Intel® Graphics Performance Analyzers (Intel® GPA)
Improve your game's performance by quickly specifying problem areas
Select multiple options
Smith__Mike
Can we have the ability to select multiple options (No Cull and No Alpha blending etc) at the same time? It would help a lot with my program.
Giselle_G_Intel
Hey Mike,
Thank you for using Intel® GPA for you optimization needs! I have a quick question about this feature you are requesting? On which API are you wanting to see this/which API are you working with that doesn't allow you to do this?
Smith__Mike
Direct X 11, when I select No Cull or whatever, the previous selected option will now be unselected. It only allows for (one) option.
Giselle_G_Intel
Hey Mike,
Do you mean you want to be able to see two separate state tabs at the same time? Because in DX11 you are able to change multiple states all in the same session. But you want to be able to open up one tab, select a state and then open up another tab and select another state at the same time... to change them to the same value? Or do you just want to be able to select them?
