Intel® Graphics Performance Analyzers (Intel® GPA)
Improve your game's performance by quickly specifying problem areas
550 Discussions
OpenSharedHandle called with unrecognized handle
oulouis
Stream capture functions properly without deferred=true, but fails with errors when using --layer capture:deferred=true. How can I resolve this issue?
PS D:\Program Files\IntelSWTools\GPA Framework\25.1\bin\Release> .\gpa-injector.exe --layer hud-layer --layer capture:deferred=true <path>
Error Log:
[GPA] I 20780 D3D11 Device detected - for NVIDIA GeForce RTX 2060
StageLoadMpk:load_meta {status: {sort_version: <sorted_version>, essential_list_md5: 447fe552f1d8afab893a2eddb91a4fd4, compact_list: [], verifying_list: []}}
StageLoadMpk:start_load #mpk_info_row=476834 #bg_info_row=0 #pak_info_row=320 #increment=false #filter=0
Detected D3D11VideoDeviceDetected D3D11VideoContext[GPA] E 20780 C:\jenkins\workspace\GPA_FW_Release\src\layers\capture\directx12-custom.cpp(509): error: void __cdecl gpa::capture_layer::directx::Pre_OpenSharedHandle(void **) | found && "OpenSharedHandle called with unrecognized handle"
My system info:
Operating System:
Name: Windows 11 Version 24H2 (OS Build 26100.3775)
Locale: zh-CN
Windows Developer Mode is enabled
Secure Boot/Trusted Boot is enabled
CPU Information:
Name: Intel(R) Core(TM) i7-9750H CPU @ 2.60GHz
Architecture: x64
Cores count: 12
System BIOS:
Version: American Megatrends Inc. E16Q4IMS.118
Date: 05/18/2020
GPU #1 Information:
Name: GPU 0: Intel(R) UHD Graphics 630
Vendor id: 0x8086
Product id: 0x3E9B
Driver Version: 31.0.101.2115
Driver Date: 11-16-2022
GPU #2 Information:
Name: GPU 1: NVIDIA GeForce RTX 2060
Vendor id: 0x10DE
Product id: 0x1F11
Stepping: 161
Driver Version: 32.0.15.7283
Driver Date: 3-14-2025
Machine:
Memory: 32612 MB
Screen: 2560x1080, 32 bit
Graphics Performance Analyzers:
Version: 25.1.1741362025
Commit hash: 1ab9e2bc
Installation folder: D:\Program Files\IntelSWTools\GPA\
sentientSpark_Intel
Hi oulouis,
Thank you for your post, and I'm sorry to hear that you are encountering this issue during deferred capture using Intel GPA Framework.
We would like to investigate this issue more closely. To properly diagnose and resolve the problem, examining your application’s source code would be very helpful. This will give us a clearer understanding of the factors leading to the crash.
If you’re able to share the source code, please let us know your preferred method for sending the files. Feel free to also point out any specific code sections.
Looking forward to hearing from you.
