Intel® High Level Design
703 Discussions
customer wants to confirm software license compatibility - QE0A4A1
PL-USB2-BLASTER
Customer wants to confirm item# IP-JESD204B
" I am using an Intel IP core called JESD204B. This core is licensed and
I'm trying to purchase the license from Mouser. The license is IP-JESD204B.
Since the IP-JESD204B is NCNR, I'd like to be 100% sure that this license
is the one I need and will work with my chosen FPGA family, IP version,
Quartus version, etc."
Please advise. thanks
Neil
PL-USB2-BLASTER
Customer asking for an update to their inquiry. Please advise.
thanks,
Neil
ZH_Intel
Hi Neil,
Thank you for reaching out.
Just to let you know that Intel has received your support request and currently we are confirming the details with our internal team.
Allow me some time to look into your issue. I shall come back to you with findings.
Thank you for your patience.
ZulsyafiqH_Intel
ZH_Intel
Hi Neil,
Good day.
Regarding to your question, I might not be able to direct if the license is the correct one or which license you require without looking at the project.
However I can suggest to you to apply an Intel 90-Day Evaluation License use with Quartus Pro/Standard (Free licensing trial).
Login to Intel® FPGA Self Service Licensing Center and request the Quartus evaluation free license here: https://licensing.intel.com/
1) Go to Sign up for Evaluation or Free licenses
2) Select Intel® FPGA EVALUATION-LIC
3) # of Seats is always 1
4) Check the T&C box
5) Add the required options
6) Click Get License button
Once you run your project compilation, Quartus will automatically create a assembler report, .asm.rpt file.
( The assembler report is located in <Project directory>/Output_files/<project_name>.asm.rpt.)
This report will show which IP license that you do not have, then you may proceed to select the IP to purchase.
You may refer to below KDB as your reference:
FPGA Knowledge Base Article ID: 000080459 - IP licensing
Hope this answer you question.
May I know if are you using Intel development kit?"
Thank you.
ZulsyafiqH_Intel
ZH_Intel
Hi Neil,
Good day.
We have not heard from you for quite some time.
I wish to follow up with you on this Case.
Did you manage to generate the Assembler report?
From the report you can see similar view as below to see which is license or unlicensed:
Assembler report exampleAssembler report example
Based on the JESD204B Intel® FPGA IP User guide under chapter 2.1 Release information, you can see the ordering code for this IP is "IP-JESD204B". You may share the assembler report and User Guide to double confirm with your distributor.
JESD204B Release informationJESD204B Release information
You may refer to below link for more information:
JESD204B Intel® FPGA IP User Guide - 2.1. Release Information
Hope this answer your question.
Thank you.
ZulsyafiqH_Intel
ZH_Intel
Hi Neil,
Good day.
We have not heard from you for about 2 weeks already.
Do you still have further inquiries on this case?
If there is no further inquiries, I will transition this thread to community support.
Thank you.
ZulsyafiqH_Intel
PL-USB2-BLASTER
Sorry for the delay, our sales rep contacted the customer again & will update you once we have more information.
thanks,
Neil
ZH_Intel
Hi Neil,
Good day.
Did you manage to get reply from customer?
Thank you.
ZulsyafiqH_Intel
PL-USB2-BLASTER
Unfortunately, our customer failed to respond & provide additional information to this inquiry.
thanks,
Neil
ZH_Intel
Hi Neil,
Thank you for your reply.
In that case, I will transition this thread to community support.
If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread.
Stay safe, and I hope you have a great day.
Thank you.
ZulsyafiqH_Intel
