weird symbol in object file
happyocotber
Compile enclosed code with
ifort -c gendown3d_types.f90 Version 11 compiler
do a nm gendown3d_types.o
You get weird symbol gendown3d_types_mp_info_default_
from this code. How do you get rid of it? Or why is it there??
module gendown3d_types
integer, parameter :: status_init=0
integer, parameter :: mem_fixed_init=0
integer, parameter :: mem_n_w_inp_init=0
integer, parameter :: mem_n_mx_inp_init=0
integer, parameter :: mem_n_my_inp_init=0
integer, parameter :: mem_n_hx_inp_init=0
integer, parameter :: mem_n_hy_inp_init=0
type gendown3d_info_type
integer :: status
integer :: mem_fixed
integer :: mem_n_w_inp
integer :: mem_n_mx_inp,mem_my_inp
integer :: mem_n_hx_inp,mem_hy_inp
end type gendown3d_info_type
type(gendown3d_info_type), parameter :: info_default = gendown3d_info_type &
(status_init, &
mem_fixed_init, &
mem_n_w_inp_init, &
mem_n_mx_inp_init, &
mem_n_my_inp_init, &
mem_n_hx_inp_init, &
mem_n_hy_inp_init )
logical, parameter :: verb_init=.true.
logical, parameter :: debug1_init=.false.
logical, parameter :: debug2_init=.false.
logical, parameter :: timers_on_init=.false.
logical, parameter :: rho_filt_init=.false.
logical, parameter :: image_zero_offset_init=.true.
logical, parameter :: image_cig_init=.false.
logical, parameter :: k_domain_init=.true.
logical, parameter :: first_adj_init=.false.
logical, parameter :: first_add_init=.false.
logical, parameter :: check_stability_init=.false.
logical, parameter :: complex_image_init=.false.
logical, parameter :: synth_data_init=.false.
logical, parameter :: no_data_init=.false.
logical, parameter :: single_hx_dip_init=.false.
logical, parameter :: time_mig_init=.false.
! choices 'cons-slow' 'back_slow' 'full_slow' 'pert_slow'
character(len=128), parameter :: oper_type_init='full_slow'
character(len=128), parameter :: domain_range_init='slow_ima'
character(len=128), parameter :: cig_forw_transf_init='pull'
character(len=128), parameter :: amp_weights_init='none'
integer, parameter :: n_threads_init=-1
integer, parameter :: max_memory_init=134217728
integer, parameter :: non_data_memory_init=0
integer, parameter :: n_data_dim_init=4
integer, parameter :: n_mx_pad_init=-huge(1)/10.
integer, parameter :: n_my_pad_init=-huge(1)/10.
integer, parameter :: n_hx_pad_init=-huge(1)/10.
integer, parameter :: n_hy_pad_init=-huge(1)/10.
integer, parameter :: n_z_image_init=-1
integer, parameter :: n_w_block_init=-1
integer, parameter :: n_z_block_init=-1
integer, parameter :: i_block_z_restart_init=-1
real, parameter :: slow_const_init=-1.
real, parameter :: slow_const_image_init=-1.
real, parameter :: slow_const_image_z0_init=-1.
real, parameter :: slow_scale_init=1.
real, parameter :: stat_shift_init=0.
real, parameter :: max_propag_angle_init=89.
real, parameter :: z_image_0_init=-1.
real, parameter :: d_z_image_init=-1.
real, parameter :: t_spike_0_init=-1.
real, parameter :: mx_spike_0_init=huge(1.)/10.
real, parameter :: my_spike_0_init=huge(1.)/10.
real, parameter :: hx_spike_0_init=huge(1.)/10.
real, parameter :: hy_spike_0_init=huge(1.)/10.
real, parameter :: t_spike_1_init=-1.
real, parameter :: mx_spike_1_init=huge(1.)/10.
real, parameter :: my_spike_1_init=huge(1.)/10.
real, parameter :: hx_spike_1_init=huge(1.)/10.
real, parameter :: hy_spike_1_init=huge(1.)/10.
real, parameter :: px_plane_0_init=0.
real, parameter :: py_plane_0_init=0.
real, parameter :: px_plane_1_init=0.
real, parameter :: py_plane_1_init=0.
real, parameter :: freq_min_0_init=-1.
real, parameter :: freq_min_1_init=-1.
real, parameter :: freq_max_0_init=-1.
real, parameter :: freq_max_1_init=-1.
type gendown3d_param_type
logical :: verb
logical :: debug1
logical :: debug2
logical :: timers_on
logical :: rho_filt
logical :: image_zero_offset
logical :: image_cig
logical :: k_domain
logical :: first_adj
logical :: first_add
logical :: check_stability
logical :: complex_image
logical :: synth_data
logical :: no_data
logical :: single_hx_dip
logical :: time_mig
character(len=128) :: oper_type
character(len=128) :: domain_range
character(len=128) :: cig_forw_transf
character(len=128) :: amp_weights
integer :: n_threads
integer :: max_memory
integer :: non_data_memory
integer :: n_data_dim
integer :: n_mx_pad
integer :: n_my_pad
integer :: n_hx_pad
integer :: n_hy_pad
integer :: n_z_image
integer :: n_w_block
integer :: n_z_block
integer :: i_block_z_restart
real :: slow_const
real :: slow_const_image
real :: slow_const_image_z0
real :: slow_scale
real :: stat_shift
real :: max_propag_angle
real :: z_image_0
real :: d_z_image
real :: t_spike_0
real :: mx_spike_0
real :: my_spike_0
real :: hx_spike_0
real :: hy_spike_0
real :: t_spike_1
real :: mx_spike_1
real :: my_spike_1
real :: hx_spike_1
real :: hy_spike_1
real :: px_plane_0
real :: py_plane_0
real :: px_plane_1
real :: py_plane_1
real :: freq_min_0
real :: freq_min_1
real :: freq_max_0
real :: freq_max_1
end type gendown3d_param_type
end module gendown3d_types
Rgds,
CoolGeo
It's variable info_types declared in module gendown3d_types. The name is constructed by the compiler by concatenating the module name and the variable name, with _mp_ separating them. Why would you want to get rid of it?
