29390 Discussions
why automatic variables can not be compiled on Intel fortran compiler
r_zhang-2
I am using Intel Fortran compiler 32 bit for linux. In the process of running my model on linux, I alwasy encounter this kind of error message:
Syntax error, found END-OF-STATEMENT when expecting one of:
AUTOMATIC ::
That is because one of my subroutine variables are defined as AUTOMATIC.I check the Intel literature and it saysVersion 9.0 support automatic variables. And I also add some argument after command 'ifort', howeverit does not work.
I hope someone can give me some tips on this.
Thanks a lot.
Rui
What is the exact statement you are using and the exact compiler version?
Note that AUTOMATIC is an extension to the language. I seem to recall that in some earlier version, the compiler did not accept AUTOMATIC and STATIC as attributes. You could say:
AUTOMATIC X
but not:
AUTOMATIC :: X
Both should work in current versions.
r_zhang-2
Thanks for your quick reply!In my windows version of compaq Fortran compiler, I define the subroutine variables as belows:
INTEGER ITMAX
REAL tol,x1,x2,func,EPS
EXTERNAL func
PARAMETER (ITMAX=30,EPS=3.e-8)
INTEGER iter
REAL a,b,c,d,e,fa,fb,fc,p,q,r,s,tol1,xm
AUTOMATIC
Now i have to use Intel Fortran compiler for Linux to run my model.
My ifort version is:
-bash-3.00$ ifort --version
ifort (IFORT) 9.0 20051201
Copyright ( C) 1985-2005 Intel Corporation. All rights reserved.
And I am using:
ifort -automatic -I/home/s0340767/lib/fnlux04dcl/lib/nag_mod_dir file1.f90 file2.f90 -L/home/s0340767/lib/fnlux04dcl/lib -lnagfl90 -lcrypt -lpthread
to compile.
Thanks in advance.
Rui
Ah, I see.
It was a bug in CVF that the AUTOMATIC statement was allowed without any variables named. We fixed that bug in Intel Fortran. There is no defined meaning for just AUTOMATIC by itself.
If you want all local variables to be automatic, then use -automatic or add the RECURSIVE keyword to the routine declaration.
r_zhang-2
Hi, Steve,
Thanks for your reply.
I get rid of -automatic option in the command line, because I only want some of local variables automatic and I add recursive argument to the subroutine.It is compilable but the model come down to dead loop. I am wondering whether the order of the subroutines I call in the ifort command line is significant.
Thanks a lot.
Rui
No, the order is not significant as long as you don't have a dependency on .mod file generation.
r_zhang-2
Hi, Steve,
Thanks a lot for your kind help. The model is running ok on unix now.
Rui
