Intel® Graphics Performance Analyzers (Intel® GPA)
Improve your game's performance by quickly specifying problem areas
Intel GPA 2015: functionality
Ernest_B_
Hello!
I'n using Intel GPA Graphics Monitor for capturing frames.
Please add function for taking frames from a running 3D-application.
Intel GPA works great! Thanks.
Seth_S_Intel
Hi Ernest,
There actually is this functionality already!
To inject into a running application you can do these steps:
1. Turn on "auto detection" - right click graphics monitor in your task tray -> preferences -> check "auto-detect launched applications" (notice graphics monitor will turn greenish)
2. start your D3D application and the HUD should be working.
3. capture frames and proceed as normal.
Let me know if you have any questions!
Best,
Seth
Ernest_B_
I'm sorry, I mean a function for taking frames from already started (running) D3D application
Also, Is that possible to inject Frame Capturing HUD manually using third-party advanced injectors?
Seth_S_Intel
Hi Ernest,
Unfortunately it's not possible for us to inject into a running application with GPA, even with a third-party injector.
What use case are you looking at that won't let you first start GPA and then the application?  Maybe if I understand why you need this functionality, I can help you find a workaround.
Best,
Seth
