Intel® Graphics Performance Analyzers (Intel® GPA)
Improve your game's performance by quickly specifying problem areas
535 Diskussionen
Graphics Monitor freezing programs on startup
D-EFF
Anfänger
4.859Aufrufe
I've been using graphics monitor with no issue for about a year up until a few days ago, but now when I try to start a program with graphics monitor on auto-detect it freezes it on startup and has to be forced to close through external methods. i'm at a loss as to why this happens as nothing has changed on my pc between now and a few days ago to my knowledge.
1 Lösung
D-EFF
Anfänger
4.577Aufrufe
Sorry for some reason it wouldn't let me respond to your dm.
https://www.mediafire.com/file/4990i2mkpfctfan/5.25-Steam.rar/file
head to your steam root folder and delete everything except the config, userdata, depotcache, steamapps folders and unzip this in and youll be on an old version with updates disabled
Lösung in ursprünglichem Beitrag anzeigen
17 Antworten
sentientSpark_Intel
4.732Aufrufe
Hi D-EFF,
Thank you for your post!
If I understand the issue correctly, applications are freezing on startup when attached with Graphics Monitor when auto-detect on. We are sorry you are experiencing this, and someone on our team is working on reproducing this issue. In order to provide the most accurate assistance on this matter, I'd like to confirm a few details:
What is the game/application you are attempting to playback? Would you be able to share it with us?
Could you share the stream information? (accessible using the (i) icon in the top right hand corner of the screen, see picture below)
Thanks, and I look forward to hearing from you.
D-EFF
Anfänger
4.722Aufrufe
Thank you for responding, for the record, this issue occurs when trying to launch any game with graphics monitor attached, auto detect or not.
The last time i used it with no issue was december 2nd, and i only noticed i was unable to use it on december 5th.
Operating System:
Name: Windows 10 Version 2009 (OS Build 19045.5198)
Locale: en-US
Windows Developer Mode is enabled
Secure Boot/Trusted Boot is disabled
CPU Information:
Name: AMD Ryzen 5 5600G with Radeon Graphics
Architecture: x64
Cores count: 12
System BIOS:
Version: AMI F.02
Date: 03/11/2022
GPU #1 Information:
Name: NVIDIA GeForce RTX 3060 Ti
Vendor id: 0x10DE
Product id: 0x2489
Stepping: 161
Driver Version: 32.0.15.6614
Driver Date: 11-6-2024
GPU #2 Information:
Name: AMD Radeon(TM) Graphics
Vendor id: 0x1002
Product id: 0x1638
Stepping: 201
Driver Version: 31.0.21910.11004
Driver Date: 6-24-2024
Machine:
Memory: 15711 MB
Screen: 2560x1440, 32 bit
Graphics Performance Analyzers:
Version: 24.3.1725959380
Commit hash: 41eed44a
Installation folder: E:\IntelGPA\
sentientSpark_Intel
4.685Aufrufe
Thanks for sharing the stream information and the additional context. I will pass this along to our team.
I will reach back out to you when I have more information to share regarding this issue!
D-EFF
Anfänger
4.673Aufrufe
I believe i've indentified the issue as Steam's recent update flagging it as piracy software. downgrading steam allows it to work normally again.
sentientSpark_Intel
4.658Aufrufe
Thanks for updating us with the latest status D-EFF.
I'm happy to hear that you found a solution!
I attempted to reproduce the issue you discovered using Intel GPA 2024.4 (which will be released in the future) using a Steam update from December 2nd on DirectX 11 and DirectX 12 titles. I was able to capture normally however and did not encounter the application hanging and not responding on startup.
We are interested as to how this situation occurred. If you have any other information that you think may be relevant regarding your pc environment, or if you are able to use the newest builds of steam again for your frame analysis needs please let us know. We are glad you were able to get your GPA usage unblocked!
west_f
Anfänger
4.632Aufrufe
I'd like to chime in on this discussion because I've noticed the same issue. I also came to the conclusion that the issue lies with the Dec 3 steam update, but I also noticed that only some titles seem to be affected (or I was simply unable to get GPA to hook on the correct application and can't say for sure that it affects all titles).
You said that you got it to work on an update from Dec 2, but is that the newest and most recent update from steam? Have you successfully got it to work within the last week?
D-EFF
Anfänger
4.608Aufrufe
I had to downgrade to an older version of steam
D-EFF
Anfänger
4.578Aufrufe
west_f
Anfänger
4.544Aufrufe
Ah cool thanks, I got it to run as well now. I just hope that steam will fix this in the future...
sentientSpark_Intel
4.478Aufrufe
Hi west_f,
I'm glad you got the downgrade steps for steam in order to solve your issue. Thanks D-EFF!
Would you be able to provide names of titles that you found to be affected with the Dec 3 steam update?
We'd like to reproduce this issue so we can track it in the future.
Cheers!
west_f
Anfänger
4.353Aufrufe
I started looking into this a little. It seems like not every game is affected, and some modes are not affected as well. It also seems to depend on whether the game runs with DX11 or DX12 and if you start frame capture in DX11/12.
So what I found is this (very limited library):
Games unaffected:
-Manor Lords
-Deep Rock Galactic
-Witcher 2
Games affected in DX11 Frame Capture mode:
-Conan Exiles
-Insurgency Sandstorm
-Wayfinder
Some of these games were able to start in DX12 capture mode, but quickly crashed soo afterwards. None of them were affected when acpturing streams or traces. All of these issues still persists with the 24.4 update.
I hope this helps in the future.
sentientSpark_Intel
4.124Aufrufe
Thank you very much for investigating this issue west_f.
We have documented this and are grateful for the time you spent to help us better understand and hopefully reproduce this issue.
Cheers and happy new year!
whatgoat
Einsteiger
3.956Aufrufe
I worked a bit with EFF on troubleshooting this initially, so I'm not sure which titles he tried, but i can at least confirm the following are affected:
GUILTY GEAR -STRIVE-
GUILTY GEAR Xrd REV 2
Granblue Fantasy Versus: Rising
Street Fighter 6
DNF Duel
sentientSpark_Intel
3.861Aufrufe
Thank you very much for the additional details whatgoat.
Thanks to the detailed information you all have shared, we have been able to reproduce the issue in DX11 Frame Mode and a fix is in progress. We appreciate your assistance!
sentientSpark_Intel
3.758Aufrufe
HI whatgoat,
A hotfix just went live today on the official Intel GPA download link.
This update should resolve the issue you have encountered with Graphics Monitor freezing programs launched from newer builds of the Steam client. It also fixes Graphics Monitor Server crashes which some customers have encountered.
sentientSpark_Intel
3.759Aufrufe
HI west_f,
sentientSpark_Intel
3.759Aufrufe
HI D-EFF,
Antworten
