Intel® Graphics Performance Analyzers (Intel® GPA)
Improve your game's performance by quickly specifying problem areas
551 Discussions
CPU frequency increases with GPU used with Sandy-Bridge
edid_tx
We are using a core i7 Sandy-bridge with LINUX with the CPU frequency fixed (governor mode = user_space) at 1.2Ghz.
When we read the CPU frequency with /sys/devices/system/cpu/cpu*/cpufreq/cpuinfo_cur_freq we read 1.2Ghz
If we launch X server with "startx" command and after using the GPU, we see the cpu frequency raises to 1.6Ghz ! But if we set the CPU frequency from 1.6Ghz to 2.1Ghz the CPU, frequency remains at the value fixed (i.e 1.7Ghz)!
We don't used Turbo Boost, HT or others BIOS setting allowing to improvement of the CPU and/or GPU.
In all case I expected that the CPU Frequency could drop if GPU needs more perfomance and/or thermal management needs to decrease frequency but not increase the CPU frequency when this frequency is fixed by user.
Thanks for your help.
Seth_S_Intel
It looks like this may be the wrong place for this thread.  Are you using the Intel Graphics Performance Analyzers tool suite?
If not, I'll help you find the right place..
Best,
Seth
