29386 Discussions
xiar missing in intel-oneapi-compiler-shared-2025.0
rudi-gaelzer
The xiar tool (archive tool for IPO objects) was not distributed with the
intel-oneapi-compiler-shared-2025.0 rpm pack for Fedora linux.
It was present until  intel-oneapi-compiler-shared-2024.2 and stored in
/opt/intel/oneapi/compiler/2024.2/bin
Was this intentional?
Ron_Green
I should have remembered - xiar was used for the old Classic Compiler IPO generated objects and libraries.
for the new LLVM lto ( IPO ) binaries we have a ar tool in .../bin/compiler/llvm-ar
This recognizes our objects with Intel GPU offload kernel code along with the CPU code (fat objects)
Ron_Green
I am attempting to find our which rpm package has xiar.
But I am curious - you are extracting the RPMs from the installer and using the RPMs directly?  From what product download or repo package are you pulling?
rudi-gaelzer
Hi Ron.
I'm running Fedora Linux, so I'm using dnf to install/upgrade OneAPI.
The xiar app was provided by:
intel-oneapi-compiler-shared-2024.2-2024.2.1-1079.x86_64 : Intel(R) Compiler Shared Files
Repo         : @system
Matched From :
Filename     : /opt/intel/oneapi/compiler/2024.2/bin/xiar
I installed all OneAPI files with RPMs provided by the Yum/dnf repository, which I installed as per instructions in:
https://www.intel.com/content/www/us/en/docs/oneapi/installation-guide-linux/2025-0/yum-dnf-005.html#FORTRAN-YUM-DNF
$>cat /etc/yum.repos.d/oneAPI.repo
[oneAPI]
name=Intel(R) oneAPI repository
baseurl=https://yum.repos.intel.com/oneapi
enabled=1
gpgcheck=1
repo_gpgcheck=1
gpgkey=https://yum.repos.intel.com/intel-gpg-keys/GPG-PUB-KEY-INTEL-SW-PRODUCTS.PUB
I can use the GNU ar, no problem.  It's just that I was used to archive objects compiled with ifort/ifx using xiar.
Ron_Green
rudi-gaelzer
OK, found it.
The syntax is similar to the old xiar, I guess?
Ron_Green
yes, very similar.
But if you have older libraries and/or objects built with ifort -ipo then that older IPO format will not be recognized by llvm-ar and you will need an older copy of xiar to manipulate those older binaries.
rudi-gaelzer
Sorry to resume a discussion that was already considered solved, but  I only had time to come back to this issue now.
As I mentioned above, I have llvm-ar installed in
/opt/intel/oneapi/compiler/2025.0/bin/compiler
but the path to this directory is not set.
Could you help me out here?
Since always I have set the paths to intel compilers by inserting the line
source /opt/intel/oneapi/setvars.sh
in .bash_profile.
However, that is only setting the following paths in the system:
/opt/intel/oneapi/vtune/2025.0/bin64
/opt/intel/oneapi/mpi/2021.14/bin
/opt/intel/oneapi/mkl/2025.0/bin
/opt/intel/oneapi/dpcpp-ct/2025.0/bin
/opt/intel/oneapi/dev-utilities/2025.0/bin
/opt/intel/oneapi/debugger/2025.0/opt/debugger/bin
/opt/intel/oneapi/advisor/2025.0/bin64
The latest package that provides llvm-ar that I have installed in my system is:
intel-oneapi-openmp-2025.0-2025.0.4-1519.x86_64.rpm
Am I doing something wrong?
Ron_Green
The path is NOT added for a reason:  customers with a default Clang/LLVM installation want to use the LLVM tools from Clang, and not from Intel.  At least, that was their complaint when we added the bin/compiler path by default some years back.  So a user who wants to use the Intel supplied LLVM tools have to manually add this path.
rudi-gaelzer
Thank you.  I will set the path manually.
Ron_Green
a follow-on discussion was the suggestion to rename the Intel LLVM tools so there is no name clash with the Clang/LLVM tools - interesting idea, however it would require all users to change their Make and Cmake builds for every application.  This is a non-starter for customers.
