Intel® Graphics Performance Analyzers (Intel® GPA)
Improve your game's performance by quickly specifying problem areas
GPA 4: Install Problem
alanlawrance
Just downloaded GPA, and for some reason I get this each time I run setup.exe:
I've done everything I can think of to rule out the possibility of another install taking place.
Help, I was looking forward to trying the GPA out!
alanlawrance
Turns out I did in fact have some rogue install processes going, even after a reboot.
GPA installed fine after killing those off.
Neal_Pierman
Valued Contributor I
Glad that you were able to install GPA successfully!
Please let us know about your experiences using the product.
Neal
Neal_Pierman
I think I may have run into the same issue myself the other day, and it occured when I was using Microsoft Remote Desktop* to connect to the machine where I was installing Intel GPA. (As you can imagine, I have lots of machines that I use for testing purposes, so Remote Desktop and VNC get lots of usage!).
Though this should be an OK install, I did run into issues where I had to manually kill the installer process even after a reboot.
Does this describe your issue as well? Any info you can provide that would help others from running into the same install issue would be appreciated.
Neal
ps-> I have also let our install team know about this; I'll let you know whether there's anything they have to say about the issue
