Intel® Graphics Performance Analyzers (Intel® GPA)
Improve your game's performance by quickly specifying problem areas
554 Discussions
Frame Analyzer does not show application console output
Fredrik_S_
As the title states. This makes it very difficult to debug a crash that only happens when running your application from inside Frame Analyzer.
Putting this under "bug reports", as I think its such a neccessity of a feature.
Ryan_G_Intel
HI Fredrik,
I am sorry you are running into trouble using GPA and thanks for the suggestion.  If I am understanding you correctly, when you attempt to inject GPA into your workload, your workload crashes.  Can I ask which workload and GPA version your are using so we can replicate your issue over here.
If you are on a Windows platform, I can suggest checking to Documents/GPA/ folders for a MonitorLog.txt file or there is a Log folder there which may contain some logs on your issue.  Windows event viewer may also contain some information.
