Intel® Graphics Performance Analyzers (Intel® GPA)
Improve your game's performance by quickly specifying problem areas
What benefit do I gain by running my game in full-screen mode with GPA?
user88
Hi, i'm reading Quick Start Guide for GPA. Here i met next text:
>In order to ensure accurate metrics, you'll also want to disable as
>many other non-essential processes as possible on both systems (including screen savers), and be sure to run
>the game in full-screen mode.
I want to aks what's about non-fullscreen applications? Is it just accurate metrics question or samthing else?
Neal_Pierman
Valued Contributor I
The reason is metrics accuracy.
When you run an application in other than full-screen mode, there is additional overhead for the window manager, since you are measuring both the time for your game plus the time for the window manager. When running in full-screen mode, the window manager does not run.
For most applications the difference is probably not that significant, but using full-screen mode will help ensure that you are really attacking optimization issues within the game itself (and not necessary masked by the time utilized by the window manager).
Thanks for your use of GPA!
Neal
Neal_Pierman
Neal
user88
OK, thanks for answer Neal.
faizan4it
thanks for the explaination of such an excellent ides.
Charles_Ying
thanks for sharing wonderful information.
thanks
graphic designers
