vector subscript of an array
Pierre_Archambeau
Could you explain the difference between the two calls?
The first call changes the expected values ​​while the second provides zero.
Pierre
    module essai
    contains
        subroutine testarray(array)
            real(4),dimension(:) :: array
            array(:)=1
        end subroutine
    end module
    program moi
    use essai
    real(4), dimension(1,20), target :: array
    integer, dimension(2) :: part = (/1,4/)
    array=0
    call testarray(array(1,1:4:3))
    array=0
    call testarray(array(1,part))
    end program
mecej4
In the second CALL, the actual argument is an array section with a variable used to designate the section. Therefore, I believe, the actual argument is an expression and is, therefore, in the subroutine you are not allowed to assign a value to it.
The second call uses what is called a "vector subscript". This causes a temporary copy to be passed and any changes discarded. Consider what would happen if part was defined instead as (/3,3/).
