Intel® Graphics Performance Analyzers (Intel® GPA)
Improve your game's performance by quickly specifying problem areas
Vulkan not appearing in supported APIs
Theodor
So im running GPA on Ubuntu 22.04.3 with a i5-8265U CPU with UHD620 integrated gpu.
Running Graphics Monitor on a application that uses the OpenGL API works fine from what i can tell. The problem im having is that Vulkan doesnt appear in supported APIs. The only reason i can think of is because i dont have the vulkan-sdk package installed but rather libvulkan-dev.
Pamela_H_Intel
Thanks for your post Theodor. I will check with the dev team on whether you need the full sdk.
Theodor
Well i only had libvulkan-dev vulkan-tools and validation layers installed. I removed those and installed the vulkan-sdk package from the LunarG repository but it made no difference.
The message im getting when trying to start a vulkan application is:
"ETW session was disabled or modified. Trace file can be incomplete".  Doesnt really seem to be more meaningful than the fact that Vulkan doesnt appear in the supported APIs.
Pamela_H_Intel
Theodor,
The devs reminded me that we have not implemented Vulkan on Ubuntu -- sorry, I'm on vacation, my brain wasn't engaged. As you'd noted, Vulkan is not listed in the docs: See supported Graphics APIs,
Pamela
Pamela_H_Intel
. . . and I would ask the devs to change the error message, except that we have deprecated support for Ubuntu and it will no longer be available after this month's release.
