Intel® Graphics Performance Analyzers (Intel® GPA)
Improve your game's performance by quickly specifying problem areas
Start capture in the code
Laurent_C_1
Is there a way to start and stop a capture not synchronized with present call from my c++ code with DirectX 10?
Ryan_G_Intel
Hi Laurent,
I am not sure I understand your question correctly.
Laurent_C_1
Hi Ryan,
I just wonder if there is an API to do a "framecapture" in the code.
Something like:
StartGPACapture()
Do some directX call...
StopGPACapture()
So I can analyse just a part of the frame.
Laurent
Ryan_G_Intel
Hi Laurent,
I think I understand you now :-)     I think what you are looking for can be found here:
Intel® Metrics Framework - https://software.intel.com/en-us/node/659423
Intel® Platform Analysis Library - https://software.intel.com/en-us/intel-platform-analysis-library
Also, when GPA is installed, 'capture.exe' will be located in the install location.  This exe can also be used to capture a frame from the command line.
