29488 Discussions
writing on a fixed line into a console
tropfen
is it possible to write on a fixed position into a console line? (Meaning no new line for each write(6,...))
If yes how?
Thanks in advance
Frank
Les_Neilson
Valued Contributor II
Have a look at the WRITE with Advance=NO option.
Does this do what you want?
Les
jparsly1
Here's one way using some of the routines provided with CVF. The GOTOXY
routine allows you to set the cursor position in the console window.Probably works
with IVF too, although the USE statements might be a little different...
call gotoxy(10,20)
write(*,*) 'row 10 column 20'
call gotoxy(20,10)
write(*,*) 'row 20, column 10'
read(*,*) ii
stop
end
subroutine gotoxy(irow,icol)
use dflib
use dfwin
integer fhandle
logical lstat
Type(T_COORD) wpos
fhandle = GetStdHandle(STD_OUTPUT_HANDLE)
wpos.x = icol
wpos.y = irow
lstat = SetConsoleCursorPosition(fhandle, wpos)
return
end
tropfen
Hello Les,
yes.
Your way will do it in 99% of the problems.
Frank
