watching global variables
wg205
I'm using IFC10.0 and Visual Studio 2005 Profesional. During debugging of the code I'm able to watch local variables but not the global ones. Is there a way to watch them?
If they are module variables, you can use the syntax modname::varname in a watch window.
Kevin_D_Intel
Can you provide some additional source code context or perhaps small example that offers insight into the declaration of these global variables?
It would be helpful to know the package id for your 10.0 compiler, or the Build Date of the actual compiler (disable: Properties > Fortran > General > Suppress Startup Banner) and re-compile a single source file, or at least the version of the Intel Visual Fortran compiler integrations with Visual Studio accessible via: Help >About (under the MSVS IDE)
If it is convenient, you might also try a newer IVF 10.1 release (specifically 10.1.025) available from the Intel Registration here.
wg205
After some trials I found that I can watch global variables if the module where they are declared is plugged directly into subroutine instead of having use statement for whole module. eg
I can watch variables declared in config_module in such construction:
module boggitt_module
implicit none
contains
subroutine set_boggitt(idnode)
use config_module
implicit none
end subroutine set_boggitt
end module boggitt_module
and I can't do that if use statment is outside the subroutine:
use config_module
implicit none
contains
implicit none
In this way variables declared module wide are not watchable.
This solution: modname::varname in a watch window allows me to track module variables, although it is not that convenient like the ones for local variables.
Thanks for your help.
Up through version 10.1, you could not view "uplevel referenced" variables in the debugger. This is fixed in version 11.0, to be released in November.
Antoon
I am strugging with the same problem, all my global arrays are defined in a module, but I can't watch the arrays.
I moved the use assoc from the module header to the subroutine body (same as you did), but I still can't watch the global data, apart from inserting the module name before the array name. Does this work in general or is it by accident that you can watch now your data.
Any idea what I am doing wrong ?
Bye,
Antoon
sjors
Dear Steve,
I just tried the latest version of 11.0 (i.e. 11.0.066) to see whether this problem is indeed solved. Me and many of my collegues find it impractical not to be able to view "uplevel referenced" variables during debugging. Since we bought version 10.1 I could only install 11.0 only as an evaluation version, but the problem still seems to be present. Are additional settings required? And will there also be a fix for version 10.1?
Regards Arjen
The problem is fixed in 11.0. It's possible that you are not using the 11.0 compiler - go to Tools > Options > Intel Visual Fortran > Compilers and make sure that 11.0 is selected. This fix required major changes to several parts of the compiler and will not be retrofitted to 10.1.
If you have a test case where this still doesn't work, I'd like to see it.
eos_pengwern
I upgraded to V11.0 last week on the advice of Premier Support, precisely because of this issue. I found that, in V11.0, the issue was fixed for my simple test program which had a small number of variables held in a single module.
However, for my main application (a multi-module DLL), I find that I can view scalar module variables but not arrays. I have checked carefully to see that the V11.0 compiler is invoked, and the behavior is certainly different from before because in 10.1 I couldn't even view scalar module variables in the debugger.
I'm wondering if it's something to do with the fact that my project was automatically converted to a V11.0 project, whereas my test program was built as a 'native' V11.0 project. I suggested this possibility to Premier Support when I wrote up the issue on Tuesday last week, but so far I haven't heard back from them. For the time being I'm doing my normal workaround, which is to make local copies of allthe module variables that I want to watch. It's ugly, but it gets me there for now.
Conversion of the project is not relevant. Did you supply to Premier Support a test case that shows the problem in 11.0?
eos_pengwern
Not yet; I haven't been able to come up with a medium-size application that shows the problem; I'll send them the whole DLL if they ask, but only if they ask.
sjors
Dear Steve,
I already uninstalled the test version of 11.0 but I tried again, and it seems I checked a couple of global variables that were actually parameters; the rest seems to work fine. If we decide to switch from 10.1 to 11.0 we need to buy update support again, of which we just ran out. If I have to convince my manager to buy about 10 licenses I need to come up with a bit more than the ability to finally watch your global variables. The list of new features don't show me things that we specifically use, but I sometimes use the Module Wizard and we are interested in using the two CPU's of our duo core computers. The module wizard has been updated, but what are the differences? The answers to these questions might help me convince my manager to buy new support again, but if I should ask the questions somewhere else, let me know.
Cheers Arjen
I am not aware of any general changes to the Module Wizard. We did fix a problem (if I recall correctly) in the automation library where INTEGER*1 arguments were not supported.
We made a long list of improvements, including performance, as well as bug fixes in version 11. We're no longer fixing bugs in version 10.1 except for extremely serious problems that block major applications from building, so if you encounter problems with 10.1 your options will be limited (actually more limited since your support expired). You'll have to make the case to your manager as to whether or not to extend the support term.
alexrozen
We have checked this issue yesterday. After 10.1 -> 11.0 upgrade (10.1 compiler was totally uninstalled) we got out, that about half of module variablesare nowshowing their values during debug. But not all of them. I can't find the criteria.
I have attached the screenshot and the smalltest case.
alexrozen
FE1.F90
Quoting - alexrozen
Sorry, did not attached files in the previous message :(
Hmm - seems to work for me using 11.0.066.
alexrozen
Really strange... The same I have installed.
alexrozen
Ok. I have got the trick. Aftersolution rebuilding all began to work fine. The test case was imported from Fortran-10.1-charged PC, so it was my shame.
But now I have the sample with alittle more tricky behaviour. "Here it works, but there does not".
Interesting. I can reproduce that and will send it on to the developers for them to look at.
alexrozen
We still hope it to be fixed.
It will be fixed in the upcoming version 11.1.
