Intel® Graphics Performance Analyzers (Intel® GPA)
Improve your game's performance by quickly specifying problem areas
DirectX 9, vertex shader constants
Stan_B_
I am looking at a series of ergs which set vertex shader constants, and I am not sure if GPA is displaying vertex shader constants correctly. For example, in the video below I am looking at 3 ergs in which the constant c7 is set to 0 in the Vertex Shader Constants tab though there is no SetVertexShaderConstantF that modifies that register. Am I missing something?
https://youtu.be/vImG1YzMJsI
Graphics Frame Analyzer for DirectX
Copyright: © 2007-2015 Intel Corporation. All rights reserved.
Version: 15.3.262022
Host IP: 127.0.0.1
Capture File
File Name: C:\Users\sbobovyc\Documents\GPA_2015_R3\GameJABiA_2015_09_18__22_30_45_565.gpa_frame
App Name: GameJABiA.exe
Graphics API: DX9
Frame Number: 2179
File Size: 221.5 MB
Information of the System on which the Frame was Captured
File Capture Date: 2015/9/18
Windows 7 build 7601, 64-bit DEP enabled
Num Processors: 4
Memory: 16328MB
System BIOS: American Megatrends Inc. 1802 (05/14/2013)
Video BIOS: Version 80.04.C4.00.62  (08/08/13)
Driver 0:
     Device: NVIDIA GeForce GTX 760
     Provider: NVIDIA
     Date: 8-25-2015
     Version: 10.18.13.5582
     VendorId: 10de
     ProductId: 1187
     Stepping: a1
     No support for GPA Instrumentation
(GPA software not installed)
Current user is in Administrators group: YES
Playback System Information
Num Processors: 4
Memory: 16328MB
Driver 0:
     Provider: NVIDIA
     Date: 9-13-2015
     Version: 10.18.13.5598
     VendorId: 10de
     ProductId: 1187
     Stepping: a1
Install directory: C:\Intel\INDE\GPA\2015 R3\
Seth_S_Intel
Hi sbobovyc,
Thank you for the incredibly detailed post and video.  This will help reproducing what you are seeing.
From your video it does look like there may be an issue.  I'll have a developer look at it, I could be missing something as well.
Also,  would it be possible to private message me a link to your frame file?  It may help the devs out if there does end up being an issue.
Cheers!
Seth
Seth_S_Intel
Hi Sbobovyc,
I received your frame file.   I'll add it to the defect and let you know what we find.
Thanks!
Seth
