Intel® Graphics Performance Analyzers (Intel® GPA)
Improve your game's performance by quickly specifying problem areas
551 Discussions
"This platform is not debuggable" error with Android* tablets
Stuart_L_
I'm trying to connect GPA to a Samsung Galaxy Note 10.1 (2014 Edition).
Model - SM-P605
Chip - Snapdragon 800, Krait 400(CPU), Adreno330(GPU).
I get the following message 'Cannot run application. This platform is not debuggable. Contact the Intel GPA support team.'.
I've successfully managed to connect to other variants of the Samsung Galaxy Note 10.1.
Cheers,
Stuart Leonardi
Neal_Pierman
Valued Contributor I
Can you first of all print out the information about your client system (that is, your Windows machine) -- right-click the Intel GPA Monitor in the notification tray and copy the "About..." information here.
Next, can you provide the output of "adb shell getprop"?
And do you know whether your Android system is running the latest firmware available for that device?
And you also mentioned that you tried other variants of this device, and they worked ok. Can you provide some info on one of these others that worked with Intel GPA?
thanks!
Neal
Stuart_L_
Hi Neal,
Windows 7 build 7601, 64-bit DEP enabled
Num Processors: 12
Memory: 16309MB
System BIOS: Dell Inc. A10 (11/03/2013)
Video BIOS: Version 80.04.BF.00.01  (06/17/13)
Driver 0:
     Device: NVIDIA GeForce GTX 760
     Provider: NVIDIA
     Date: 7-2-2014
     Version: 9.18.13.4052
     VendorId: 10de
     ProductId: 1187
     Stepping: a1
     No support for GPA Instrumentation
GPA install directory: C:\Intel\INDE\GPA\2014 R2\
GPA version: 14.2.225646
Current user is in Administrators group: YES
Current GPA 2014 R2 (14.2.225646)
Secure Boot/Trusted Boot is Disabled
>>Next, are you able to provide the output of "adb shell getprop"?
[init.svc.ril-daemon]: [running]
[init.svc.ril-qmi]: [stopped]
[init.svc.rmt_storage]: [running]
[init.svc.run-mobicore]: [running]
[init.svc.scranton_RD]: [stopped]
[init.svc.sdcard]: [stopped]
[init.svc.sec-sh]: [stopped]
[init.svc.secure_storage]: [running]
[init.svc.security-check1]: [stopped]
[init.svc.security-check2]: [stopped]
[init.svc.servicemanager]: [running]
[init.svc.ssr_diag]: [running]
[init.svc.surfaceflinger]: [running]
[init.svc.swapon]: [stopped]
[init.svc.thermal-engine]: [running]
[init.svc.time_daemon]: [running]
[init.svc.ueventd]: [running]
[init.svc.usf-post-boot]: [stopped]
[init.svc.vold]: [running]
[init.svc.wcnss-service]: [stopped]
[init.svc.zygote]: [running]
[installd.sdcard_manipulate_done]: [1]
[keyguard.no_require_sim]: [true]
[lpa.decode]: [false]
[lpa.use-stagefright]: [false]
[media.aac_51_output_enabled]: [true]
[media.enable-commonsource]: [true]
[media.stagefright.enable-aac]: [true]
[media.stagefright.enable-fma2dp]: [true]
[media.stagefright.enable-http]: [true]
[media.stagefright.enable-player]: [true]
[media.stagefright.enable-qcp]: [true]
[media.stagefright.enable-scan]: [true]
[mmp.enable.3g2]: [true]
[net.bt.name]: [Android]
[net.change]: [net.dns2]
[net.dns1]: [10.1.200.1]
[net.dns2]: [10.1.200.2]
[net.hostname]: [android-1f7fa92d3166c1b2]
[net.qtaguid_enabled]: [1]
[net.tcp.buffersize.default]: [4096,87380,704512,4096,16384,110208]
[net.tcp.buffersize.edge]: [4093,26280,35040,4096,16384,35040]
[net.tcp.buffersize.evdo]: [4094,87380,262144,4096,16384,262144]
[net.tcp.buffersize.gprs]: [4096,30000,30000,4096,8760,11680]
[net.tcp.buffersize.hsdpa]: [4092,87380,704512,4096,16384,110208]
[net.tcp.buffersize.hspa]: [4092,87380,704512,4096,16384,262144]
[net.tcp.buffersize.hspap]: [4092,87380,704512,4096,16384,262144]
[net.tcp.buffersize.hsupa]: [4092,87380,704512,4096,16384,262144]
[net.tcp.buffersize.lte]: [524288,1048576,2560000,524288,1048576,2560000]
[net.tcp.buffersize.umts]: [4094,87380,704512,4096,16384,110208]
[net.tcp.buffersize.wifi]: [524288,1048576,2560000,524288,1048576,2560000]
[persist.audio.allsoundmute]: [0]
[persist.audio.headsetsysvolume]: [9]
[persist.audio.hphonesysvolume]: [9]
[persist.audio.ringermode]: [1]
[persist.audio.sysvolume]: [1]
[persist.cne.feature]: [0]
[persist.data.netmgrd.qos.enable]: [false]
[persist.debug.wfd.enable]: [1]
[persist.demo.hdmirotationlock]: [false]
[persist.env.phone.global]: [false]
[persist.env.plmn.update]: [false]
[persist.fuse_sdcard]: [true]
[persist.gps.qc_nlp_in_use]: [1]
[persist.hwc.mdpcomp.enable]: [true]
[persist.radio.apm_sim_not_pwdn]: [1]
[persist.radio.initphone-type]: [1]
[persist.rild.nitz_long_ons_0]: []
[persist.rild.nitz_long_ons_1]: []
[persist.rild.nitz_long_ons_2]: []
[persist.rild.nitz_long_ons_3]: []
[persist.rild.nitz_plmn]: []
[persist.rild.nitz_short_ons_0]: []
[persist.rild.nitz_short_ons_1]: []
[persist.rild.nitz_short_ons_2]: []
[persist.rild.nitz_short_ons_3]: []
[persist.security.ams.enforcing]: [1]
[persist.speaker.prot.enable]: [false]
[persist.sys.camera.connect]: [0]
[persist.sys.camera.transform]: [0]
[persist.sys.clssprld1]: [698]
[persist.sys.clssprld2]: [738]
[persist.sys.country]: [GB]
[persist.sys.dalvik.vm.lib]: [libdvm.so]
[persist.sys.drs.date]: [Wed Jun 11 21:38:31 KST 2014]
[persist.sys.drs.enforce]: [0]
[persist.sys.flipfontpath]: [default]
[persist.sys.language]: [en]
[persist.sys.localevar]: []
[persist.sys.logkit.ctrlcode]: [0]
[persist.sys.profiler_ms]: [0]
[persist.sys.screen.rotation.Off]: [-1]
[persist.sys.setupwizard]: [FINISH]
[persist.sys.silent]: [1]
[persist.sys.storage_preload]: [2]
[persist.sys.strict_op_enable]: [false]
[persist.sys.timezone]: [Europe/London]
[persist.sys.usb.config]: [mtp,adb]
[persist.sys.wfd.virtual]: [0]
[persist.sys.whitelist]: [/system/etc/whitelist_appops.xml]
[persist.sys.xtra_time]: [1408706420934]
[persist.timed.enable]: [true]
[ril.CompleteMsg]: [01]
[ril.ICC_TYPE]: [0]
[ril.RildInit]: [1]
[ril.approved_codever]: [none]
[ril.approved_cscver]: [none]
[ril.approved_modemver]: [none]
[ril.atd_status]: [1_1_0]
[ril.cs_svc]: [1]
[ril.deviceOffRes]: [0]
[ril.ecclist0]: [112,911,999,000,08,110,118,119]
[ril.ecclist]: [911,*911,#911,112,000,08,110,999,118,119]
[ril.hw_ver]: [MP 0.900]
[ril.modem.board]: [MSM8974]
[ril.official_cscver]: [P605DBTCNF1]
[ril.product_code]: [SM-P6050ZWADBT]
[ril.radiostate]: [10]
[ril.rfcal_date]: [2014.01.14]
[ril.sales_code]: [DBT]
[ril.serialnumber]: [RF2F110TJNL]
[ril.servicestate]: [2]
[ril.subscription.types]: [NV,RUIM]
[ril.sw_ver]: [P605XXUCNF2]
[ril.timezoneID]: [Europe/London]
[rild.libargs]: [-d /dev/smd0]
[rild.libpath]: [/system/lib/libsec-ril.so]
[ro.adb.secure]: [1]
[ro.allow.mock.location]: [0]
[ro.baseband]: [msm]
[ro.bluetooth.dun]: [true]
[ro.bluetooth.hfp.ver]: [1.6]
[ro.bluetooth.sap]: [true]
[ro.board.platform]: [msm8974]
[ro.boot.baseband]: [msm]
[ro.boot.boot_recovery]: [0]
[ro.boot.bootloader]: [P605XXUCNF2]
[ro.boot.cp_debug_level]: [0x55FF]
[ro.boot.debug_level]: [0x4f4c]
[ro.boot.emmc]: [true]
[ro.boot.emmc_checksum]: [3]
[ro.boot.hardware]: [qcom]
[ro.boot.nvdata_backup]: [0]
[ro.boot.sec_atd.tty]: [/dev/ttyHSL0]
[ro.boot.serialno]: [776b6205]
[ro.boot.uart_debug]: [0]
[ro.boot.warranty_bit]: [1]
[ro.boot_recovery]: [0]
[ro.bootloader]: [P605XXUCNF2]
[ro.bootmode]: [unknown]
[ro.bt.bdaddr_path]: [/efs/bluetooth/bt_addr]
[ro.build.PDA]: [P605XXUCNF2]
[ro.build.changelist]: [1914976]
[ro.build.characteristics]: [tablet]
[ro.build.date.utc]: [1402490311]
[ro.build.date]: [Wed Jun 11 21:38:31 KST 2014]
[ro.build.description]: [lt03ltexx-user 4.4.2 KOT49H P605XXUCNF2 release-keys]
[ro.build.display.id]: [KOT49H.P605XXUCNF2]
[ro.build.fingerprint]: [samsung/lt03ltexx/lt03lte:4.4.2/KOT49H/P605XXUCNF2:user
/release-keys]
[ro.build.hidden_ver]: [P605XXUCNF2]
[ro.build.host]: [SWDD6007]
[ro.build.id]: [KOT49H]
[ro.build.knox.container]: []
[ro.build.product]: [lt03lte]
[ro.build.scafe.shot]: [single]
[ro.build.scafe.size]: [grande]
[ro.build.scafe]: [americano]
[ro.build.selinux.enforce]: [1]
[ro.build.selinux]: [1]
[ro.build.tags]: [release-keys]
[ro.build.type]: [user]
[ro.build.user]: [dpi]
[ro.build.version.codename]: [REL]
[ro.build.version.incremental]: [P605XXUCNF2]
[ro.build.version.release]: [4.4.2]
[ro.build.version.sdk]: [19]
[ro.carrier]: [unknown]
[ro.chipname]: [MSM8974]
[ro.com.android.dateformat]: [MM-dd-yyyy]
[ro.com.google.clientidbase]: [android-samsung]
[ro.com.google.gmsversion]: [4.4.2_r2]
[ro.config.alarm_alert]: [Alarm_Morning_flower.ogg]
[ro.config.knox]: [1]
[ro.config.media_sound]: [Media_preview_Touch_the_light.ogg]
[ro.config.notification_sound]: [S_Whistle.ogg]
[ro.config.ringtone]: [Over_the_horizon.ogg]
[ro.config.rm_preload_enabled]: [0]
[ro.config.tima]: [1]
[ro.config.timaversion]: [2.0]
[ro.cp_debug_level]: [0x55FF]
[ro.crypto.state]: [unencrypted]
[ro.csc.country_code]: [Germany]
[ro.csc.countryiso_code]: [DE]
[ro.csc.sales_code]: [DBT]
[ro.debug_level]: [0x4f4c]
[ro.debuggable]: [0]
[ro.emmc]: [true]
[ro.emmc_checksum]: [3]
[ro.error.receiver.default]: [com.samsung.receiver.error]
[ro.factorytest]: [0]
[ro.gps.agps_provider]: [1]
[ro.hardware]: [qcom]
[ro.hdcp2.rx]: [tz]
[ro.hdmi.enable]: [true]
[ro.hwui.drop_shadow_cache_size]: [4]
[ro.hwui.gradient_cache_size]: [1]
[ro.hwui.layer_cache_size]: [32]
[ro.hwui.path_cache_size]: [8]
[ro.hwui.shape_cache_size]: [2]
[ro.hwui.text_large_cache_height]: [1024]
[ro.hwui.text_large_cache_width]: [2048]
[ro.hwui.text_small_cache_height]: [512]
[ro.hwui.text_small_cache_width]: [1024]
[ro.hwui.texture_cache_size]: [48]
[ro.kernel.qemu]: [0]
[ro.nfc.port]: [I2C]
[ro.nvdata_backup]: [0]
[ro.opengles.version]: [196608]
[ro.product.board]: [MSM8974]
[ro.product.brand]: [samsung]
[ro.product.cpu.abi2]: [armeabi]
[ro.product.cpu.abi]: [armeabi-v7a]
[ro.product.device]: [lt03lte]
[ro.product.locale.language]: [en]
[ro.product.locale.region]: [GB]
[ro.product.manufacturer]: [samsung]
[ro.product.model]: [SM-P605]
[ro.product.name]: [lt03ltexx]
[ro.product_ship]: [true]
[ro.qc.sdk.audio.fluencetype]: [none]
[ro.qc.sdk.audio.ssr]: [false]
[ro.qc.sdk.camera.facialproc]: [false]
[ro.qc.sdk.izat.premium_enabled]: [0]
[ro.qc.sdk.izat.service_mask]: [0x0]
[ro.qc.sdk.sensors.gestures]: [true]
[ro.qualcomm.bluetooth.ftp]: [true]
[ro.qualcomm.bluetooth.hfp]: [true]
[ro.qualcomm.bluetooth.hsp]: [true]
[ro.qualcomm.bluetooth.map]: [true]
[ro.qualcomm.bluetooth.nap]: [true]
[ro.qualcomm.bluetooth.opp]: [true]
[ro.qualcomm.bluetooth.pbap]: [true]
[ro.qualcomm.bt.hci_transport]: [smd]
[ro.qualcomm.cabl]: [1]
[ro.revision]: [11]
[ro.ril.svdo]: [false]
[ro.ril.svlte1x]: [false]
[ro.runtime.firstboot]: [1406257082885]
[ro.sec.fle.encryption]: [true]
[ro.secure]: [1]
[ro.securestorage.support]: [true]
[ro.security.mdpp.release]: [2]
[ro.security.mdpp.ux]: [Enabled]
[ro.security.mdpp.ver]: [1.0]
[ro.secwvk]: [144]
[ro.serialno]: [776b6205]
[ro.setupwizard.mode]: [OPTIONAL]
[ro.sf.lcd_density]: [320]
[ro.slook.ver]: [1]
[ro.telephony.call_ring.multiple]: [false]
[ro.use_data_netmgrd]: [false]
[ro.vendor.extension_library]: [/vendor/lib/libqc-opt.so]
[ro.warranty_bit]: [1]
[ro.wifi.channels]: []
[sec.fle.encryption.status]: [Dec NewFile IncludeMedia]
[secmm.player.disabledivx]: [True]
[secmm.player.gp.url]: [true]
[secmm.player.uhqamode]: [True]
[security.mdpp.result]: [None]
[security.mdpp]: [Ready]
[selinux.policy_version]: [SEPF_SM-P605_4.4.2_0016]
[selinux.reload_policy]: [1]
[service.bootanim.exit]: [0]
[service.media.powersnd]: [1]
[storage.mmc.size]: [15758000128]
[sys.boot_completed]: [1]
[sys.cameramode.blackbox]: [0]
[sys.cameramode.vtcall]: [0]
[sys.factory.mediaScanningCount]: [3]
[sys.hangouts.fps]: [-1]
[sys.ims.QMI_DAEMON_STATUS]: [1]
[sys.knox.zygote.containerapps]: [true]
[sys.mobicoredaemon.enable]: [true]
[sys.qseecomd.enable]: [true]
[sys.settings_global_version]: [1]
[sys.settings_secure_version]: [1]
[sys.settings_system_version]: [39]
[sys.shutdown.fastboot]: [false]
[sys.sysctl.extra_free_kbytes]: [48000]
[sys.usb.config]: [mtp,adb]
[sys.usb.state]: [mtp,adb]
[tunnel.audiovideo.decode]: [false]
[tunnel.decode]: [false]
[vold.post_fs_data_done]: [1]
[wifi.interface]: [wlan0]
[wlan.driver.status]: [ok]
[wlan.wfd.status]: [disconnected]
No updates are available, we are running Android 4.4.2
Model - SM-P600
Chip - Exynos 5, Cortex A15+Cortex-A7(CPU), ARM Mali-T628-MP6(GPU).
Cheers,
Stuart
Neal_Pierman
We're beginning to suspect that a bug in the Android* OS may be causing this issue. We're seeing more and more systems where the "run-as" command that Intel GPA uses has the incorrect priv's associated with it.
If this is the case, you have two choices: (1) load a version of the firmware that does not have this issue, or (2) "root" the device.
I'll do some more checking and get back to you on this.
Neal
Neal_Pierman
Some more info for you...
You should try the following command to see if your "run-as" command is "broken" on this system:
   adb shell run-as <package name>
where <package name> is the full package name which you can get using "adb shell pm list packages".
If you get something like "package name is unknown", then your system has the "bad" version of the "run-as" command. This problem was originally reported in an earlier release of Android*, and was fixed, but we're still seeing this in a number of 4.4.2 systems.
Neal
ps-> I'll try digging up more documentation on this issue and include the link to the bug report
Neal_Pierman
For more information on the "run-as" issue, see this link.
Neal
Stuart_L_
I've verified that this is indeed the 'bad' version of the 'run-as' command.
Thank you for the link to the information.
Cheers,
Stuart
Neal_Pierman
For other watching this thread, a similar problem was occurring with the Asus MemoPad 8. A recent firmware update (late September of 2014) has now fixed this.
Neal
Loddipalli_S_
this platform is not debuggable" error for Redmi 1S WCDMA
with android 4.3 version and latest stable rom (43.0)  for the device
here is below system information and adb shell getprop logfile
Num Processors: 8
Memory: 6038MB
System BIOS: Dell Inc. A06 (07/20/2011)
Video BIOS: 05/16/20
Driver 0:
     Device: Intel(R) HD Graphics 3000
     Provider: Intel Corporation
     Date: 3-20-2014
     Version: 9.17.10.3517
     VendorId: 8086
     ProductId: 116
     Stepping: 9
     Supports GPA Instrumentation
Install directory: C:\Intel\INDE\GPA\2014 R3\
Version: 14.3.231370
Current Graphics Performance Analyzers 2014 R3 (14.3.231370)
[DEVICE_PROVISIONED]: [1]
[dalvik.vm.heapgrowthlimit]: [96m]
[dalvik.vm.heapmaxfree]: [8m]
[dalvik.vm.heapminfree]: [2m]
[dalvik.vm.heapsize]: [256m]
[dalvik.vm.heapstartsize]: [8m]
[dalvik.vm.heaptargetutilization]: [0.75]
[dalvik.vm.stack-trace-file]: [/data/anr/traces.txt]
[debug.cl.profiler]: [1]
[debug.composition.type]: [c2d]
[debug.egl.hw]: [1]
[debug.egl.profiler]: [1]
[debug.mdpcomp.bw]: [1.66]
[debug.mdpcomp.logs]: [0]
[debug.sf.fb_always_on]: [1]
[debug.sf.hw]: [1]
[dev.bootcomplete]: [1]
[dev.pm.dyn_samplingrate]: [1]
[dhcp.wlan0.dns1]: [192.168.202.1]
[dhcp.wlan0.dns2]: []
[dhcp.wlan0.dns3]: []
[dhcp.wlan0.dns4]: []
[dhcp.wlan0.domain]: [connectify]
[dhcp.wlan0.gateway]: [0.0.0.0]
[dhcp.wlan0.ipaddress]: [192.168.202.101]
[dhcp.wlan0.leasetime]: [43200]
[dhcp.wlan0.mask]: [255.255.255.0]
[dhcp.wlan0.pid]: [11546]
[dhcp.wlan0.reason]: [REBOOT]
[dhcp.wlan0.result]: [ok]
[dhcp.wlan0.server]: [192.168.202.1]
[dhcp.wlan0.vendorInfo]: []
[dolby.audio.sink.info]: [speaker]
[drm.service.enabled]: [true]
[gsm.apn.sim.operator.numeric]: [,40473]
[gsm.current.phone-type]: [1,1]
[gsm.network.type]: [Unknown,GPRS]
[gsm.operator.alpha]: [null,CellOne]
[gsm.operator.iso-country]: [,in]
[gsm.operator.isroaming]: [false,false]
[gsm.operator.numeric]: [null,40473]
[gsm.sim.operator.alpha]: [,]
[gsm.sim.operator.iso-country]: [,in]
[gsm.sim.operator.numeric]: [,40473]
[gsm.sim.state]: [ABSENT,READY]
[gsm.version.baseband]: [MPSS.TR.2.0-b56bcd8,MPSS.TR.2.0-b56bcd8]
[gsm.version.ril-impl]: [Qualcomm RIL 1.0]
[hw.cabl.level]: [Auto]
[hw.cabl.version]: [1.1.20130401]
[hw.cabl.yuv]: [0]
[hw.pp.cfg]: [/data/pp_data.cfg]
[init.svc.adbd]: [running]
[init.svc.adsprpcd]: [running]
[init.svc.atfwd]: [stopped]
[init.svc.bootanim]: [stopped]
[init.svc.charger_monitor]: [running]
[init.svc.cnd]: [running]
[init.svc.config_bluetooth]: [stopped]
[init.svc.debuggerd]: [running]
[init.svc.dhcpcd_wlan0]: [running]
[init.svc.drm]: [running]
[init.svc.flash_recovery]: [stopped]
[init.svc.gsiff_daemon]: [running]
[init.svc.immvibed]: [stopped]
[init.svc.ims_rtp_daemon]: [running]
[init.svc.imsdatadaemon]: [running]
[init.svc.imsqmidaemon]: [running]
[init.svc.installd]: [running]
[init.svc.irsc_util]: [stopped]
[init.svc.keystore]: [running]
[init.svc.lbesec]: [stopped]
[init.svc.mcd_init]: [stopped]
[init.svc.mcd_service]: [running]
[init.svc.mdbd]: [running]
[init.svc.media]: [running]
[init.svc.modem_dump]: [running]
[init.svc.mpdecision]: [running]
[init.svc.netd]: [running]
[init.svc.netmgrd]: [running]
[init.svc.p2p_supplicant]: [running]
[init.svc.ppd]: [running]
[init.svc.ptt_socket_app]: [stopped]
[init.svc.qcamerasvr]: [running]
[init.svc.qcom-c_core-sh]: [stopped]
[init.svc.qcom-c_main-sh]: [stopped]
[init.svc.qcom-post-boot]: [stopped]
[init.svc.qcom-sh]: [stopped]
[init.svc.qcom-usb-sh]: [stopped]
[init.svc.qcomsysd]: [running]
[init.svc.qmuxd]: [running]
[init.svc.qrngd]: [running]
[init.svc.qrngp]: [stopped]
[init.svc.qseecomd]: [running]
[init.svc.rfs_access]: [running]
[init.svc.ril-daemon1]: [running]
[init.svc.sdcard]: [running]
[init.svc.sensors]: [running]
[init.svc.shelld]: [running]
[init.svc.wcnss-service]: [running]
[init.svc.wifi-crda]: [stopped]
[lpa.use-stagefright]: [true]
[mdbd.framework_channel.ready]: [1]
[mm.enable.qcom_parser]: [37491]
[mm.enable.smoothstreaming]: [true]
[net.change]: [net.dns1]
[net.dns1]: [192.168.202.1]
[net.hostname]: [android-a123ae81eac3014b]
[net.tcp.buffersize.default]: [4096,87380,110208,4096,16384,110208]
[net.tcp.buffersize.gprs]: [4092,8760,11680,4096,8760,11680]
[net.tcp.buffersize.hsdpa]: [4094,87380,1220608,4096,16384,1220608]
[net.tcp.buffersize.hspa]: [4094,87380,1220608,4096,16384,1220608]
[net.tcp.buffersize.hspap]: [4094,87380,1220608,4096,16384,1220608]
[net.tcp.buffersize.hsupa]: [4094,87380,1220608,4096,16384,1220608]
[net.tcp.buffersize.lte]: [524288,1048576,2097152,262144,524288,1048576]
[net.tcp.buffersize.umts]: [4094,87380,110208,4096,16384,110208]
[net.tcp.buffersize.wifi]: [524288,2097152,4194304,262144,524288,1048576]
[permanent.radio.modem]: [WCDMA]
[persist.audio.dirac.headset]: [8]
[persist.audio.dirac.music.state]: [1]
[persist.audio.init_volume_index]: [1]
[persist.cne.feature]: [1]
[persist.data.netmgrd.qos.enable]: [true]
[persist.demo.hdmirotationlock]: [true]
[persist.gps.qc_nlp_in_use]: [0]
[persist.omh.enabled]: [true]
[persist.power.useautobrightadj]: [true]
[persist.radio.adb_log_on]: [0]
[persist.radio.airplane_mode_on]: [0]
[persist.radio.default.sub]: [1]
[persist.radio.dont_use_dsd]: [true]
[persist.radio.eons.enabled]: [false]
[persist.radio.modem]: [WCDMA]
[persist.radio.msgtunnel.start]: [false]
[persist.radio.multisim.config]: [dsds]
[persist.radio.paging_priority_0]: [1]
[persist.radio.ramdump_sdcard]: [1]
[persist.service.bdroid.bdaddr]: [22:22:da:3e:e8:06]
[persist.sys.auto-start.once]: [true]
[persist.sys.button_headset_hook]: [media]
[persist.sys.button_jack_profile]: [volume]
[persist.sys.button_jack_switch]: [0]
[persist.sys.cnd.iwlan]: [1]
[persist.sys.device_name]: [srihari]
[persist.sys.display_prefer]: [2]
[persist.sys.downscale.disable]: [1]
[persist.sys.memctrl]: [on]
[persist.sys.mitalk.enable]: [true]
[persist.sys.ssr.restart_level]: [3]
[persist.sys.strictmode.disable]: [true]
[persist.sys.timezone]: [Asia/Calcutta]
[persist.sys.user_mode]: [0]
[qcom.audio.init]: [complete]
[qcom.hw.aac.encoder]: [true]
[ril.ecclist1]: [911,*911,#911,112,100,101,102]
[ril.ecclist]: [911,*911,#911,112,100,101,102]
[ril.qcril_pre_init_lock_held]: [0]
[ril.subscription.types]: [RUIM]
[rild.libpath]: [/vendor/lib/libril-qc-qmi-1.so]
[ro.alarm_boot]: [false]
[ro.bluetooth.dun]: [false]
[ro.board.platform]: [msm8226]
[ro.boot.console]: [ttyHSL0]
[ro.boot.serialno]: [e6024a5a]
[ro.bootloader]: [unknown]
[ro.build.characteristics]: [default]
[ro.build.date.utc]: [1411568671]
[ro.build.date]: [Wed Sep 24 22:24:31 CST 2014]
[ro.build.description]: [armani-user 4.3 JLS36C JHCMIBH43.0 release-keys]
[ro.build.display.id]: [JLS36C]
[ro.build.fingerprint]: [Xiaomi/armani/armani:4.3/JLS36C/JHCMIBH43.0:user/release-keys]
[ro.build.host]: [zc-miui-ota-bd37]
[ro.build.id]: [JLS36C]
[ro.build.product]: [armani]
[ro.build.user]: [builder]
[ro.build.version.incremental]: [JHCMIBH43.0]
[ro.build.version.release]: [4.3]
[ro.build.version.sdk]: [18]
[ro.com.android.dataroaming]: [false]
[ro.com.android.mobiledata]: [false]
[ro.com.google.clientidbase]: [android-xiaomi]
[ro.com.google.gmsversion]: [4.3_r5]
[ro.com.widevine.cachesize]: [16777216]
[ro.config.alarm_alert]: [GoodMorning.ogg]
[ro.config.elder-ringtone]: [Angel.mp3]
[ro.config.notification_sound]: [FadeIn.ogg]
[ro.config.ringtone]: [MI.ogg]
[ro.config.sms_delivered_sound]: [MessageComplete.ogg]
[ro.config.sms_received_sound]: [FadeIn.ogg]
[ro.miui.cust_variant]: [in]
[ro.miui.region]: [in]
[ro.miui.ui.version.code]: [3]
[ro.miui.ui.version.name]: [V5]
[ro.product.board]: [MSM8226]
[ro.product.brand]: [Xiaomi]
[ro.product.device]: [armani]
[ro.product.locale.region]: [US]
[ro.product.manufacturer]: [Xiaomi]
[ro.product.mod_device]: [armani_global]
[ro.product.model]: [HM 1S]
[ro.product.name]: [armani]
[ro.product.real_model]: [HM 1SW]
[ro.qc.sdk.audio.fluencetype]: [fluence]
[ro.qc.sdk.izat.premium_enabled]: [1]
[ro.qualcomm.svi]: [1]
[ro.revision]: [0]
[ro.ril.miui.imei]: [865622025995320]
[ro.ril.oem.imei1]: [865622025995320]
[ro.ril.oem.imei2]: [865622025995338]
[ro.ril.oem.imei]: [865622025995320]
[ro.runtime.firstboot]: [1412354615075]
[ro.secure]: [1]
[ro.serialno]: [e6024a5a]
[ro.sys.fw.bg_apps_limit]: [10]
[ro.sys.oem.sno]: [114307227599]
[ro.telephony.default_network]: [0]
[ro.usb.pid.mass_storage.adb]: [1228]
[ro.usb.pid.mass_storage]: [1220]
[ro.usb.pid.mtp.adb]: [1268]
[ro.usb.pid.mtp]: [1260]
[ro.usb.pid.ptp.adb]: [1218]
[ro.usb.pid.ptp]: [1210]
[ro.usb.pid.rndis.adb]: [1288]
[ro.usb.pid.rndis]: [1280]
[ro.use_data_netmgrd]: [true]
[service.bootanim.exit]: [1]
[sys.foreground_process]: [com.miui.home]
[sys.ims.DATA_DAEMON_STATUS]: [1]
[sys.is_keyguard_showing]: [0]
[sys.media.vdec.sw]: [0]
[sys.memory.threshold.low]: [524288000]
[sys.sd2_boot_mounted]: [0]
[sys.settings_global_version]: [23]
[sys.settings_secure_version]: [5]
[sys.settings_system_version]: [28]
[sys.sysmat.service.control]: [stopsend]
[system_init.startsurfaceflinger]: [0]
[tunnel.audio.encode]: [true]
[tunnel.audiovideo.decode]: [true]
[tunnel.decode]: [true]
[vidc.debug.level]: [1]
[wlan.crda.country]: [00]
[wlan.driver.ath]: [0]
[wlan.driver.config]: [/data/misc/wifi/WCNSS_qcom_cfg.ini]
Loddipalli_S_
After going through the link you have given i was able to connect my device to intel system analyzer
and it even detects my debuggable app and when i run the app on the mobile and try to open through  system analyzer
i am getting the following error
Application error:  open: permission denied open : Permission denied
and i have the follwowing permissions in my manifest file
 <uses-permission android:name="android.permission.ACCESS_NETWORK_STATE" />
    <uses-permission android:name="android.permission.ACCESS_WIFI_STATE" />
    <uses-permission android:name="android.permission.INTERNET" />
    <uses-permission android:name="android.permission.WRITE_EXTERNAL_STORAGE" />
    <uses-permission android:name="android.permission.WAKE_LOCK" />
    <uses-permission android:name="com.android.vending.CHECK_LICENSE" />
    <uses-permission android:name="android.permission.BLUETOOTH" />
    <uses-permission android:name="com.android.vending.BILLING" />
    <uses-permission android:name="android.permission.READ_PHONE_STATE" />
    <uses-permission android:name="android.permission.GET_ACCOUNTS" />
Neal_Pierman
I believe that your Android* system is an ARM* device, and only a limited number of non-Intel Android* devices are supported. The only ARM* devices that are supported are documented here: https://software.intel.com/en-us/articles/intel-gpa-release-notes
Sorry that we don't support your device at this time.
Neal
EichmannCharity
Has your problem been resolved? If your problem is ringtone, check out: https://kostenloseklingeltone.de/
Pamela_H_Intel
Folks - Intel(r) GPA no longer supports Android OS. But it will work for Android emulators run on systems we do support.
Pamela
