Intel® Graphics Performance Analyzers (Intel® GPA)
Improve your game's performance by quickly specifying problem areas
Playback error
MoLo1012
Unable to open frame. Error requesting GpaPlayer to open the selected frame.Most likely GpaPlayer crashed during playback. Playback progress: 100%. lfthe issue persists, please contact Intel customer support. Can you tell me where the logs are stored
sentientSpark_Intel
Hello MoLo1012,
Thank you for your post! In order to provide the most accurate assistance on this matter, I'd like to confirm a few details:
What is the game/application you are attempting to playback? Would you be able to share it with us?
Could you share the stream information? (accessible using the (i) icon in the top right hand corner of the screen, see picture below)
And to answer your question, a playback crash such as this doesn't generate logs. You could try to playback using Intel GPA Framework (which Intel GPA uses to capture and playback streams among other things) if you would like more verbose output in regards to failures.
