Intel® Graphics Performance Analyzers (Intel® GPA)
Improve your game's performance by quickly specifying problem areas
Fatal Error when frame capturing UE5 DX12
hfive
1.UnrealEngine 5
2.dx12
3.Run GPA Frame Capture
You get "Fatal Error" message popup
Use GPA Stream Capture, can open,but cannot open single frame(an internal error has occurred.)
please help me.thanks.
Pamela_H_Intel
Hello hfive,
Often that sort of issue happens when either your driver is not updated, or you are using something we don't support.
Are you capturing from the GPA plugin in UE?
  • If yes, please provide your platform and GPA version info.
If not, are you capturing from Graphics Monitor?
  • Please provide the info in the "i" panel (from the top of Graphics Monitor).
Check if your driver needs updating?
Pamela
