x64 code behavior on Win7 & Win8
David_DiLaura1
Colleagues, Steve,
We have an application that is available in both IA-32 and x64 flavors. Engineering code with lots of math so we optimize as much as possible: using /O3 in both IA-32 and x64 compiles. The x64 bit version behaves differently on Win7 than on Win8.  The Win8 results are incorrect. The IA-32 version runs fine in both Win7 and Win8. How differently is the compiler behaving (regarding optimizations, say) when generating x64 code?
David
The compiler generates rather different code, since x64 has a different instruction set as well as more and wider registers. My guess as to the different behavior is probably an uninitialized variable, as otherwise there should not be Win7/Win8 differences.
Do you also use the /Qx or /Qax options to target newer processors? The default is Pentium 4/SSE2.
