Intel® Graphics Performance Analyzers (Intel® GPA)
Improve your game's performance by quickly specifying problem areas
Capture failed: Preview image conversion failed
Tobias_T_
Intel GPA is quite impressive, one of the best tools I've recently found :)
Unfortunately, I'm unable to capture a frame in my own DirectX 11 application (for testing reasons I deleted all code except the DirectX Initialization and Present). It always fails with the message "Preview image conversion failed" and the following log:
[00002d04] 16:52:46:641 |    INFO |     INTERCEPTOR | InterceptorDll.cpp:68    | GPA shim DLL attached.
[00002d04] 16:52:47:416 |    INFO |         CAPTURE | ShimMgt\CaptureManager.cpp:824   | D3D11 device context 00C9CBD4 created
[00002d04] 16:52:47:525 |    INFO |     INTERCEPTOR | ShimMgt\CaptureManager.cpp:3101  | Initializing Metrics Pipeline: ok
[00002d04] 16:52:50:620 |    INFO |         CAPTURE | ShimMgt\CaptureManager.cpp:3906  | Frame capture requested: C:\Users\Tobias\Documents\GPA\PostEffects_2016_09_07__16_52_50_615.gpa_frame
[00002d04] 16:52:50:620 |    INFO |         CAPTURE | ShimMgt\CaptureManager.cpp:859   | Start capture
[00002d04] 16:52:50:653 |    INFO |         CAPTURE | ShimMgt\CaptureManager.cpp:3924  | Capture message: Preview image conversion failed
[00002d04] 16:52:55:724 |    INFO |         CAPTURE | ShimMgt\CaptureManager.cpp:3906  | Frame capture requested: C:\Users\Tobias\Documents\GPA\PostEffects_2016_09_07__16_52_55_712.gpa_frame
[00002d04] 16:52:55:724 |    INFO |         CAPTURE | ShimMgt\CaptureManager.cpp:859   | Start capture
[00002d04] 16:52:55:767 |    INFO |         CAPTURE | ShimMgt\CaptureManager.cpp:3924  | Capture message: Preview image conversion failed
I tried it in other applicatiosn and there it works perfectly, such as World of Warcraft oder Starcraft 2. When I use DirectX 9 in my Application it works too. Under DirectX 11 the HUD is even showing and I can see the graphs running and use the debug option. Only the frame capture doesn't work.
Do you have any directions for me?
Thanks in advance!
Seth_S_Intel
Hi Tobias,
Sorry for the late response!
I have a couple workarounds you can try for frame capturing:
  • Try disabling "tracing" and trying a frame capture again.  Graphics monitor -> Profiles -> Tracing -> Disable Tracing
  • Try to inject with  "auto-detect launched application".  Graphics monitor -> Preference -> auto-detect launched applicatio
Also, If you could post your about dialog here so I can see what driver version and version of GPA you are using, that would be great.
If these workarounds do not work for you, we might need to get a copy of your application so we can reproduce the issue here.
Cheers!
Seth
Tobias_T_
Hi Seth,
I finally got it working today, while I was assembling the files to upload for you. The reason was a unused import of the DirectX 9 headers, which statically linked the DLLs into the application. I have no idea why this prevented the Graphics Monitor from capturing, but now with lazy loading everything works fine! It's curious that if I used DirectX 9 for rendering it worked, but with DirectX 11 and loaded DirectX 9 not.
If you want to track down this issue nevertheless, I've added all information you requested:
The workarounds didn't worked for me, nothing happened.
My About dialog:
Windows 10 build 10586, 64-bit DEP enabled
Num Processors: 4
Memory: 8111MB
System BIOS: American Megatrends Inc. P1.60 (07/03/2013)
Video BIOS: Version 80.04.C3.00.13  (06/06/13)
Driver 0:
     Device: NVIDIA GeForce GTX 770
     Provider: NVIDIA
     Date: 8-25-2016
     Version: 21.21.13.7270
     VendorId: 10de
     ProductId: 1184
     Stepping: a1
     No support for GPA Instrumentation
Install directory: C:\Program Files\IntelSWTools\GPA_16.2\
Version: 16.2.299487
Current user is in Administrators group: YES
Current Graphics Performance Analyzers 2016 R2 (16.2.299487)
Secure Boot/Trusted Boot is Disabled
And finally two reduced applications, one working one not:
https://drive.google.com/open?id=0B3HWSqf3Ke-mQVhjdi1FbEsxOXc
Thanks!
Tobias
Seth_S_Intel
Great!  Glad to hear that everything is working now!
I have a couple ideas of why this could have failed.  I'l grab  your apps and I'll see if we can get a fix in for this.
Anyway, i'm glad you are unblocked. :)
Cheers,
Seth
