suggests a coding error in the application. Variables do not "fall out of scope" within a routine. Usually a problem like this is caused by an argument type mismatch in the call or an out-of-bounds array reference in the called routine. It need not be with the variable in question.
jvandeven
For example, a variable x (which is notreferenced by subroutine B) is equal to 5 before the call to subroutine B, and is equal to some random number, or identified as an undefined pointer array after the call to subroutine B. I will check mycode forinaccurate array referencing and variable definitions.
Many thanks,
Justin
The Intel compiler has options that can help. Generated interface checking (/gen-interface /warn:interface) and array bounds checking (/check:bounds).
jvandeven
Brilliant - I've found one bug, and suspect that there is another. I will try the compiler options that you suggest and continue to track them down. You have reduced by stress levels considerably (I was starting to wonder whether I had misunderstood use of modules and subroutines at a fundamental level).
Justin.
