Intel® Graphics Performance Analyzers (Intel® GPA)
Improve your game's performance by quickly specifying problem areas
536 Discussions
Can't run on OSX, application closes unexpectedly.
Linietsky__Juan
I can't run my application from Graphics Frame Analyzer (or any other from the performance tools). Application closes immediately and the follow error is visible. Running application from command line works perfect. How do I get my application to run on graphics frame analyzer?
Here is machine info:
OS:
Name: macOS 10.10.5 (build 14F27)
Locale: en_AR
CPU:
Architecture: x64
Cores count: 4
GPU:
Name: Intel HD Graphics 5000
Vendor id: 0x8086
Product id: 0xA26
Stepping: 9
Machine: Andrea’s Mac mini
Memory: 4096 MB
Screen: 1920x1080, 24 bit
GPA:
Version: 17.3.314655
This error appears as application immediately closes after running it.
Giselle_G_Intel
Hey Juan,
First of all, thank you for using our tool! I'm sorry you are currently experiencing issues with the tool, but I will get you back on track.
Have you tried launching the game using the Graphics Monitor, not Frame Analyzer? Do you see the same results in the scenario? Is the application you're profiling an OpenGL or Metal Application.
Linietsky__Juan
Hi Giselle, thanks for your answer.
I tried launching from Graphics Monitor, but the result is the same. Application closes two or three seconds after it opens. I am working with OpenGL.
If launched standalone, application works fine.
Giselle_G_Intel
Hey Juan,
I just looked at your OS version, and we unfortunately don't support anything below macOS* 10.12. This is most likely the cause of your issue. To profile OpenGL* and Metal* APIs, you need to be running either macOS 10.12 or 10.13
Linietsky__Juan
Giselle, thanks again for your answer. I upgraded to high sierra, but the problem persists.
Giselle_G_Intel
Hey Juan,
What is the exact workload you are trying to profile?
Linietsky__Juan
Compiled Godot Engine from scratch on OSX:
https://github.com/godotengine/godot
Which generates a 64-bit executable: godot.osx.tools.64
I selected the executable and the path to one of the demos (executable reads a config file from working directory).
When running it, it immediately closes. Running the executable manually from command line works fine.
Giselle_G_Intel
Juan,
I am going to try to reproduce this issue to determine the underlying issue. I will be in touch as soon as I am able to run Godot.
Linietsky__Juan
Alright , thanks a lot!
Giselle_G_Intel
Hey Juan,
I'm unable to recreate your issue. I think I used the precompiled version of the tool... did you create a ".app" version of the tool? It seems to work fine with the ".app" version. I didn't try it with the app within the bin however.
d__m
Giselle:
The problem was most likely caused by setting the "Address Sanitizer" option check under Runtime Sanitization in the Run scheme set to debug mode.
I am on OSX 10.12.6 with Xcode 8.3.3 running all versions of frame analyzer.
Turn off address sanitizer while you use Intel Frame Analyzer for OpenGL.
Here is my console capture:
Process:               skeleton [7410]
Path:                  /macdev/*/skeleton.app/Contents/MacOS/skeleton
Identifier:            com.rpzdesign.skeleton
Version:               1.0.7173 (7173)
Code Type:             X86-64 (Native)
Parent Process:        GpaServer [7409]
Responsible:           skeleton [7410]
User ID:               501
Date/Time:             2018-01-08 18:27:32.202 -0600
OS Version:            Mac OS X 10.12.6 (16G29)
Report Version:        12
Anonymous UUID:        51BA19C4-E73C-3BAF-B038-F26C0785551B
Time Awake Since Boot: 44000 seconds
System Integrity Protection: disabled
Crashed Thread:        0  Dispatch queue: com.apple.main-thread
Exception Type:        EXC_CRASH (SIGABRT)
Exception Codes:       0x0000000000000000, 0x0000000000000000
Exception Note:        EXC_CORPSE_NOTIFY
Application Specific Information:
==7410==ERROR: AddressSanitizer: heap-use-after-free on address 0x60200002ea50 at pc 0x00010d6bf305 bp 0x7fff52d13960 sp 0x7fff52d130f0
READ of size 1 at 0x60200002ea50 thread T0
    #0 0x10d6bf304 in wrap_strcmp (libclang_rt.asan_osx_dynamic.dylib:x86_64+0x11304)
    #1 0x114f8dfec  (libGLHUD.dylib:x86_64+0x5afec)
    #2 0x114f8d4a9  (libGLHUD.dylib:x86_64+0x5a4a9)
    #3 0x114f36c5a  (libGLHUD.dylib:x86_64+0x3c5a)
    #4 0x114f36961  (libGLHUD.dylib:x86_64+0x3961)
    #5 0x10d232e92  (OpenGL:x86_64+0x19e92)
    #6 0x10d232c11  (OpenGL:x86_64+0x19c11)
    #7 0x7fffa20d4873 in std::__1::__call_once(unsigned long volatile&, void*, void (*)(void*)) (libc++.1.dylib:x86_64+0x3c873)
    #8 0x10d22d9ef  (OpenGL:x86_64+0x149ef)
    #9 0x10d23764b  (OpenGL:x86_64+0x1e64b)
    #10 0x10d2373b0  (OpenGL:x86_64+0x1e3b0)
    #11 0x7fff8b70b27e in -[NSOpenGLContext initWithFormat:shareContext:] (AppKit:x86_64+0x32127e)
    #12 0x10cfea891 in -[Tglview initWithFrame:] Tappcocoa.mm:73
    #13 0x10cfa320f in Tapp::cbrun(int) Tapposx.mm:209
    #14 0x10d0c196f in main main.mm:7
    #15 0x7fffa3503234 in start (libdyld.dylib:x86_64+0x5234)
0x60200002ea50 is located 0 bytes inside of 7-byte region [0x60200002ea50,0x60200002ea57)
freed by thread T0 here:
    #0 0x10d7011c6 in wrap_free (libclang_rt.asan_osx_dynamic.dylib:x86_64+0x531c6)
    #1 0x114f8dfdd  (libGLHUD.dylib:x86_64+0x5afdd)
previously allocated by thread T0 here:
    #0 0x10d700ffc in wrap_malloc (libclang_rt.asan_osx_dynamic.dylib:x86_64+0x52ffc)
    #1 0x114f8dfbf  (libGLHUD.dylib:x86_64+0x5afbf)
SUMMARY: AddressSanitizer: heap-use-after-free (libclang_rt.asan_osx_dynamic.dylib:x86_64+0x11304) in wrap_strcmp
Shadow bytes around the buggy address:
  0x1c0400005cf0: fa fa fd fd fa fa fd fd fa fa fd fd fa fa fd fd
  0x1c0400005d00: fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa
  0x1c0400005d10: fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa
  0x1c0400005d20: fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa
  0x1c0400005d30: fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa
=>0x1c0400005d40: fa fa fa fa fa fa fa fa fa fa[fd]fa fa fa fd fd
  0x1c0400005d50: fa fa fd fa fa fa fd fd fa fa fd fa fa fa fd fd
  0x1c0400005d60: fa fa fd fa fa fa fd fd fa fa fd fa fa fa fd fd
  0x1c0400005d70: fa fa fd fd fa fa fd fa fa fa fd fa fa fa 00 fa
  0x1c0400005d80: fa fa 00 00 fa fa fd fa fa fa 00 00 fa fa fd fa
  0x1c0400005d90: fa fa 00 fa fa fa 00 fa fa fa fd fd fa fa fd fa
Shadow byte legend (one shadow byte represents 8 application bytes):
  Addressable:           00
  Partially addressable: 01 02 03 04 05 06 07
  Heap left redzone:       fa
  Freed heap region:       fd
  Stack left redzone:      f1
  Stack mid redzone:       f2
  Stack right redzone:     f3
  Stack after return:      f5
  Stack use after scope:   f8
  Global redzone:          f9
  Global init order:       f6
  Poisoned by user:        f7
  Container overflow:      fc
  Array cookie:            ac
  Intra object redzone:    bb
  ASan internal:           fe
  Left alloca redzone:     ca
  Right alloca redzone:    cb
==7410==ABORTING
abort() called
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0   libsystem_kernel.dylib        0x00007fffa3631d42 __pthread_kill + 10
1   libsystem_pthread.dylib        0x00007fffa371f457 pthread_kill + 90
2   libsystem_c.dylib              0x00007fffa3597420 abort + 129
3   libclang_rt.asan_osx_dynamic.dylib 0x000000010d721c16 __sanitizer::Abort() + 70
4   libclang_rt.asan_osx_dynamic.dylib 0x000000010d71d738 __sanitizer::Die() + 120
5   libclang_rt.asan_osx_dynamic.dylib 0x000000010d706097 __asan::ScopedInErrorReport::~ScopedInErrorReport() + 311
6   libclang_rt.asan_osx_dynamic.dylib 0x000000010d705b08 __asan::ReportGenericError(unsigned long, unsigned long, unsigned long, unsigned long, bool, unsigned long, unsigned int, bool) + 344
7   libclang_rt.asan_osx_dynamic.dylib 0x000000010d6bf330 wrap_strcmp + 976
8   libGLHUD.dylib                0x0000000114f8dfed 0x114f33000 + 372717
9   libGLHUD.dylib                0x0000000114f8d4aa 0x114f33000 + 369834
10  libGLHUD.dylib                0x0000000114f36c5b 0x114f33000 + 15451
11  libGLHUD.dylib                0x0000000114f36962 0x114f33000 + 14690
12                                0x000000010d232e93 0x10d219000 + 106131
13                                0x000000010d232c12 0x10d219000 + 105490
14  libc++.1.dylib                0x00007fffa20d4874 std::__1::__call_once(unsigned long volatile&, void*, void (*)(void*)) + 139
15                                0x000000010d22d9f0 0x10d219000 + 84464
16                                0x000000010d23764c 0x10d219000 + 124492
17                                0x000000010d2373b1 0x10d219000 + 123825
18  com.apple.AppKit              0x00007fff8b70b27f -[NSOpenGLContext initWithFormat:shareContext:] + 80
19  com.rpzdesign.skeleton        0x000000010cfea892 -[Tglview initWithFrame:] + 2130 (Tappcocoa.mm:73)
20  com.rpzdesign.skeleton        0x000000010cfa3210 Tapp::cbrun(int) + 8736 (Tapposx.mm:209)
21  com.rpzdesign.skeleton        0x000000010d0c1970 main + 48 (main.mm:8)
22  libdyld.dylib                  0x00007fffa3503235 start + 1
Thread 1:
0   libsystem_kernel.dylib        0x00007fffa363244e __workq_kernreturn + 10
1   libsystem_pthread.dylib        0x00007fffa371c621 _pthread_wqthread + 1426
2   libsystem_pthread.dylib        0x00007fffa371c07d start_wqthread + 13
Thread 2:
Thread 3:
Thread 4:
0   libsystem_kernel.dylib        0x00007fffa3631f46 __semwait_signal + 10
1   libsystem_c.dylib              0x00007fffa35b8b72 nanosleep + 199
2   libc++.1.dylib                0x00007fffa20e065b std::__1::this_thread::sleep_for(std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l> > const&) + 80
3   com.rpzdesign.skeleton        0x000000010cf87f9e void std::__1::this_thread::sleep_for<long long, std::__1::ratio<1l, 1000l> >(std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000l> > const&) + 9358 (thread:443)
4   com.rpzdesign.skeleton        0x000000010d0c58de Tapp::texturethread() + 958 (Tappthreadtexture.cpp:18)
5   com.rpzdesign.skeleton        0x000000010cfb1280 void* std::__1::__thread_proxy<std::__1::tuple<void (Tapp::*)(), Tapp*> >(void*) + 1616 (__functional_base:383)
6   libsystem_pthread.dylib        0x00007fffa371c93b _pthread_body + 180
7   libsystem_pthread.dylib        0x00007fffa371c887 _pthread_start + 286
8   libsystem_pthread.dylib        0x00007fffa371c08d thread_start + 13
Thread 5:
4   com.rpzdesign.skeleton        0x000000010cff6808 Tapp::evtthread() + 5944 (Tappthreadevent.cpp:37)
Thread 6:
4   com.rpzdesign.skeleton        0x000000010cf956dc Tapp::updatethread() + 1180 (Tappthreadupdate.cpp:17)
Thread 7:
4   com.rpzdesign.skeleton        0x000000010cf9e494 Tapp::udpthread() + 916 (Tappthreadudp.cpp:12)
Thread 8:
4   com.rpzdesign.skeleton        0x000000010d0c2644 Tapp::taskthread() + 916 (Tappthreadtask.cpp:12)
Thread 9:
1   libsystem_pthread.dylib        0x00007fffa371c48e _pthread_wqthread + 1023
Thread 10:
0   libsystem_kernel.dylib        0x00007fffa362a34a mach_msg_trap + 10
1   libsystem_kernel.dylib        0x00007fffa3629797 mach_msg + 55
2   com.apple.CoreFoundation      0x00007fff8d939874 __CFRunLoopServiceMachPort + 212
3   com.apple.CoreFoundation      0x00007fff8d938cf1 __CFRunLoopRun + 1361
4   com.apple.CoreFoundation      0x00007fff8d938544 CFRunLoopRunSpecific + 420
5   com.apple.CoreFoundation      0x00007fff8d977d31 CFRunLoopRun + 97
6                                  0x000000010d5b9dbb 0x10d219000 + 3804603
7                                  0x000000010d5ba46d 0x10d219000 + 3806317
8   libsystem_pthread.dylib        0x00007fffa371c93b _pthread_body + 180
9   libsystem_pthread.dylib        0x00007fffa371c887 _pthread_start + 286
10  libsystem_pthread.dylib        0x00007fffa371c08d thread_start + 13
Thread 11:
0   libsystem_kernel.dylib        0x00007fffa362a452 syscall_thread_switch + 10
1   libsystem_platform.dylib      0x00007fffa37152f0 _OSSpinLockLockYield + 103
2   libclang_rt.asan_osx_dynamic.dylib 0x000000010d715c10 __sanitizer::BlockingMutex::Lock() + 32
3   libclang_rt.asan_osx_dynamic.dylib 0x000000010d71ca68 __sanitizer::ThreadRegistry::CreateThread(unsigned long, bool, unsigned int, void*) + 40
4   libclang_rt.asan_osx_dynamic.dylib 0x000000010d709c8e __asan::AsanThread::Create(void* (*)(void*), void*, unsigned int, __sanitizer::StackTrace*, bool) + 206
5   libclang_rt.asan_osx_dynamic.dylib 0x000000010d6f7c7f wrap_pthread_create + 335
6                                  0x000000010d226a82 0x10d219000 + 55938
7                                  0x000000010d5a2e04 0x10d219000 + 3710468
8                                  0x000000010d5a623e 0x10d219000 + 3723838
9                                  0x000000010d5a440a 0x10d219000 + 3716106
10                                0x000000010d227673 0x10d219000 + 58995
11                                0x000000010d227106 0x10d219000 + 57606
12                                0x000000010d22a7c6 0x10d219000 + 71622
13  libsystem_pthread.dylib        0x00007fffa371c93b _pthread_body + 180
14  libsystem_pthread.dylib        0x00007fffa371c887 _pthread_start + 286
15  libsystem_pthread.dylib        0x00007fffa371c08d thread_start + 13
Thread 12:
0   libsystem_kernel.dylib        0x00007fffa3631eb6 __select + 10
1                                  0x000000010d5ddc68 0x10d219000 + 3951720
2                                  0x000000010d5a3f4a 0x10d219000 + 3714890
3                                  0x000000010d227106 0x10d219000 + 57606
4                                  0x000000010d22a7c6 0x10d219000 + 71622
5   libsystem_pthread.dylib        0x00007fffa371c93b _pthread_body + 180
6   libsystem_pthread.dylib        0x00007fffa371c887 _pthread_start + 286
7   libsystem_pthread.dylib        0x00007fffa371c08d thread_start + 13
Thread 13:
2                                  0x000000010d5db000 0x10d219000 + 3940352
3                                  0x000000010d590394 0x10d219000 + 3634068
4                                  0x000000010d227106 0x10d219000 + 57606
5                                  0x000000010d22a7c6 0x10d219000 + 71622
Thread 14:
0   libsystem_kernel.dylib        0x00007fffa362a43a swtch_pri + 10
1   libsystem_pthread.dylib        0x00007fffa371d479 sched_yield + 11
2   libclang_rt.asan_osx_dynamic.dylib 0x000000010d715639 __sanitizer::internal_sched_yield() + 9
3   libclang_rt.asan_osx_dynamic.dylib 0x000000010d6f7cd5 asan_thread_start(void*) + 21
4   libsystem_pthread.dylib        0x00007fffa371c93b _pthread_body + 180
5   libsystem_pthread.dylib        0x00007fffa371c887 _pthread_start + 286
6   libsystem_pthread.dylib        0x00007fffa371c08d thread_start + 13
Thread 0 crashed with X86 Thread State (64-bit):
  rax: 0x0000000000000000  rbx: 0x0000000000000006  rcx: 0x00007fff52d123c8  rdx: 0x0000000000000000
  rdi: 0x0000000000000307  rsi: 0x0000000000000006  rbp: 0x00007fff52d123f0  rsp: 0x00007fff52d123c8
   r8: 0x000000010dbcfe30   r9: 0x0000000000000011  r10: 0x0000000008000000  r11: 0x0000000000000206
  r12: 0x000060200002ea50  r13: 0x00007fff52d130f0  r14: 0x00007fffac46e3c0  r15: 0x000000010d97ddf0
  rip: 0x00007fffa3631d42  rfl: 0x0000000000000206  cr2: 0x00007fffac450128
Logical CPU:     0
Error Code:      0x02000148
Trap Number:     133
