29651 Discussions
warning message while compiling CAMx
meteorico
Hi all,
I have no such experience in Linux, and I'm working on a environmental model (CAMx). I have installed Intel FortranCompiler 9.1.043 and I tried to compile the code. This is what happened:
You are about to compile with MXTRSP set to 1
If this is not correct, hit C
do "make clean"
Modify "tracer.com" and recompile.
The camx.prm is linked to camx.prm.mrpo.36.12
The executable will be called: CAMx.mrpo.36.12.i_linux
make hdflib
HDF=false
FC=ifort
CC=gcc
FLGS="-I./Includes -DPC_LINUX1 -O2 -align dcommons -extend_source -convert big_endian -ipo -static"
make[1]: Entering directory `/home/CAMx/CAMx_v4.40.src.061025.tar.gz_FILES'
ifort -c -o IO_hdf/camx_includes.o -I./Includes -DPC_LINUX1 -O2 -align dcommons -extend_source -convert big_endian -ipo -static -I./Modules -module ./Modules IO_hdf/camx_includes.f
ifort -c -o IO_hdf/hdf5_file_out.o -I./Includes -DPC_LINUX1 -O2 -align dcommons -extend_source -convert big_endian -ipo -static -I./Modules -module ./Modules IO_hdf/hdf5_file_out.F90
ar -rv libcamxhdf.a ./IO_hdf/camx_includes.o ./IO_hdf/hdf5_file_out.o
r - ./IO_hdf/camx_includes.o
r - ./IO_hdf/hdf5_file_out.o
make[1]: Leaving directory `/home/CAMx/CAMx_v4.40.src.061025.tar.gz_FILES'
make model
FC=ifort
TARGT=CAMx.mrpo.36.12.i_linux
FLGS="-I./Includes -O2 -align dcommons -extend_source -convert big_endian -ipo -static"
ifort -o CAMx.mrpo.36.12.i_linux -I./Includes -O2 -align dcommons -extend_source -convert big_endian -ipo -static ./CAMx/CAMx.o ./CAMx/aerochem_aq.o ./CAMx/aerochem_cf.o ./CAMx/aerochem_cmu.o ./CAMx/aeroset.o ./CAMx/aggdep.o ./CAMx/aggr00.o ./CAMx/aggreg.o ./CAMx/ahoprep.o ./CAMx/average.o ./CAMx/bc1grd.o ./CAMx/bcmodfy.o ./CAMx/caldate.o ./CAMx/camxerr.o ./CAMx/chem10.o ./CAMx/chemdriv.o ./CAMx/chemrxn.o ./CAMx/chmdat.o...
...e cos per altre decine di righe...
..../RTRAC/wrrcprt.o ./SOAP/soapdat.o ./SOAP/soap.o ./SOAP/spfcn.o ./HG/hggaschem.o ./HG/hgaqschem.o ./IO_hdf/camx_includes.o ./IO_hdf/hdf5_file_out.o
IPO Warning: unresolved : hybrd_
Referenced in /tmp/ipo_ifortIacmuZ.o
IPO: performing multi-file optimizations
IPO: generating object file /tmp/ipo_ifortIacmuZ.o
What does those warning messages mean? Has it to do with compiler, with libraries? I have installed Ubuntu 6.10.
Thanks a lot
